Deschenus Maximus Posted August 29, 2024 Share Posted August 29, 2024 Over 9,000 on an Epic 30k site. Mind sharing which site that is? Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6060889 Share on other sites More sharing options...
Interrogator Stobz Posted August 29, 2024 Share Posted August 29, 2024 No worries, my link-fu is weak, but it's called: EPIC 30k Legions Imperialis Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6061097 Share on other sites More sharing options...
Deschenus Maximus Posted August 30, 2024 Share Posted August 30, 2024 No worries, my link-fu is weak, but it's called: EPIC 30k Legions Imperialis That's the name of the site with the forum? Or the FB group? Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6061165 Share on other sites More sharing options...
DuskRaider Posted August 30, 2024 Share Posted August 30, 2024 Here’s the FB Groups I’m in: Legions Imperialis Epic Battles in the 31st Millennium Epic 30K Legions Imperialis And the Subreddit: r/LegionsImperialis I think I remember an Epic 30K site a while back that I joined, but I never really participated and that was years ago when I was buying up Forumware models for my Titanicus bases and whatnot. Marshal Rohr, vadersson, Deschenus Maximus and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6061170 Share on other sites More sharing options...
Interrogator Stobz Posted August 30, 2024 Share Posted August 30, 2024 That's the name of the site with the forum? Or the FB group? What Dusk just shared Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6061233 Share on other sites More sharing options...
d503 Posted September 2, 2024 Share Posted September 2, 2024 (edited) Can units with skyfire split fire like point defence? Use the Acastus knight as an example. Can I shoot the magma lascannons at a land target, and shoot the skyfire missiles at a separate air target? Please clarify how the flamer templates interact with buildings Also, please FAQ all superheavy tanks to have 3 wounds, without changing the points cost. The game really needs baneblades(etc) to not suck. It's okay if Malcadors suck, they look like they should suck. Edited September 2, 2024 by d503 Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6061850 Share on other sites More sharing options...
Crablezworth Posted September 2, 2024 Share Posted September 2, 2024 Can units with skyfire split fire like point defence? Use the Acastus knight as an example. Can I shoot the magma lascannons at a land target, and shoot the skyfire missiles at a separate air target? Please clarify how the flamer templates interact with buildings Also, please FAQ all superheavy tanks to have 3 wounds, without changing the points cost. The game really needs baneblades(etc) to not suck. It's okay if Malcadors suck, they look like they should suck. For skyfire yes but the 2nd target has to be a flyer Yeah they should clarify templates and structures, this is the current understanding of it: Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6061915 Share on other sites More sharing options...
Deschenus Maximus Posted September 3, 2024 Share Posted September 3, 2024 Can units with skyfire split fire like point defence? Use the Acastus knight as an example. Can I shoot the magma lascannons at a land target, and shoot the skyfire missiles at a separate air target? No, they can’t. The paragraph in the Point Defence special rule that allows for that is not in the Skyfire rules. Consequently, if you shoot at a Flyer secondary target, you must do so with all your guns. This might be an unintentional oversight but currently, that’s the RAW answer. Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6061949 Share on other sites More sharing options...
Crablezworth Posted September 3, 2024 Share Posted September 3, 2024 No, they can’t. The paragraph in the Point Defence special rule that allows for that is not in the Skyfire rules. Consequently, if you shoot at a Flyer secondary target, you must do so with all your guns. This might be an unintentional oversight but currently, that’s the RAW answer. "Models with at least one weapon with the Skyfire trait may choose to fire on its Detachment's target or a Secondary Target; a Secondary Target is an eligible target (i.e., within range and line of sight of the firing model) different from the first chosen target. The Secondary Target must be a model with the Flyer special rule. All firing Skyfire weapons must target the same Flyer Detachment, unless another rule overrides this." You can split fire if the target is a flyer Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062015 Share on other sites More sharing options...
Deschenus Maximus Posted September 3, 2024 Share Posted September 3, 2024 "Models with at least one weapon with the Skyfire trait may choose to fire on its Detachment's target or a Secondary Target; a Secondary Target is an eligible target (i.e., within range and line of sight of the firing model) different from the first chosen target. The Secondary Target must be a model with the Flyer special rule. All firing Skyfire weapons must target the same Flyer Detachment, unless another rule overrides this." You can split fire if the target is a flyer Yes, the whole model can split fire from the rest of the Detachment, but if it chooses to do so, it must do so with all its weapons, not just those with Skyfire. Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062023 Share on other sites More sharing options...
