The Neverborn Posted August 22, 2024 Share Posted August 22, 2024 I believe these guys have a rule that states something along the line of "enemy units may not be se up with 12" from reserves. A Number of armies have ways access to a way of setting up within 6" or 3" of enemy models. Is there an official answer on which one supersedes the other? Link to comment https://bolterandchainsword.com/topic/383581-infiltrator-squad-omni-scramblers/ Share on other sites More sharing options...
The Neverborn Posted August 22, 2024 Author Share Posted August 22, 2024 Promise I did read stuff before i posted this. Five minutes later i read this. Reinforcement Priority While setting up Reinforcement units, you will occasionally find that two rules cannot both apply – for example, when a unit is arriving using the Deep Strike ability (which allows it to be set up anywhere on the battlefield that is more than 9" away from all enemy units) but an enemy unit has a rule that prevents enemy Reinforcement units from being set up within 12". In such cases, rules limiting the placement of Reinforcement units take priority over rules that state where Reinforcement units can be placed. Page 26 https://www.warhammer-community.com/wp-content/uploads/2023/06/bQTWEw8T9k5dy4Eq.pdf Admins feel free to lock/delete this post. Karhedron, Xenith, DemonGSides and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/383581-infiltrator-squad-omni-scramblers/#findComment-6059031 Share on other sites More sharing options...
Dr_Ruminahui Posted August 22, 2024 Share Posted August 22, 2024 Despite you providing the answer to yourself, its a worthwhile question with a quality answer, so leaving it "as is" is fine. Link to comment https://bolterandchainsword.com/topic/383581-infiltrator-squad-omni-scramblers/#findComment-6059121 Share on other sites More sharing options...
Xenith Posted August 23, 2024 Share Posted August 23, 2024 Good find on the ruling. It's a bit abstract, but the 'special' rule taking precedence over the 'general' rule also comes to that answer - the special rule allowing 3" takes precedence over the 9" normal distance, however that rule can be used in any game, with and against other units, with the extreme exception of the infiltrators, one unit that you can't deploy within 12" of. vague and messy I know! Link to comment https://bolterandchainsword.com/topic/383581-infiltrator-squad-omni-scramblers/#findComment-6059236 Share on other sites More sharing options...
Lord_Ikka Posted August 23, 2024 Share Posted August 23, 2024 There's a couple of units like that- one that you might see now is a Navigator from the Imperial Agents codex taken with any Imperium army. For 75 points you get a 12" denial zone plus the possibility of doing mortal wounds to enemies in the Shooting Phase. A fairly cheap rear objective holder who won't really be wasted just sitting in the backfield. DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/383581-infiltrator-squad-omni-scramblers/#findComment-6059240 Share on other sites More sharing options...
