Crablezworth Posted November 3, 2024 Share Posted November 3, 2024 6 hours ago, Mandragola said: Lots of complaints about infantry being too fast. What would happen if we had a look at the movement stats of infantry and perhaps other things? Dropping their speed to something like 3” would make a big difference, crucially making almost all weapons reach further than charge range. I think they remain as is, you just only allow double not triple move. A carve out for roads as an optional terrain rule where if they start and end entirely on a road they can 3x might help keep the change less contentious. The bigger thing for me is they should only charge their movement stat, no 10-14 inch charges. That would hopefully also incentivize assault transports more. 6 hours ago, Mandragola said: i think you would then also want to reform overwatch to only work on first fire (and perhaps point defence), as suggested. That would also help speed the game up a bit. 100% agree on overwatch only on first fire but allow it on pd still, it has worked well in massively reducing the big center scrums where it feels like every other unit is overwatching and the game just sort of disappears down a rabbit hole. Not to mention it fixes flyer interactions and lets interceptors actually do their thing. 6 hours ago, Mandragola said: I think you’d still want things like bikes and assault marine to be quite fast. I think they can stay the same, I largely just hate vehicles charging. Bikes, at least outriders, could use a tiny shred of love like furious charge as jetbikes largely outclass them. 6 hours ago, Mandragola said: im not sure what to do about walkers if we slowed infantry. Things like dreadnoughts would be a bit rubbish with only a 3” move. 4” might be ok. Walkers main thing should be that they're rarely slowed and should largely be like knights and effectively have nimble. I also think more terrain needs to slow infantry, if you want to see absurd, look up the rules for cliffs. Somehow infantry can advance up them, like navy seals can't rebel up a sheer surface while firing battle rifles one handed, its a bit silly. We've made rules for cliffs where infantry need to be on march to even climb them. And honestly some games we've just agreed they can't. But ya, walkers I think should by synonymous with being able to maneuver over difficult ground with ease compared to vehicles and other units like bikes. 6 hours ago, Mandragola said: I’m also interested in tackling activations. I’d be curious to see what happened if we activated Formations rather than Detachments. Things might get pretty messy though. Actually it would help here if only first fire detachments could overwatch. By definition they wouldn’t be moving, making it easier to track what was going on. We've moved away from even tracking breaking points and also deploy armies at once instead of alternating formations, this was done both for time and the fact that it was just too much of a deterrent to playing bigger games and tracking is just a nightmare as scale of play increases. I think activations and formations need caps. As simple formula that seems to work okay is 100pts = 1 activation/detachment so at 1500 you can have 15 detachments, 2000, 20 and so on. 3k can be a manageable game, but not if its like 40 activations on each side. There should either be a hard formation cap like max 4 formations at 2k, for example, one could even go further and limit how many of any one formation can be fielded multiple times. Some formations are guaranteed to be problems because they require so few points to field. A new example of that is the taghmata 3 tank formation, i call it that because one of the options is karacnos, which can fielded in detachments of 1 for all 40pts. So the formations has a whole buy in of 120pts, without limits, one could have an entire army of single detachment karacnos legally. This isn't a new problem, but a good example of the extremes the army construction can currently legally be taken to without any limits on formations. At 3k, you could have 75 activations in 25 formations of 3 lol. Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074258 Share on other sites More sharing options...
Crablezworth Posted November 3, 2024 Share Posted November 3, 2024 58 minutes ago, DuskRaider said: I would also say that infantry should not have the ability to assault anything larger than other infantry (or as others have suggested one scale above their own). Maybe give them the ability to purchase Melta Bombs and give them the opportunity to attack detachments two scales above their own. I think baseline infantry should largely be doing 2 things, sitting in cover or a structure near an objective, or, attacking enemy infantry in cover or in a structure. I'm tired of people thinking they're genius for spamming ogryns, even those imo should be doing one of the two things mentioned and not like tearing a apart heavy armour in combat. My thought is though if charging changes to be just infantry's movement stat, and no more triple march, I can live with them as is, but I think anything charging something larger scale should have to pass a morale test. If failed can still move their full movement stat in any direction including forward but can't actually come within an inch and thus engage. Basically, keep it at "you can try, but its way harder now". Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074260 Share on other sites More sharing options...
