INKS Posted September 13, 2024 Share Posted September 13, 2024 Since I sort of see them as miners, I want a mine themed base but I am coming up empty. No idea what to do. Any ideas out there? how do you base your guys? Link to comment https://bolterandchainsword.com/topic/383977-bases/ Share on other sites More sharing options...
Solution Karhedron Posted September 13, 2024 Solution Share Posted September 13, 2024 For a mining theme, I would start out with rocky bases. You can either decorate the normal warhammer bases or buy some specially made ones like the ones below. The next thing I would do would be to add some minerals to the bases that the Votann might be mining. Lots of people put tufts of grass or greenery on their bases but you could use gems or precious metals instead. There are lots of ways you could so this. The easiest way would be to get some fine gravel or coarse sand and spray it with cheap gold paint. Then stick a few pieces to each base once the models are on to represent nuggets or ores of precious metals. If you want something a bit more dramatic, you could try adding crystals to the base. You can buy cheap decorative crystals in all sort of places but the ones below are a cool example and other colours are available. This would give a very Deep Rock Galactic feel (Rock and Stone!). INKS, Focslain and W.A.Rorie 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/383977-bases/#findComment-6064347 Share on other sites More sharing options...
W.A.Rorie Posted September 13, 2024 Share Posted September 13, 2024 I second the gems INKS 1 Back to top Link to comment https://bolterandchainsword.com/topic/383977-bases/#findComment-6064372 Share on other sites More sharing options...
