Wormwoods Posted October 17, 2024 Share Posted October 17, 2024 Hey all, just thought I would cut through the noise of trawling through search results, and just ask directly: How do you all do your base magnetisation? I'm over 1,000 points with my Tau, and dreading the idea of trying to transport all this big, dumb mechs. Seems as good a time as any to finally put some magnets on bases. I'll be grabbing a magnet-suitable container for them, but wanted to confirm some details before I waste money getting things I won't actually need. So! What magnet sizes should I be using? I've seen arguments for 2x2mm as a standard for infantry, or 2x1.5mm with extra filling, or 3x2 for extra grip. Has anyone had trouble with actually getting models off a sheet safely due to too strong a magnetic hold? Any guidance would be appreciated. Ta. Link to comment https://bolterandchainsword.com/topic/384281-base-magnetisation-how-big-how-many-and-how-to-fix-in-place/ Share on other sites More sharing options...
Grotsmasha Posted October 17, 2024 Share Posted October 17, 2024 For standard infantry (25mm-50mm bases) I'd recommend 3-5mm diameter by 2mm, once your hitting 60mm-90mm bases, closer to 10mm by 2mm. Once you're over 100mm bases you're looking at multiple magnets. 1 Back to top Link to comment https://bolterandchainsword.com/topic/384281-base-magnetisation-how-big-how-many-and-how-to-fix-in-place/#findComment-6071404 Share on other sites More sharing options...
Firedrake Cordova Posted October 17, 2024 Share Posted October 17, 2024 (edited) It's also worth looking at the pull-strength of the magnets - some of them are stronger than others, despite being the same size. Edited October 17, 2024 by Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384281-base-magnetisation-how-big-how-many-and-how-to-fix-in-place/#findComment-6071407 Share on other sites More sharing options...
Wormwoods Posted October 17, 2024 Author Share Posted October 17, 2024 What's the preferred attachment method? Superglue, as I've used for weapon mounts, or do I want to be using greenstuff or some other putty? Link to comment https://bolterandchainsword.com/topic/384281-base-magnetisation-how-big-how-many-and-how-to-fix-in-place/#findComment-6071410 Share on other sites More sharing options...
Grotsmasha Posted October 17, 2024 Share Posted October 17, 2024 Greenstuff if you push the magnet in against a flat surface while it still has some curing to do, you will get a perfect, flush fit that will give better attachment 1 Back to top Link to comment https://bolterandchainsword.com/topic/384281-base-magnetisation-how-big-how-many-and-how-to-fix-in-place/#findComment-6071412 Share on other sites More sharing options...
