The Neverborn Posted October 5, 2024 Share Posted October 5, 2024 Been watching some of the Animations on WH+ the Orks don't appear to be as physically strong as I expected. It looks like men and women 1/3 their size parry blows quite regularly. I can accept that in a fight technique, timing and skill help a lot. But all the technique and timing won't help someone if they are fighting someone or something powerful enough, for example an adult raging grizzly bear. Heck given 10 metre or less engagement range a grizzly bear vs current day special forces with a standard side arm. I'm betting grizzly. So here's my question and if you can back it up with written quoted lore you get rep from me! How does the strength of : PDF, Cadian Guardsperson , Commissar, Kasrkin Compare to Ork, Nob, Warboss, Warlord And how do any of them compare to a large raging grizzy bear in raw strength. Link to comment https://bolterandchainsword.com/topic/384168-how-strong-is-an-ork/ Share on other sites More sharing options...
INKS Posted October 5, 2024 Share Posted October 5, 2024 Something to the effect of: an ork boy is typically as strong as the strongest human you would ever meet. They have unnatural strength which let's them lift and throw thing much better than a human can. They are also very sturdy and have extreme stamina so physically better at physical combat by a long shot. Bigger orks like nobs have literal gorilla strength and can tear a man apart with little effort. A warboss can have strength comparable to an elephant. SvenIronhand 1 Back to top Link to comment https://bolterandchainsword.com/topic/384168-how-strong-is-an-ork/#findComment-6068902 Share on other sites More sharing options...
Valkyrion Posted October 5, 2024 Share Posted October 5, 2024 The answer is - as strong as the story requires them to be. The Neverborn, INKS and SvenIronhand 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/384168-how-strong-is-an-ork/#findComment-6068904 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted October 6, 2024 Share Posted October 6, 2024 (edited) Maybe in W40K RPG books you can find that and extrapolate it to W40K wargame. But in my opinion the works tends to be stronger physically than a normal human. Specially if they get older. Young works can be less. Edited October 6, 2024 by Agramar_The_Luna_Wolf Link to comment https://bolterandchainsword.com/topic/384168-how-strong-is-an-ork/#findComment-6068961 Share on other sites More sharing options...
grailkeeper Posted October 6, 2024 Share Posted October 6, 2024 St 3 or 4 usually. The Neverborn 1 Back to top Link to comment https://bolterandchainsword.com/topic/384168-how-strong-is-an-ork/#findComment-6069058 Share on other sites More sharing options...
Brother Monty Posted October 8, 2024 Share Posted October 8, 2024 It all depends, in Da Gobbo’s Revenge a mek boy threw a Gretchen and almost took off a humans head, so I’d say around gorilla. Link to comment https://bolterandchainsword.com/topic/384168-how-strong-is-an-ork/#findComment-6069477 Share on other sites More sharing options...
