INKS Posted August 23, 2024 Share Posted August 23, 2024 Will probably magnetize them so I can use whatever is best, unless there is no difference between swords and spears. but there is likely a difference. Link to comment https://bolterandchainsword.com/topic/383463-new-aos-models-gold-ba-releases/page/7/#findComment-6059336 Share on other sites More sharing options...
Karhedron Posted August 23, 2024 Share Posted August 23, 2024 I am going to keep running my OG Sanguinary Guard I think. I am not a huge fan of the new models and since Swords > Spears, I won't be losing anything by running my old loadouts. INKS 1 Back to top Link to comment https://bolterandchainsword.com/topic/383463-new-aos-models-gold-ba-releases/page/7/#findComment-6059345 Share on other sites More sharing options...
DemonGSides Posted August 23, 2024 Share Posted August 23, 2024 Will probably magnetize them so I can use whatever is best, unless there is no difference between swords and spears. but there is likely a difference. Warcom showed us the difference early this week. Swords are just straight up better, unfortunately. The maths been done to death in various places, but there's only the smallest niche available to the Spear that makes them the correct build. That being said, when they had the same issue with Deathwing Knights, they ended up getting buffed so that there was a legit choice between weapons, so The Spears could get there. I think just making them Ap -3 probably gets them there for me, or maybe making them strength 7? They don't need to do much to make it a consideration to be made; it probably should just be "Encarmine weapons" and then have a sweep and a strike profile. Helias_Tancred, INKS and Karhedron 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/383463-new-aos-models-gold-ba-releases/page/7/#findComment-6059351 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 23, 2024 Share Posted August 23, 2024 Warcom showed us the difference early this week. Swords are just straight up better, unfortunately. The maths been done to death in various places, but there's only the smallest niche available to the Spear that makes them the correct build. That being said, when they had the same issue with Deathwing Knights, they ended up getting buffed so that there was a legit choice between weapons, so The Spears could get there. I think just making them Ap -3 probably gets them there for me, or maybe making them strength 7? They don't need to do much to make it a consideration to be made; it probably should just be "Encarmine weapons" and then have a sweep and a strike profile. With the sword getting more attacks I think you need more than just AP-3 to make the spears generally an even option. either push the S up to 7 or the D up to 3. S9 on the charge w/ lance makes them a solid threat to armor. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/383463-new-aos-models-gold-ba-releases/page/7/#findComment-6059387 Share on other sites More sharing options...
Nephaston Posted August 24, 2024 Share Posted August 24, 2024 Not a BA collector, though I do consider getting on kit (second handfrom all the inevitable patrol boxes people might buy) to surround Dante on my shelf. Which is why I don't really consider kit bashing or extra bits worth the effort, but I did consider playing around with the paint scheme a bit to break up the massive chunk of gold. Basically the idea is; instead of buying or sculpting wings, and to keep them from out-blinging humble wing-less Dante, I'll just paint a wing pattern or really feathery design on the entire pack, since surely it can't be that hard. In case it is that hard to do a feather pattern I'll probably stick with just priming them white, doing a bog simple marble texture, and either go wild with transfers, or try my hand at golden swirlies (because those are so much easier, right?) Either way, eyes will be blackened, red tears will be added, the curved mag pouch will be either relocated or cut, and I think it'll be quite passable visually. Also the upper legs do have a bit of a musculature design on them but for some reason just on the inside, while the outside retains the standard tacticus plating. INKS and Blindhamster 2 Back to top Link to comment https://bolterandchainsword.com/topic/383463-new-aos-models-gold-ba-releases/page/7/#findComment-6059455 Share on other sites More sharing options...
