hd3 Posted August 12, 2024 Share Posted August 12, 2024 I really like the citadel paints but I've noticed they gunk up and jam the lids so they don't close pretty easily. I just lost another pot to drying out when I thought the lid was closed properly. Is it worth moving these over to dropper bottles? And does anyone have any idea how much that would cost? Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/ Share on other sites More sharing options...
Firedrake Cordova Posted August 12, 2024 Share Posted August 12, 2024 For cost, it depends on where you are, I guess. Vallejo used to sell them and they were fairly expensive (£0.45 when a pot of paint was £2.30). Probably your best bet is to find ones of the same style on Amazon, e-Bay, or similar? In terms of transferring the paint to the dropper pot, the opening on the dropper bottle is narrower, so you'll either want to be careful, or see if you can get/make a little funnel (I don't know if waxes paper/card may help the paint run more smoothly?). You'll end up with some paint left in the GW pot, so it might be an idea to add a little Lahmian Medium and give it a shake, in the hopes that it'll mix and you'll end up with some runny dregs that you can just pour out. There's lots of videos on YouTube - Juan Hidalgo, Vince Venturella, Duncan, and Epic Duck all have one. Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6055885 Share on other sites More sharing options...
Terminatorinhell Posted August 12, 2024 Share Posted August 12, 2024 Yeah I've transferred mine into the dropper bottles but they gum up a little too.. Not as badly. I used cheap ones, but the tops actually crack somehow which is weird :cuss: lol. Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6055959 Share on other sites More sharing options...
Grotsmasha Posted August 12, 2024 Share Posted August 12, 2024 Before I switched to droppers, I used to pull lids off old pots before I discarded then, then clean them so I could swap them out for any gummy ones. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056036 Share on other sites More sharing options...
crimsondave Posted August 13, 2024 Share Posted August 13, 2024 I have close to as much army painter as citadel. My biggest issue with dropper bottles is when they clog up and explode and you lose 90% of your paint. Doesn’t happen often but when it does there will be f bombs galore. I just scrape my pots out after every use. I also thin them in the pot some and put ball bearings in them. It’s a pain but my pots never dry out. Like most things in the hobby it’s personal choice. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056078 Share on other sites More sharing options...
Firedrake Cordova Posted August 13, 2024 Share Posted August 13, 2024 My biggest issue with dropper bottles is when they clog up and explode and you lose 90% of your paint Aye, a painty Vesuvius is not fun. The key is to notice when there's resistance and not squeeze any harder. An old airbrush needle is really useful at lancing the clog out of the nozzle. crimsondave 1 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056112 Share on other sites More sharing options...
sbarnby71 Posted August 13, 2024 Share Posted August 13, 2024 I decanted a load of my paints 3, 4 years ago as it was the "thing to do". What I have found is similar to the bomb experience. I have added a ball-bearing and used some flow improver to help get all the paint from the old pot. Now for some colours they just clog the nozzle and I have to keep a pin handy to clear them. Other colours (Mephiston Red (base paint) and Baharroth Blue (edge paint) I shake, I remove the lid and the paint is almost fountaining out of the dropper bottle before I even turn it upside down, so I lose so much paint. I've tried a few different bottles, even gave up adding an extra like flow improver but these 2 colours just make such a massive mess and it's annoying as I use them a lot, but I only need a tiny spot each time. For the paints I use a lot of (volume of paint, not frequency), I stick with the pots and just have a session every few weeks of digging the dried paint from the rim of the lid. One word of caution, don't be too aggressive as you can damage the rim and that makes the seal worse and you end up with more paint getting in the rim and cycle gets worse. Another thing I do is try and let the lid drip into the pot for a while after use so less paint is hanging around that funnel thingy in the lid. I'd say which ever way you go, expect to lose a fair bit of paint due to clean-up, which is better than losing half a pot because it dried up because the lids are rubbish. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056123 Share on other sites More sharing options...
DemonGSides Posted August 13, 2024 Share Posted August 13, 2024 I really like the citadel paints but I've noticed they gunk up and jam the lids so they don't close pretty easily. I just lost another pot to drying out when I thought the lid was closed properly. Is it worth moving these over to dropper bottles? And does anyone have any idea how much that would cost? I transferred all of mine this spring and it was the best decision I ever made. Amazon has the funnels and the bottles and get a container of AK's stainless steel balls. Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056195 Share on other sites More sharing options...
Spaced Hulk Posted August 13, 2024 Share Posted August 13, 2024 There is actually a fairly quick and easy way to 'de-gunk' Citadel paint lids. Basically take the lid completely off the pot (obviously including the O-ring that holds it in place) and then turn it inside out. It takes a little bit of force but the flexible plastic of the lid can be twisted in this way. The dried paint then comes off really easily and you can simply reattach the lid and it's good to go. I've found this a real game changer with Citadel paints and I'm surprised it's not more widely known. If I was GW I'd probably put a tutorial on YouTube about it (although that would mean admitting that it's a problem in the first place! ). Cleon, crimsondave, Firedrake Cordova and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056266 Share on other sites More sharing options...