Crablezworth Posted November 3, 2024 Share Posted November 3, 2024 16 minutes ago, Deus_Ex_Machina said: Infantry: I have seen years ago battle reports of Dropzone Commander. Infantry without transports are moving like snails across the battlefield which makes sense considering they are supposed to be fighting in a city and not a village like it is done in 30K/40K. 20 minutes ago, Deus_Ex_Machina said: Walkers: Movement should be taken into account depending on it´s type. Siege and artillery dreadnoughts are slow by nature. A contemptor however should have still a move of 4´´. Same logic should apply to SA & Mechanicum walkers. Is it of a more cumbersome design? Then give it a low move stat. Otherwise keep it at 4´´. Well infantry aren't speed demons in real life, there's a reason modern armies are largely mechanized, but sadly the way gw's made them, transports largely sit empty and end up getting used for silly stuff like charging other vehicles. I feel like infantry should largely be static, sitting in cover holding ground. Or if attacking, largely focusing on dealing with enemy infantry, but currently they can charge basically anything and its a bit silly. I think walkers should like knights and titans largely never be slowed by difficult terrain, that should be their main thing imo. As to whether 4 or 5 inch move, I'm fine with a variety move stats for them based on how heavy or lightly armoured they look. 20 minutes ago, Deus_Ex_Machina said: First Fire & Overwatch: Only allowing Overwatch on First Fire will turn games into static affairs. Tanks should be rolling forward and shooting their point defence weapons as protection against the likes of swift bikers who may have been lurking nearby to suckerpunch them. Otherwise you will never have "Blitzkrieg" moment and be forced to play trench warfare which means the player who moves first into no man´s land loses instantly. . It would still allow for overwatch with pd, but would greatly reduce the absurdity of unlimited overwatch in a game hat might have 30-60 detachments in play. It just adds to these 2 turn games of a giant central mosh pit because everything just advanced towards each other. That's also what the current progressing round based scoring encourages as well, so it at least tempers that. Also, book 4 has a few mission that are only scored at the end of the game, those would be good examples of where a slower pace/less rush to the center sorta tempo will make help highlight how much more sense it can make in terms of game flow. 24 minutes ago, Deus_Ex_Machina said: Legion Traits: We haven´t talked about those at all yet but the overall sentiment is that some are good and others are garbage. I know that it is impossible to balance 18 traits fairly but you can at least erase those which only apply in very specific situations. The best way to do it is to give each Legion a passive perk which is active all the time. I am playing Iron Hands (big surprise!) and even their perk which doesn´t sound too bad on paper evaporates into thin air when you take into account that in order for it too work (tanks on first fire orders are harder to destroy) you have to close the gap to the opposition first in order to activate your weapons. Problem is your tanks die very fast to the opposing vanquisher tank turrets of the SA WHILE on the move. So nice try from the dev team here but it just doesn´t work. The IH perk also includes infantry making them tougher to ranged attacks but only when a medic is in the general area. Again another fine example of making a trait useless when dumping a prerequisite into the mix. Yeah balancing 18 of them is impossible, so many need work. The biggest upset was taking what should be a core game mechanic, pushing back infiltrate, and hiding it behind space wolves. They could have just made space wolves the best at doing it, but no. Total absurdity. I also at the same time don't like legion armies being able to have unlimited mixing of legions, even beyond just ruleswise, aesthetically its not great to look at armies that resemble crayons, but going back to ruleswise, it just leads to gamey silly stuff, I'd say 2 legions max in one army list. But that can be dealt with at an event level, the bigger issue is just how bad and how good some traits really are. DuskRaider and Interrogator Stobz 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074261 Share on other sites More sharing options...
Deus_Ex_Machina Posted November 3, 2024 Share Posted November 3, 2024 You could address the issues with Legion perks and mixed Legions forces by doing the following: 1. Army consists of only one SM Legion: Legion gains access to their Primary Legion perk which is a passive perk and thus active all the time. 2. Army consists of two SM Legions: Legions gain access to their Secondary Legion perk which is a lesser passive perk and thus active all the time. 3. Army consists of a maximum of three different Legions (inspired by Shattered Legions rules from HH 2.0): Legions gain access to their Tertiary Legion perk which is situational and thus has very little impact upon the game. vadersson, Interrogator Stobz and DuskRaider 3 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074263 Share on other sites More sharing options...
