calgar101 Posted September 18, 2024 Share Posted September 18, 2024 (edited) The humble Artillery piece has long gone, I was always a fan of it but shamefully never bought one. I'm going to be adding more tanks to my Guard army and want some Griffon mortars, I'm just unsure the best way to convert some. I've looked at some images and was thinking of buying a Basilisk and cutting down the gun barrel to a stub. Would leave the gun shield off too and have the top of the tank as open as possible. Not sure if this is possible or should use different gun parts? Any help/guidance is appreciated thank you. Edited September 18, 2024 by calgar101 Add picture. Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/ Share on other sites More sharing options...
Solution Dr. Clock Posted September 18, 2024 Solution Share Posted September 18, 2024 Can confirm - leaving/cutting off the forward half of an earthshaker still looks fine. I picked up 2 earthshaker cannons as 'emplacements' 2nd hand years ago and only 1 had a full length barrel. I use them slapped on a Necromunda Ridgehauler and trailer as gun carriages, and they work well for that. Today's earthshaker stats are also not so substantial that a reduction in barrel length will draw too much notice from opponents. It's the Guard - variation is expected! Cheers, The Good Doctor. calgar101 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065294 Share on other sites More sharing options...
calgar101 Posted September 18, 2024 Author Share Posted September 18, 2024 Can confirm - leaving/cutting off the forward half of an earthshaker still looks fine. I picked up 2 earthshaker cannons as 'emplacements' 2nd hand years ago and only 1 had a full length barrel. I use them slapped on a Necromunda Ridgehauler and trailer as gun carriages, and they work well for that. Today's earthshaker stats are also not so substantial that a reduction in barrel length will draw too much notice from opponents. It's the Guard - variation is expected! Cheers, The Good Doctor. Thank you for your reply, any pictures of your conversion? It sounds good; I've wanted to use a Ridgehauler for something. I'm not bothered on stats, I haven't played since 7th, my gaming circle are looking at 3rd/4th edition. Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065296 Share on other sites More sharing options...
LameBeard Posted September 18, 2024 Share Posted September 18, 2024 I’m surprised Blood & Skulls Industry doesn’t do a conversion kit, but maybe there is an stl out there? Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065307 Share on other sites More sharing options...
DemonGSides Posted September 19, 2024 Share Posted September 19, 2024 I like the 30k basilisk; it also comes with a Medusa short barrelled mortar so might accomplish what you're looking for. LameBeard and Dr. Clock 2 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065337 Share on other sites More sharing options...
calgar101 Posted September 19, 2024 Author Share Posted September 19, 2024 @LameBeard I haven't looked into 3d printing side of things, probably some gun piece out there. @DemonGSides I was thinking the same when I was looking at that kit last night. Might have to try make a version from the 30k and 40k kit. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065347 Share on other sites More sharing options...
LameBeard Posted September 19, 2024 Share Posted September 19, 2024 Maybe something from https://mortian.shop/product/stationary-weapon-medium-gun-b-twin-mortar/?v=e5ecf956e6d6 might work? calgar101 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065351 Share on other sites More sharing options...
calgar101 Posted September 19, 2024 Author Share Posted September 19, 2024 (edited) Maybe something from https://mortian.shop/product/stationary-weapon-medium-gun-b-twin-mortar/?v=e5ecf956e6d6 might work? That looks like it could work, thank you. I'd completely forgotten about Mortian, they've expanded their range since I last looked Edited September 19, 2024 by calgar101 Add a comment. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065357 Share on other sites More sharing options...
AutumnEffect Posted September 19, 2024 Share Posted September 19, 2024 (edited) Check out this conversion guide:https://theforgefloor.wordpress.com/2011/07/28/converting-an-imperial-guard-griffon-heavy-mortar/ I'm just not sure what the 'road wheels' sprue/bit that they used for the barrel came from, but it does add a lot to the conversion, pulling off a bit of length and width to the barrel. Edited September 19, 2024 by AutumnEffect Dr. Clock, calgar101 and LameBeard 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065360 Share on other sites More sharing options...
calgar101 Posted September 19, 2024 Author Share Posted September 19, 2024 Check out this conversion guide:https://theforgefloor.wordpress.com/2011/07/28/converting-an-imperial-guard-griffon-heavy-mortar/ I'm just not sure what the 'road wheels' sprue/bit that they used for the barrel came from, but it does add a lot to the conversion, pulling off a bit of length and width to the barrel. That looks awesome, thank you for posting. Not sure if the vehicles come with that road wheel sprue now but, I've a few spare barrels from guns that would make it look suitable. AutumnEffect 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065363 Share on other sites More sharing options...
