kabaakaba Posted August 10, 2024 Share Posted August 10, 2024 Hello mates! I'm waiting for my basing materials but wan't to start paint the models, what the best way to fix model on base for priming ang painting without glueing it? Link to comment https://bolterandchainsword.com/topic/383450-best-way-to-fix-model-on-base-without-glueing/ Share on other sites More sharing options...
Solution Grotsmasha Posted August 10, 2024 Solution Share Posted August 10, 2024 (edited) Double sided tape, or blu-tac (poster putty) on a bottle cap or some such Edited August 10, 2024 by Grotsmasha Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/383450-best-way-to-fix-model-on-base-without-glueing/#findComment-6055237 Share on other sites More sharing options...
Xenith Posted August 12, 2024 Share Posted August 12, 2024 Best way I have found is to pin it - small hole through the base into the foot and superglue together or you can then stick the pin into a cork and paint the model. the model easily detaches from the base, after you're done with the base, you drill a small hole again and reattach the model - I believe this is what GW do. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/383450-best-way-to-fix-model-on-base-without-glueing/#findComment-6055566 Share on other sites More sharing options...