DuskRaider Posted November 3, 2024 Share Posted November 3, 2024 Personally I think my Legion should have the best traits and every other one should suck. Seriously, though… there’s a massive imbalance between the Legions and their traits. Some are extremely powerful to the point that it’s game breaking (Alpha Legion, Raven Guard) where others are nigh useless. There has to be a middle ground and I’m not sure why they didn’t just kinda port those from the 28mm game over to 8mm where possible. The same can be said for the various Titan Legios and Knight Households in AT. Most of that could be ported into LI with minimal effort or issues, but just… wasn’t. I suppose you could say it may slow the game down, but it can’t be worse than it is now. Pacific81, Interrogator Stobz and ThaneOfTas 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074274 Share on other sites More sharing options...
Deus_Ex_Machina Posted November 3, 2024 Share Posted November 3, 2024 52 minutes ago, DuskRaider said: Personally I think my Legion should have the best traits and every other one should suck. Seriously, though… there’s a massive imbalance between the Legions and their traits. Some are extremely powerful to the point that it’s game breaking (Alpha Legion, Raven Guard) where others are nigh useless. There has to be a middle ground and I’m not sure why they didn’t just kinda port those from the 28mm game over to 8mm where possible. The same can be said for the various Titan Legios and Knight Households in AT. Most of that could be ported into LI with minimal effort or issues, but just… wasn’t. I suppose you could say it may slow the game down, but it can’t be worse than it is now. Why they don´t port them over? Because it is VERBOTEN! You cannot even have basic USR from 30K/40K mean the same thing in LI. As LI is a different game it needs to have different rules even if the perks are called the same as in other systems. DuskRaider and Mandragola 2 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074283 Share on other sites More sharing options...
DuskRaider Posted November 3, 2024 Share Posted November 3, 2024 (edited) 2 hours ago, Deus_Ex_Machina said: Why they don´t port them over? Because it is VERBOTEN! You cannot even have basic USR from 30K/40K mean the same thing in LI. As LI is a different game it needs to have different rules even if the perks are called the same as in other systems. From what I understand, there’s some internal battles between SG and GW Main concerning crossover of products, which is why a lot of the 30K units are now considered “Legends” units now. Actually, same for a lot of the FW 40K units. It’s ridiculous. I have a feeling that the fan base could, should and probably will make a better ruleset for LI eventually. The sooner the better, because I don’t trust the people over at GW to be able to fix the problems and make a better system after I’ve seen what they’ve done to 40K over the years and the massive downgrade of 30K from FW’s rendition to GW’s current one. Edited November 3, 2024 by DuskRaider Interrogator Stobz and Deus_Ex_Machina 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074297 Share on other sites More sharing options...
Deus_Ex_Machina Posted November 3, 2024 Share Posted November 3, 2024 16 minutes ago, DuskRaider said: From what I understand, there’s some internal battles between SG and GW Main concerning crossover of products, which is why a lot of the 30K units are now considered “Legends” units now. Actually, same for a lot of the FW 40K units. It’s ridiculous. I have a feeling that the fan base could, should and probably will make a better ruleset for LI eventually. The sooner the better, because I don’t trust the people over at GW to be able to fix the problems and make a better system after I’ve seen what they’ve done to 40K over the years and the massive downgrade of 30K from FW’s rendition to GW’s current one. There is a guy who posted on this very forum rules for Orks & Eldar for play in LI in practically no time. Maybe he can take an attempt at it. And yes, the community can do great things. Examples would be 9th Age and the first Living Rulebook for Blood Bowl. Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074298 Share on other sites More sharing options...