DemonGSides Posted September 19, 2024 Share Posted September 19, 2024 @LameBeard I haven't looked into 3d printing side of things, probably some gun piece out there. @DemonGSides I was thinking the same when I was looking at that kit last night. Might have to try make a version from the 30k and 40k kit. I'm relatively new to the Guard and refuse to buy anything from GW directly, so I leaned on the new 30k Basilisks to give me that ranged punch. I also like that they're in the Leman Russ chassis, as it makes my force look a bit more unified. calgar101 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065381 Share on other sites More sharing options...
Orion Posted September 19, 2024 Share Posted September 19, 2024 (edited) The humble Artillery piece has long gone, I was always a fan of it but shamefully never bought one. I'm going to be adding more tanks to my Guard army and want some Griffon mortars, I'm just unsure the best way to convert some. I've looked at some images and was thinking of buying a Basilisk and cutting down the gun barrel to a stub. Would leave the gun shield off too and have the top of the tank as open as possible. Not sure if this is possible or should use different gun parts? Any help/guidance is appreciated thank you. The Imperial Heavy Mortar pictured in the conversion above is actually available (or was, when in stock) as a separate field gun for Krieg. And it's the same one they used on the Vanaheim pattern griffon. Nice looking tank self propelled artillery. Edited September 19, 2024 by Orion calgar101 and LameBeard 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065384 Share on other sites More sharing options...
Inquisitor_Lensoven Posted September 19, 2024 Share Posted September 19, 2024 The humble Artillery piece has long gone, I was always a fan of it but shamefully never bought one. I'm going to be adding more tanks to my Guard army and want some Griffon mortars, I'm just unsure the best way to convert some. I've looked at some images and was thinking of buying a Basilisk and cutting down the gun barrel to a stub. Would leave the gun shield off too and have the top of the tank as open as possible. Not sure if this is possible or should use different gun parts? Any help/guidance is appreciated thank you. A long time ago I used a rhino, and tossed and empire mortar on the roof, then IG track guards to make look more like an actual thing than just a rhino with a mortar on the roof calgar101 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065403 Share on other sites More sharing options...
Tallarn Commander Posted September 19, 2024 Share Posted September 19, 2024 I look forward to seeing your Griffon when it's done. It looks like folks have presented you with many good options. The Griffon was the first tank I painted up for 40K. That was 24 years ago. Now my Tallarns have 17 tanks. SteveAntilles and calgar101 2 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065418 Share on other sites More sharing options...
Dr. Clock Posted September 19, 2024 Share Posted September 19, 2024 No pics on my phone and the items in question are at a friend's house just now. I'll take a pic this weekend if I remember. Calling mine a 'conversion' is ambitious - I haven't glued the guns to the chassis or anything, but basically just plonk the assembled gun decks straight on to the 'hauler and trailer. It looks good enough, and means I can use the hauler and trailer in Necro without the cannons in the way. I'm just not sure what the 'road wheels' sprue/bit Presumably the old-old leman russ road wheels? It's definitely a cool conversion, but it'll be a nightmare to find that specific bit unless you know, or are, a Guard grognard. Still - you can probably find a different muzzle bit somewhere... maybe like a vanquisher or eradicator cannon which should be easy to find, but definitely bigger and possibly just far too big. Cheers, The Good Doctor. AutumnEffect and calgar101 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065426 Share on other sites More sharing options...
calgar101 Posted September 19, 2024 Author Share Posted September 19, 2024 Thank you all for your replies and guidance, it is very much appreciated! The route I have decided to go for now is as follows; Use a 40k Basilisk, cut the Earthshaker cannon down and use an Eradicator barrel to finish the end off to create that 'Heavy mortar' gun. I'll be leaving the gun shield off and the Artillery piece will look quite 'open topped'. If that does not look right then I will use the weapon emplacement for the Mortian range or something similar. Once I've found a way I think looks good/suitable, I'll build 3 and later expand to a company. Looking at the Mortian range, they have a plasma cannon weapon emplacement... perhaps the Griffon could be improved with a plasma bombard? Once again thank you all. AutumnEffect 1 Back to top Link to comment https://bolterandchainsword.com/topic/384006-griffon-mortar-tank/#findComment-6065443 Share on other sites More sharing options...