Bryan Blaire Posted August 14, 2024 Share Posted August 14, 2024 (edited) I purchased a 40 pack of 1 oz HDPE squeeze bottles with screw cap droppers similar to the ProAcryl ones (super easy to clean if needed, but never gotten one clogged) and using stainless steel bearings to agitate with - the size allows two full pots of Citadel paint to fit inside the bottle with about 5 ml of a flow improver + thinner mix I used to clean out the pots as best I could in each during the transfer. To move the paint over, I actually got metal frosting piping tips (medium to large sizes) and tipped the pots over into those to drain down (did have to hold them while they drained) - those were much easier to clean than anything else funnel-wise and I didn’t have to throw a bunch of paper/plastic away. You can also peel the label off the pots and stick it to the bottles easily. It was the last bit of GW paint I’ve bought - I still use them, they are still just as fresh three years later and mix up every time I need to use them (which isn’t as much lately because I have other paint lines I like to use more now). Edited August 14, 2024 by Bryan Blaire Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056418 Share on other sites More sharing options...
sbarnby71 Posted August 14, 2024 Share Posted August 14, 2024 (edited) There is actually a fairly quick and easy way to 'de-gunk' Citadel paint lids. Basically take the lid completely off the pot (obviously including the O-ring that holds it in place) and then turn it inside out. It takes a little bit of force but the flexible plastic of the lid can be twisted in this way. The dried paint then comes off really easily and you can simply reattach the lid and it's good to go. I've found this a real game changer with Citadel paints and I'm surprised it's not more widely known. If I was GW I'd probably put a tutorial on YouTube about it (although that would mean admitting that it's a problem in the first place! ). I've never thought to try that! Going to give it a try later today. Edited August 14, 2024 by sbarnby71 grammer Spaced Hulk 1 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056454 Share on other sites More sharing options...
Cleon Posted August 14, 2024 Share Posted August 14, 2024 There is actually a fairly quick and easy way to 'de-gunk' Citadel paint lids. Basically take the lid completely off the pot (obviously including the O-ring that holds it in place) and then turn it inside out. It takes a little bit of force but the flexible plastic of the lid can be twisted in this way. The dried paint then comes off really easily and you can simply reattach the lid and it's good to go. I've found this a real game changer with Citadel paints and I'm surprised it's not more widely known. If I was GW I'd probably put a tutorial on YouTube about it (although that would mean admitting that it's a problem in the first place! ). Whuuut, why did no one tell me this years ago, I just tried it you paint wizard. Spaced Hulk and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056457 Share on other sites More sharing options...
crimsondave Posted August 14, 2024 Share Posted August 14, 2024 There is actually a fairly quick and easy way to 'de-gunk' Citadel paint lids. Basically take the lid completely off the pot (obviously including the O-ring that holds it in place) and then turn it inside out. It takes a little bit of force but the flexible plastic of the lid can be twisted in this way. The dried paint then comes off really easily and you can simply reattach the lid and it's good to go. I've found this a real game changer with Citadel paints and I'm surprised it's not more widely known. If I was GW I'd probably put a tutorial on YouTube about it (although that would mean admitting that it's a problem in the first place! ). Dude. If this works, you’re a legend. I’m trying it today. For ball bearings, I use these because they’re cheap and I have lots of paint. https://www.amazon.com/gp/aw/d/B0BJ2DVNPV?psc=1&ref=ppx_pop_mob_b_asin_title Firedrake Cordova and Spaced Hulk 2 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056498 Share on other sites More sharing options...
sbarnby71 Posted August 14, 2024 Share Posted August 14, 2024 It works!!! How have I missed this! One cavet, if you have the older black lids they are not as flexible so take a lot more bending. I just cleared out 4 pots in seconds using this. And agree on the ball bearings, just buy generic ones from Amazon, no need for specialist ones. Spaced Hulk and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056607 Share on other sites More sharing options...
crimsondave Posted August 14, 2024 Share Posted August 14, 2024 It works!!! How have I missed this! One cavet, if you have the older black lids they are not as flexible so take a lot more bending. I just cleared out 4 pots in seconds using this. And agree on the ball bearings, just buy generic ones from Amazon, no need for specialist ones. It sure does work. I just tried it too. No idea how I haven’t figured this out after all these years. This needs to be a sticky or something. Spaced Hulk, Oxydo and Firedrake Cordova 3 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056675 Share on other sites More sharing options...
Firedrake Cordova Posted August 15, 2024 Share Posted August 15, 2024 (edited) This needs to be a sticky or something. I'm working on something - I'll add it to that Edited August 15, 2024 by Firedrake Cordova crimsondave 1 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056741 Share on other sites More sharing options...
sbarnby71 Posted August 15, 2024 Share Posted August 15, 2024 I'm going to add an extra step if I may, put the lids in some warm water to help soften the lid a bit (don't use boiling water as the lid could warp). I know it's an extra step but it also removes any wet paint that splatters all over you if the lid snaps back as you try and turn it inside out. Yep I got a blue glaze paint over my nice clean grey t-shirt from that. Firedrake Cordova and crimsondave 2 Back to top Link to comment https://bolterandchainsword.com/topic/383464-citadel-paint-pot-problems/#findComment-6056747 Share on other sites More sharing options...