Crablezworth Posted November 4, 2024 Share Posted November 4, 2024 The community can do great things but there's such a heavy logistical side to rebalancing units. It's about the nature of what is to change with each unit, if for example its just a re-costing, that still might mean a not insignificant edit and if not edit, having to index a new price list to everything. There's also the card factor, there are thankfully people doing fan made card files so its not hopeless, but it is indicative of gw not ever intending to do anything drastic because although they can update a digital book in theory, they can't update the cards without a new print run and a lot of hassle. They largely missed an opportunity with book 4 to at least start the process with titans and knights and, well, that didn't happen. The only real positive change was seeing armigers and moirax able to operate on their own in some formations. I think being realistic involves making as few changes as possible but at a core level and to re adjust incentives, and introduce some hard limits on army construction. On army construction, some formations have sort of questionably low cost in terms of compulsory slot. There are attempts to sort of tax or force some kind of structure to the whole thing, akin to the old 40k foc of like 1 hq 2 troop, but there's also formations that are simply "take 3 detachments of tanks" or super-heavies, etc. I don't think its a sign of game health that a legal list could be like hundreds of jetbikes, or 27 stormhammers. A legal list, right now, is 75 karacnos, each individual detachments, in 25 fomraitons. That's 3k on the nose. I don't think those edge cases will ever come close to seeing the tabletop, but the fact that they're completely legal clearly shows the game is just way too open for poor balance. But the point is to show that the army construction does a poor job to incentivize fewer larger detachments over trying to take as many as possible. Book 2, literally, gives zero point saving incentive on any detachment in the book, so its by definition he "msu" (multiple small units) book because they went right back to discounting in book 3 and now book 4. So pulling a random number out of my mind, lets say at 2k you could only field maximum 4 formations, or 1 per 500pts basically, so 3 at 1500. Its mostly just as food for though but, starting there. You'd be capped at 6 at 3k, which doesn't even seem like that much of a limit. There's also the question of duplicate formations, I don't want to be the fun police by I think many can agree that formations like pioneer company being spammed can be a bit obnoxious, as well as any sort of skew. I think the goal should be combined arms is sorta the way to go, if not by incentive alone, by structure of army construction. If that means some formations can only be taken once or twice, so be it. Even just as an example, if each formation was 0-1, outside of silly stuff like all titan or knight armies, the hope is you'd more of a combined arms approach, but I'm sure there are ways to still do skew of one wants to. So in the name of efficiency, and without getting into more of a pure faq territory of correcting small mistake in unit/weapon stats, here's the 5 core changes I think would be worth consideration: 1. Infiltrate needs to be replaced in most scenarios with forward deployment or outflank. The new book 4 mission with the bridges is a great example of a cool scenario that will get totally ruined by infiltrate in its currents state. That and even when in play, infiltrate should never allow turn 1 charge, it just ruins the game. 2. Armor and other saves in close combat. The hope here is we'd see less silliness with infantry beating up much larger units, they still can, but now that kratos has its 2+ save, think on it. 3. Infantry should only march 2x, and should only charge their movement stat, no longer double. I'd also want them to have to pass morale in order to charge anything scale 2 or higher. If they fail they can still move their movement stat in any direction even toward the enemy but can't come within 1 inch/engage. 4. Reserves as a core mechanic. Example, a mission/scenario with reserves would require say 1/3 of each sides detachment to begin the game in reserve, similar to deep strikers and outflankers, but in this case just arriving by board edge. (or the other aforementioned methods). Reserves would be in two tiers, the kind you roll for from turn 2 onwards or a tactical reserve where you simply choose when they arrive as it currently works. However in the case of the latter, those detachments would be in addition to your 1/3 reserve, meaning they don't count for the overall % of detachments in reserve. Example, i have 15 detachments, so i need to put at least 5 in reserve. I may place more in reserve, like a 6th detachment of terminators i intend to deep strike. As i've already got 5 detachment i can just put them in tactical reserve and choose when they arrive as normal instead of rolling. Rolling might sound like a drag but it adds an element of uncertainty equally to both sides, especially in a game that once deployed can seem very "telegraphed" because both sides have a birds eye view. To all of a sudden have a unit arrive from reserves you did not expect or on the flanks or from deep strike can really make the game more interesting. But also it can help mitigate disparity in activation somewhat. It also keeps the temp of the battle a bit more even handed instead of the usual 2 turn beat downs you see then its just sorta peters out. 5. Detachments and formations need caps. If I were to run an event right now, the baseline I would use is 1 activation/detachment per 100pts, so 20 max at 2k, 15 at 1500 and so on. As for formations, I'm less confident but I do think approximately 1 per 500pts. I would also just say max 2 of any formation largely not to upset anyone but it probably should be closer to 0-1, at least of the really broken formations. 6 (unofficial) I joking include this because it would have been in the list but it seems GW has already listened, somewhat in that end game scoring is present in a few of the new scenarios/missions in book 4. This sets a good precedent for shifting away from progressive scoring to end game scoring. It's much lower, you can't really get an early lead and in terms of narrative games or more historical style, it makes a lot more sense because you can literally summarize a game in a couple photos, here's a pic after deployment but before turn 1, here's a pick end game, you can see who controls which objectives. Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6074388 Share on other sites More sharing options...