Crablezworth Posted September 3, 2024 Share Posted September 3, 2024 (edited) Yes, the whole model can split fire from the rest of the Detachment, but if it chooses to do so, it must do so with all its weapons, not just those with Skyfire. It just say all skyfire weapons, meaning it all needs to be the same flyer detachment. "All firing Skyfire weapons must target the same Flyer Detachment, unless another rule overrides this." All weapons with skyfire that are firing must do so at the same flyer detachment, they can't target a flyer each. "all firing skyfire weapons" all isn't referring to the model here, it's referring to the firing skyfire weapons. so using a deredeo detachment, they could fire their main guns at a nearby detachment but splitfire with their missiles at a nearby flyer detachment. Edited September 3, 2024 by Crablezworth Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062035 Share on other sites More sharing options...
apologist Posted September 3, 2024 Share Posted September 3, 2024 Quick one for FAQ: As written, the Cyclops Demolition Vehicle can't hurt infantry in buildings (as the hole in the template is placed over the Cyclops; but to affect the building, the hole needs to be over it). Is this correct? Mandragola 1 Back to top Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062037 Share on other sites More sharing options...
Crablezworth Posted September 3, 2024 Share Posted September 3, 2024 Quick one for FAQ: As written, the Cyclops Demolition Vehicle can't hurt infantry in buildings (as the hole in the template is placed over the Cyclops; but to affect the building, the hole needs to be over it). Is this correct? Yes, and even if one writes it to allow it to just touch, it needs permission to do so like with wrecker. On top of that, they currently can break their own formations as nothing exempts them from break point. Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062039 Share on other sites More sharing options...
Deschenus Maximus Posted September 3, 2024 Share Posted September 3, 2024 It just say all skyfire weapons, meaning it all needs to be the same flyer detachment. That bit of the paragraph (the last sentence you quoted) is there to prevent 1) designating a Flyer Detachment as the Primary Target and another Flyer Detachment as the Secondary Target 2) disallow a weapon that has both PD and Skyfire (like the Marauder's heavy bolters) to shoot at yet another Flyer Detachment. The Skyfire rule doesn't have this bit of that is present in the Point Defence rule and that enables just the PD weapons (rather than the whole model with all its guns) to be fired at the Secondary Target (sorry for the crappy quality of the pic): If PD didn't have that paragraph, PD weapons would necessitate that the model bearing them fire ALL its guns at the Secondary Target rather than just the PD weapons. Oxydo 1 Back to top Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062046 Share on other sites More sharing options...
Crablezworth Posted September 3, 2024 Share Posted September 3, 2024 I'm not seeing what prevents deredeos from splitting fire into a secondary target that is a flyer with only their skyfire weapons And there are pd weapoons with skyfire but no light at that aren't even able to currently target flyers as we know all the marine flyer heavy bolters currently have that problem Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062085 Share on other sites More sharing options...
Deschenus Maximus Posted September 3, 2024 Share Posted September 3, 2024 I'm not seeing what prevents deredeos from splitting fire into a secondary target that is a flyer with only their skyfire weapons Where does it say they can do that? I’m happy to be proven wrong but reading and rereading the Skyfire rule, it doesn’t actually say anywhere that they can do that. Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062092 Share on other sites More sharing options...
Crablezworth Posted September 3, 2024 Share Posted September 3, 2024 Where does it say they can do that? I’m happy to be proven wrong but reading and rereading the Skyfire rule, it doesn’t actually say anywhere that they can do that. "Models with at least one weapon with the Skyfire trait may choose to fire on its Detachment's target or a Secondary Target; a Secondary Target is an eligible target (i.e., within range and line of sight of the firing model) different from the first chosen target. The Secondary Target must be a model with the Flyer special rule. All firing Skyfire weapons must target the same Flyer Detachment, unless another rule overrides this." if it said all models I'd agree with you, but its not clear at all. The first sentence allows for the the possibility that you're firing all weapons at a flyer detachment to begin with and wish to split fire at a second flyer detachment, for example, with only the skyfire weapons. Where is that prevented exactly? If deredeos shoot all their guns including their skyfire into only one detachment of flyers they've fulfiffled all requirements, if they split fire with just their skyfire weapons at second flyer detachment they've fulfilled all requirements. Again the way the last sentence is worded it could be referring to all models that are firing weapons with the skyfire trait, it could also be referring to the weapons themselves firing and having the skyfire trait. Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062096 Share on other sites More sharing options...
