Kharn13 Posted August 2, 2024 Share Posted August 2, 2024 Hi folks, Is this the right place to post for 40K Crusade shenanigans? Thanks in advance Link to comment https://bolterandchainsword.com/topic/383410-40k-crusade/ Share on other sites More sharing options...
Solution Captain Idaho Posted August 10, 2024 Solution Share Posted August 10, 2024 Do you mean the campaign side of 40K, called Crusade? They use the broader 40K rules and the relevant section is appropriate. So regarding a Crusade campaign discussion, Amicus Aedes is appropriate, whereas factions specific discussion should be in the relevant faction specific forum. Hope that helps. Kharn13 1 Back to top Link to comment https://bolterandchainsword.com/topic/383410-40k-crusade/#findComment-6055254 Share on other sites More sharing options...
Kharn13 Posted August 18, 2024 Author Share Posted August 18, 2024 Do you mean the campaign side of 40K, called Crusade? They use the broader 40K rules and the relevant section is appropriate. So regarding a Crusade campaign discussion, Amicus Aedes is appropriate, whereas factions specific discussion should be in the relevant faction specific forum. Hope that helps. Thank you, much appreciated. Link to comment https://bolterandchainsword.com/topic/383410-40k-crusade/#findComment-6057647 Share on other sites More sharing options...