Crablezworth Posted November 12, 2024 Share Posted November 12, 2024 Okay so this isn't perfect, the combat res stuff could probably be worded better or more explicitly, the hope is common sense prevails in terms of combat res. TL;DR This core change is designed to shift the meta back from infantry being king. This big change means that those cool expensive units players pay a lot of points for finally get their resilience in combat and not just from shooting. It's meant to adjust incentives because now charging isn't a guarantee of likely causing some wounds. I left rend out of it, so veletarii and ogryns will still hit hard but they don't cause an ap, so the hope is they'll focus more on lighter targets like other infantry and leave the heavy tanks and knights and titans alone as they'd get their saves. Inv saves work, as do ion saves. Ion works like with shooting, so ap -1 won't shift the integer, but ap -2/3 shifts it 1, ap -4 shifts it 2. Also still only works in front arc. I still don't think this "fixes" infantry by a long shot, they're still great, still run 3x and charge 2x and so on, would love to address those things as well. This also doesn't fix rhinos arvuses and other cheap vehicles charging. But it's a start. Pacific81 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6075474 Share on other sites More sharing options...
DuskRaider Posted November 13, 2024 Share Posted November 13, 2024 The infantry movement is the easiest fix in the world, IMO. Same with vehicle and infantry movement interactions. Infantry moves twice their speed on March. Any other movement is their base number. If they’re in a vehicle and it moves its base movement, they can jump out and move their base movement. If it goes on a March order, they cannot leave the vehicle. The movement is probably the second worst thing about infantry and it compounds all the other problems that they bring to the table. Lord Marshal, vadersson, Interrogator Stobz and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6075486 Share on other sites More sharing options...
Crablezworth Posted November 13, 2024 Share Posted November 13, 2024 1 hour ago, DuskRaider said: The infantry movement is the easiest fix in the world, IMO. Same with vehicle and infantry movement interactions. Infantry moves twice their speed on March. Any other movement is their base number. If they’re in a vehicle and it moves its base movement, they can jump out and move their base movement. If it goes on a March order, they cannot leave the vehicle. The movement is probably the second worst thing about infantry and it compounds all the other problems that they bring to the table. Yeah agree on all of those. Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6075505 Share on other sites More sharing options...
BrutalCities Posted December 9, 2024 Share Posted December 9, 2024 Have you tried epic 40k/armageddon rules? I keep hearing that's one of the best games GW has ever done. And a great rules set for combined arms games. I haven't played it, but watching a game sold me. Pacific81 and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6079972 Share on other sites More sharing options...
Crablezworth Posted December 9, 2024 Share Posted December 9, 2024 5 hours ago, BrutalCities said: Have you tried epic 40k/armageddon rules? I keep hearing that's one of the best games GW has ever done. And a great rules set for combined arms games. I haven't played it, but watching a game sold me. It can certainly inform LI and how to fix it I'm sure. I think though there may be aspects I wouldn't like, I do think LI needs suppression fire but I also don't relish having to find/make a bunch of explosion tokens/markers. That was also something I didn't love about battlefleet gothic. Another aspect I don't think would work is the abstracting of weaponry, li's gone too far down that road to go back now, I also have to say people that want to dismiss WYSIWYG entirely for li to be more like older epic games I just think won't work too well. The main reason I wouldn't go back to older editions of epic is simply, its already very difficult to find opponents for li. vadersson 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6080070 Share on other sites More sharing options...
Gillyfish Posted December 12, 2024 Share Posted December 12, 2024 Interestingly, I always liked the visual impact of the explosions... Anyway, you are correct. This is based on the second edition of the game more than the subsequent editions. That was always quite a swingy game and had some real issues with the game effectively being over by turn 2 (granted my friends and I were playing 6-10k games, which was probably not what was intended). I think trying to fix the game needs to be broken down into stages. 1. Core rules using 'vanilla army lists without legion rules, etc.) - so the interaction of the core rules can be tested and modified as required. This might also require some quite 'basic' armies initially using units with limited special rules initially and then adding back in those more unusual units. For example, testing knight and titans later on rather than including them early. So there are some inherent sub-divisions here that we may wish to consider. 2. Army list structures. Thinking here of the detachment and unit costs as well as unit special rules. With amendments to the core rules that we are happy with, is unit X too good or unit Y really bad? Should there be a different way of selecting armies and detachments (minimum/maximum numbers of types of detachment, for example)? 3. Special army rules and how these are applied and when they are applied in the context of army selection. The above does need further teasing out, but might be a good way to approach some of the issues. DuskRaider 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6080679 Share on other sites More sharing options...
