AutumnEffect Posted October 4, 2024 Share Posted October 4, 2024 (edited) The "other things" it does is that it has Precision. That's it. Both are horribly inefficient into regular dudes of all kinds. Hence why I said, if you're not going to use that particular trait, might as well get the Las Fusils. I didn't say they were efficient into 'regular dudes' either. I said if you're going to take Las Fusils then you might as well take a Lascannon. The Las Fusil is an overpriced weapon. Las Fusils also do have a case with the Phobos Librarian. If standing still, they give his psychic blast Devastating Wounds without needing to charge himself up, and it's just slightly more expensive than two Firestrike Turrets, which might be better offensively but are terrible defensively and have no movement. That ability isn't tied to the Fusil though. Eliminators with the Sniper Rifle do the same thing. If you really want to take Eliminators with Fusils then yeah, they will on average chip four wounds off a light vehicle (Toughness 9 3+ armor) profile a turn. If that's something that's worth 85 points to you then feel free, but they are going to underperform in that role compared to any other unit armed with a peer weapon that Space Marines have access to. Things you could also spend those 85 points to take. Edited October 4, 2024 by AutumnEffect DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6068519 Share on other sites More sharing options...
Inquisitor_Lensoven Posted October 4, 2024 Author Share Posted October 4, 2024 Personally, I can think of one, very non-primaris shaped reason why someone might just not take the unit with a Lascannon. That said, the Las-Fusils aren't really AT weapons anyway, they're Anti-TEQ weapons. and if you don't need Anti-TEQ, then just take the Bolt Sniper Rifles. On another note, If you stick a Phobos Libby to the Eliminator Squad, is the unit still able to "Shoot and Scoot" using the Carbine? D6 damage and AP-3 seems like a bad choice for anti-TEQ… bolt version seems like it does that much better considering it still wounds them on a 4, has just enough AP to activate the invulnerable save, and enough flat damage to kill one outright if they fail their save. compared to the las option that has a 32% chance of leaving the target alive if they fail their save. Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6068573 Share on other sites More sharing options...
Indy Techwisp Posted October 4, 2024 Share Posted October 4, 2024 D6 damage and AP-3 seems like a bad choice for anti-TEQ… bolt version seems like it does that much better considering it still wounds them on a 4, has just enough AP to activate the invulnerable save, and enough flat damage to kill one outright if they fail their save. compared to the las option that has a 32% chance of leaving the target alive if they fail their save. Fair point on the flat damage, I'd not really taken that into consideration Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6068586 Share on other sites More sharing options...
Inquisitor_Lensoven Posted October 7, 2024 Author Share Posted October 7, 2024 (edited) Fair point on the flat damage, I'd not really taken that into consideration The fusils just seem like their niche is harassing light-medium armor or small monsters and hoping for 3 or higher on the damage roll. A sort of you either ignore them, and give them the opportunity to a lot of damage over the course of a game, or you likely spend way too much time shooting at them as they’ll likely be in cover, so -1 to hit, and -1 AP. also just thought about the fact infiltrate gives them a solid opportunity to set up nice and high from the start possibly giving them an extra AP when they shoot meaning most things won’t be getting an armor save even in cover and a lot of stuff will still only be saving on a 5+ unless they have an invuln Edited October 7, 2024 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6069180 Share on other sites More sharing options...
CatchyUsername715 Posted October 21, 2024 Share Posted October 21, 2024 Very fun to use the mortis round as an anti-tank weapon. Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6072194 Share on other sites More sharing options...
Inquisitor_Lensoven Posted October 21, 2024 Author Share Posted October 21, 2024 34 minutes ago, CatchyUsername715 said: Very fun to use the mortis round as an anti-tank weapon. Are you not playing 10th edition? Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6072208 Share on other sites More sharing options...
Indy Techwisp Posted October 21, 2024 Share Posted October 21, 2024 1 hour ago, CatchyUsername715 said: Very fun to use the mortis round as an anti-tank weapon. In 10th Ed Eliminators have either a Bolt Sniper Rifle or a Las-Fusil. The only way in a currently active game for an Eliminator to have other Ammo types iirc is Killteam 24, and there's no Tanks in that. Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6072216 Share on other sites More sharing options...