Deschenus Maximus Posted September 3, 2024 Share Posted September 3, 2024 (edited) The first sentence doesnt allow for that, though. That’s the thing I’m saying. The sentence would need to read “A model with Skyfire weapons may fire THEM (referring to the Skyfire weapons) at the Detachemnt’s target or a secondary target” Since the THEM is missing, the first sentence allows the model to shoot at a different target but as the base shooting rules state, “Unless instructed otherwise, a given model must fire all of its weapons that it chose to fire at the same target.” So since there is nothing in the Skyfire rule that explicitly states that you can split your Skyfire weapons fire off, you are bound by the base rule for shooting. Edited September 3, 2024 by Deschenus Maximus Oxydo and vadersson 2 Back to top Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062100 Share on other sites More sharing options...
SkimaskMohawk Posted September 3, 2024 Share Posted September 3, 2024 Raw ya, there's no explicit permission to split weapons or models into secondary targets. But it's also obvious that they wrote a lot of the rules like :cuss:. The titan permission to split fire uses different terminology from the point defence permission. The secondary target stuff is actually never referenced further in any of the three as some sort of mechanical interaction. Its clear that it was a part that was never fully fleshed out and just forgotten about, but it clearly was meant to enable split fire in skyfire, otherwise it's completely superfluous; it lets you shoot something else in range and los from what you just decided to shoot that was in range and los lol. Doesn't hurt to throw it in the faq pile. apologist 1 Back to top Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062111 Share on other sites More sharing options...
Deschenus Maximus Posted September 3, 2024 Share Posted September 3, 2024 Yeah it very well may be that they just forgot to add some text. I am happy with either outcome if they do FAQ it. Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062113 Share on other sites More sharing options...
Crablezworth Posted September 3, 2024 Share Posted September 3, 2024 (edited) Well all weapons on a deredeo on first fire order gain tracking array, which gives all its weapons skyfire, I think it's a pretty silly argument to say the only weapon that can actually splitfire in the case of 2 flyer detachments in range is the 8 inch ranged sarcophqagus mounted weapons because they have pd even though they like marine flyer bolters are light and can't even target fltyers. I'd simply saythat rules as intended I think it's pretty clear. RAW eats itself. And it's not exactly a consistent book or rule set. Edited September 3, 2024 by Crablezworth Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062129 Share on other sites More sharing options...
SkimaskMohawk Posted September 3, 2024 Share Posted September 3, 2024 Its silly for sure, but worth of throwing into a faq compilation to get smoothed out if the opportunity presents itself. Far more worthy than something like "does the predator sponson really only get 1 shot?". apologist 1 Back to top Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062149 Share on other sites More sharing options...
Crablezworth Posted September 4, 2024 Share Posted September 4, 2024 Its silly for sure, but worth of throwing into a faq compilation to get smoothed out if the opportunity presents itself. Far more worthy than something like "does the predator sponson really only get 1 shot?". For sure, it's right up there too with marine flyer's bolters finally getting light at like aux Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062158 Share on other sites More sharing options...
Deschenus Maximus Posted September 4, 2024 Share Posted September 4, 2024 @Mandragola Another one I just remembered: The Raven Guard legion trait states that Infantry with Dedicated Transports gain Forward Deployment instead of Infiltrate. Clearly, the intent is for such Detachments to be able to use Forward Deployment while embarked on their Transports. Problem is, the Forward Deployment rule doesn't state that a Detachment with said rule transfers it to their Dedicated Transport. So if the RG infantry start the game embarked on their Rhinos, they can't Forward Deploy. The FAQ just needs to add a sentence to the Forward Deployment rule that states something like "If an Infantry Detachment with this Special Rule has Dedicated Transports, said Dedicated Transports gain the Forward Detachment Special Rule also; however, an Infantry Detachment may not Disembark from its Dedicated Transports until the first Round of the game if said Transports perform a Forward Deployment move." Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062282 Share on other sites More sharing options...
apologist Posted September 4, 2024 Share Posted September 4, 2024 Its silly for sure, but worth of throwing into a faq compilation to get smoothed out if the opportunity presents itself. Far more worthy than something like "does the predator sponson really only get 1 shot?". For the record, I think I listed this earlier – not because I think the answer's unclear, but simply because I've seen so many people ask about it that it's very much a Frequently Asked Question! :) Mandragola 1 Back to top Link to comment https://bolterandchainsword.com/topic/383696-li-faq/page/2/#findComment-6062291 Share on other sites More sharing options...