Pacific81 Posted December 15, 2024 Share Posted December 15, 2024 It's very difficult to know how much of a change you should try and make to the game, and the point at which you go too far and then may as well be playing Armageddon or NetEpic, as you've created something with so many house rules it will only be playable with your close gaming group. Like some bastard Frankenstein of a game that has limbs and extra flesh bits hanging off in every direction and comes shambling towards you, sending gamers running off and screaming in terror. For me, there is an element of, if I want to add Orks, Eldar, Tyranids.. why not play the original aforementioned games? They were designed with the different factions in mind, they've had 20 years of community play testing and so are generally balanced. Very subjective, but I think (and this is something that isn't talked about nearly enough) they are a lot more fun to play. For an event we are running next year we will try and use the end of game scoring that the Tabletop-Standard YouTube guys tried recently. I also like some of the maximum activation and formation rules that have been posted in this thread and section of the forum. The problem is if you make too many changes you risk alienating the people that show up at your event and expecting the rules to be ubiquitous (which is really, as far as I can see, the one major benefit of Legions and it being a currently supported game). LameBeard and vadersson 2 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6081144 Share on other sites More sharing options...
Crablezworth Posted December 15, 2024 Share Posted December 15, 2024 7 hours ago, Pacific81 said: It's very difficult to know how much of a change you should try and make to the game, and the point at which you go too far and then may as well be playing Armageddon or NetEpic, as you've created something with so many house rules it will only be playable with your close gaming group. Like some bastard Frankenstein of a game that has limbs and extra flesh bits hanging off in every direction and comes shambling towards you, sending gamers running off and screaming in terror. For me, there is an element of, if I want to add Orks, Eldar, Tyranids.. why not play the original aforementioned games? They were designed with the different factions in mind, they've had 20 years of community play testing and so are generally balanced. Very subjective, but I think (and this is something that isn't talked about nearly enough) they are a lot more fun to play. For an event we are running next year we will try and use the end of game scoring that the Tabletop-Standard YouTube guys tried recently. I also like some of the maximum activation and formation rules that have been posted in this thread and section of the forum. The problem is if you make too many changes you risk alienating the people that show up at your event and expecting the rules to be ubiquitous (which is really, as far as I can see, the one major benefit of Legions and it being a currently supported game). I'll risk alienating the player that, before had to at least play a certain point level to field a warmaster who can now basically have it at almost any point level. I'll also risk alienating someone who thinks its reasonable to have like 30 activations at 1.5k I completely agree that if you change the game too much you may as well play netea or epic armageddon, but neither of those are much of an option at least locally. But agreed that there is a risk in balkanizing whatever small pool of li players there may be in any one place with too many house rules or fixes. I can't stress enough though that the one size fits all of the games current state just doesn't work. It reminds me too much of 40k when they forced knights and all the apoc stuff into and formations. There was nothing fair about a 1500pts game where one side had a 40k army an the other side had 3 knights. I'm just tired of the race to the bottom, of feeling like the marketing department is really running the show. But I think the army construction is a big cop out, to mask a fairly exploitable system with no guard rails they try and make it convoluted/have the occasional tax unit to seem like there are limits on things but there really aren't. The event where they capped detachments at 14, every game went to turn 5. But that also preceded book 4. Agreed on end game scoring being a big improvement to how enjoyable the game is to play or watch, their battle report with it is the most enjoyable li game to watch yet I think because it actually doesn't feel telegraphed like the other battle reports with progressive scoring where the writing is just always on the wall. Pacific81 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6081187 Share on other sites More sharing options...