Inquisitor_Lensoven Posted October 22, 2024 Author Share Posted October 22, 2024 The arms of two my eliminators don’t line up, anyone else have this issue? Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6072306 Share on other sites More sharing options...
TheArtilleryman Posted October 22, 2024 Share Posted October 22, 2024 3 hours ago, Inquisitor_Lensoven said: The arms of two my eliminators don’t line up, anyone else have this issue? The obvious suggestion is to try swapping them over in case you got them mixed up, but that seems too obvious. Another possibility is that the one you already built (if you have done) has arms on it that belong to one of the other two, which you managed to get to fit, but that now means the others are messed up. Cenobite Terminator 1 Back to top Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6072316 Share on other sites More sharing options...
Lord_Ikka Posted October 22, 2024 Share Posted October 22, 2024 Luckily Eliminators are stealthy, sneaky boys, so if something doesn't fit just right you can always do something like gap-filling the parts to look like ghillie suit/camo cloak wrapping. Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6072318 Share on other sites More sharing options...
Inquisitor_Lensoven Posted October 22, 2024 Author Share Posted October 22, 2024 16 hours ago, Lord_Ikka said: Luckily Eliminators are stealthy, sneaky boys, so if something doesn't fit just right you can always do something like gap-filling the parts to look like ghillie suit/camo cloak wrapping. It’s not too noticeable, but I was just curious if it was a known or regular issue with the kit. Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6072469 Share on other sites More sharing options...
Tacitus Posted December 8, 2024 Share Posted December 8, 2024 On 10/2/2024 at 5:11 AM, DemonGSides said: I think the las fusil are meh and there's so many better options for the shooting you're looking for, especially without having three of them. If I went las fusil I would consider grabbing a phobos librarian as well, that way they basically become an unassailable turret that can sit and plink out 2+ last shots with devastating wounds, 3 a turn. I think they got butchered after they got knocked down to 3man only squad. Previously I liked them for Headhunting, but I mostly play against necrons and they win or lose based on their leader benefits (or did). Pretty much here. 3 and only 3 units are very rarely worth it. They just don't have enough bodies to do what they need to do with a D6 randomization. When Scout Sniper Squads were still a thing I'd take that before I took a sniper Eliminator unit. 10 generic sniper rifles were better than 3 slightly better ones. Swapping to significantly (more than slightly less than majorly) worse lascanon doesn't improve things. 6 S9 vs 4 S12 (Devs) for almost the same cost is pretty meh. Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6079783 Share on other sites More sharing options...
Inquisitor_Lensoven Posted December 12, 2024 Author Share Posted December 12, 2024 Just thinking that las fusil eliminators fill the AT role much better now with the OoM buff Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6080768 Share on other sites More sharing options...
Karhedron Posted December 12, 2024 Share Posted December 12, 2024 27 minutes ago, Inquisitor_Lensoven said: Just thinking that las fusil eliminators fill the AT role much better now with the OoM buff While this is true, traditional lascannons also get the +1 to Wound so I don't think this actually changes anything. A rising tide floats all boats. DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6080774 Share on other sites More sharing options...
Galron Posted December 12, 2024 Share Posted December 12, 2024 I guess if you arent going to use OoM for something else then yeah. I'd still rather have 4 devastators with lascannons though. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6080775 Share on other sites More sharing options...
Inquisitor_Lensoven Posted December 12, 2024 Author Share Posted December 12, 2024 25 minutes ago, Karhedron said: While this is true, traditional lascannons also get the +1 to Wound so I don't think this actually changes anything. A rising tide floats all boats. It’s true, it just means more weapons that were previously borderline in the role now fit into it snuggly Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6080780 Share on other sites More sharing options...
Tacitus Posted December 13, 2024 Share Posted December 13, 2024 12 hours ago, Inquisitor_Lensoven said: Just thinking that las fusil eliminators fill the AT role much better now with the OoM buff I started to have hope when I read Eliminators get +2 shots per Bolt Rifle as long as they target the same unit. Then I saw that was Intercessors, not Eliminators, and I went back to not liking them. Link to comment https://bolterandchainsword.com/topic/384130-how-do-you-like-eliminators/page/2/#findComment-6080840 Share on other sites More sharing options...