Crablezworth Posted January 9, 2025 Share Posted January 9, 2025 So thought I'd bump the thread slightly now that there's been some time to absorb the new book, which technically introduced not 2 but 4 new factions to the game. A positive change was seeing armigers and moirax formations now being able to exist on their own instead of tied at the hip to larger knights with the lengthy independent rule. The book also introduced some problem again for balance, where as before large titans like warmasters and warlords had to fit in 30% and thus were only available at certain point levels like 2500 or 2000, that sorta went out the window. It's sort of a step back, in that, there some kind of basic limitation that if one wanted to avoid warmasters they could play below 2.5k, or 2k in the case of avoiding warlords. If the dreaded competitive meta was warmaster and a sea of infantry at 2.5k, it can now more or less take on that form below 2.5k now as well. The other concern isn't necessarily the brutal end of competitive play but also just the practical realities of activation disparities. I don't think I'm a monster for having no interest in playing say 1k or 1.5k against a handful of titans/activations. When 40k started allowing all the silliness of apoc stuff like super heavies, formations and eventually knights, there was never anything engaging about a meta going from largely combined arms mechanized armies to "i just have 3 knights at 1500". And that's sort of the ramifications of where we're at now balance wise with book 4. I think without trying to come off as cynical or edgy, there is a very real problem of incentives in that the marketing department wants gw games to be as liberal and open as possible as to not limit sales. And the end result is a massive misalignment in incentives and outcomes. A good example of this is the almost universal phenomenon of players expectations not conforming to reality, exemplified by players make 3k their first game and tapping out after a few turns. The reality being the game's rule system is perhaps less built for speed than one might expect, but also, balance being not just a factor of actual point costs etc being out of whack but also activation disparity not controlled for in anyway. One interesting development was an event in the states capping armies at 14 activations/detachments. The result of which was all games actually finishing and getting to turn 5 in the time allotted. I think its doubtful we will get much in a meaningful faq/errata from gw but there's so much potential for li with the right amount of tlc. Shooting works mostly well and smoothly for the most part, barring some units that have lot of different weapon stats. But simply put some tanks exchanging fire is usually pretty quick to resolve. The one exception to this can be too much overwatch without some kind of limitation, this is one area that can not only bleed time but also be complicated to remember in the case of pd weapons, but can also serve to confuse one or both players as to if they're even in the movement phase anymore or the combat phase. As someone who isn't a fan of reactions, overwatch really should be limited or locked behind just pd/first fire. But the even with that, combat still feels like the worst in terms of enjoyment vs time invested. I actually don't hate the contextuality of it, but its so strange for something so contextual to then be abstracted to a single number, but worse, have the process be not only swingy but mentally draining. Resolving combat if small can be fine, but the larger and more complex the combat the more it can feel like both sides are cashiers at a super market and not friends enjoying a game. So rounding back out to the topic of suggested fixes. If we're not going to be able to fix combat or make it any more fun, we can certainly do things to make it more of a rare occurrence. As I've shown earlier we could allow saves, which may in itself not be a total deterrent to combat, but would certainly shift things towards the target of the charge being more considered than they are currently. Furthermore as others have suggested we could slow infantry down, no more triple march or double charge. That one change alone would invariable see infantry without missile launchers perhaps actually have to consider whether to fire there weapons or charge, compared to currently where charging is quite often the better option, esp considering there is no equiv to light trait for cc attacks. There clearly is a mandate in gw where they want close combat as viable as shooting and it really really really doesn't work at this scale of combat. The issue currently isn't just speed but its very difficult to fail a charge at times with enough bodies, there's never even so much as a leadership check require for scale 1 infantry to charge a scale 5 titan. I'm sure I'm not saying much "new" the hasn't already been said in this thread, but the issues at the core of the rules are still largely the same. Having played now a few times with my dark mech, all I can say is infantry are still insanely strong and largely a much better value than the 2 wound bots. And that's not to slag the bots either, some do quite well, its just, my god, myrmidon secutors with c beams are just as disgusting as missile marines and the point cost is insanely low for the output. Not helping either one can field 3 detachments of them in up to 8 models per, for 24 c beams in a single formation (dark taghmata sub convent) and the only tax is 2 detachments of 4 tech thralls and a 25pt hq magos. So, the problems ain't going away seemingly, infantry still rule the day and will continue to seemingly, DuskRaider 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6086163 Share on other sites More sharing options...
Crablezworth Posted February 23, 2025 Share Posted February 23, 2025 (edited) So somewhere in the ballpark of the topic of fixing li is having a good example of what is possible given just how permissive army construction is. The meme came to life: If anyone remembers the famous 40k game where infiltrating kroot I believe basically ended the game before it even started by infiltrating across the board and blocking the opponents edge, effectively rendering it game over. This isn't quite that but, how fun is it to have an entire or good portion of an opponent army infiltrate 4 inches from your zone and box you in pretty much entirely? I think this at least serves as an example of why infiltrate is problem number 1 for a faq/errata/rebalancing. A recent event in australia capped infiltrators at 900pts, I think that's an admirable attempt but honestly to my mind it's not just that infiltrate is largely not costed as its often given by a foramtion's special rules, its the rule itself, the fact that the range is so short, and detachments are permitted to charge, it's just way too much. Even deep strike or outflank isn't going to allow charging without some kind of help from an hq to flip the order, but infiltrate allowing it isn't even consistent with past games. Infiltrate also in older 40k had some relation to los, ie you could only get so close by hiding out of los from all enemy models, otherwise you'd be relegated to like 18 inches instead of 12. But in their case, turn 1 charge after infiltrate was a non zero possibility. It's not even advantageous for gw or marketing to have it remain this way as it undoubtedly hurts sales of drop pods. Why pay points and money for pods when a legion like RG or alpha legion can just infiltrate? Similarly why buy transports for solar aux when entire formations can infiltrate? The other problem with this example of a whole army of pioneer companies is, not only is this game likely not going to be super enjoyable, but it will be very few turns, just a couple really long turns. At least with the new mechanicum tanks nowhere in sight players aren't having to suffer endless karacnos, but that's coming too I'm afraid, if no limits to army construction even manifest. Perhaps the best we can hope for if a new book comes out is, we'll finally see legion artillery and possibly super heavies and solar aux light armour, but really the core of the book, dare to dream, could maybe be in the vain of the AT matched play book and try and reign in the game balance a bit. Dare to dream. classic Edited February 23, 2025 by Crablezworth Deus_Ex_Machina and DuskRaider 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6096504 Share on other sites More sharing options...
Nagashsnee Posted February 24, 2025 Share Posted February 24, 2025 So legions imperialis more or less died around my game area. And it all came down to 1 thing and 1 thing only, the current edition is strictly pay/print to win by the largest degree in GWs history. Units/weapons are so comically unbalanced that this is not a game where one needs to be competitive to immediately see 1/3- 1/2 the units in the game might as well not exist. Not because they are simply slightly bad or slightly overcoated, but because they have no actual role that cannot be done far better by something else, often to a comical degree. This quickly led to whoever could have access to thing like ogryns, marine missiles, termies, thudd rapiers, etc in any significant numbers to absolutely and easily dominate someone who just bought a little bit of everything. So you had 1-2 people who could afford to buy X numbers of boxes to make said units since GW has in affect taxed all boxes with some good some bad units in random numbers. But then (and i am one of these) came the printing bros. And suddenly access to the models was not a barrier to list building. And then the game just collapsed under its own totally horrendous internal balance. No amount of core rule fixes could stop this. The fact is some people can afford to buy/print X extra boxes that only have say 2 Myrmidon Secutors (random example not saying this specific unit is problematic) per box yet can be fielded up to 8 strong PER SINGLE UNIT and its pay/print to win. And with the abominable internal balance this matters. Because its not tournie WAAC players crunches numbers, its looking the leman russ variants with a working brain and choosing anything but the Vanquisher. Secondly Legion rules have been implemented horrendously and cannot be balanced in their current version. Given a army, na army wide buff for free is already dangerous, giving a army access to 18 free buffs that they can freely mix was a recipe for disaster. Allowing them to do it BY DETACHMENT??? LoL. Making it so ONLY ONE faction got this kind of thing was .... a choice allright. SA have no regiments, Mech wont get Forge worlds. So either every single space marine unit in the game has been costed with every single legion trait taken into account (LOOOOOOOOL).... and then costed to mix this multiple times over by detachment....or marines will always be over/under costed. Thirdly the game pushes and i would say expects you to mix armies (Marines, SA, etc), but most people in my experience did not want to do this. So you had most marines play solo marines, SA play solo SA, i am doing Solo Mech and before that had Solo Marines. And again any notion that they tried to balance costs/detachments for both ways of play is laughable. But asides from that its financially insane. The way the infantry and support boxes are structured trying to get a small marine ally detachment with 1 full strg infa option of each infantry option (so 8 bases of assault, termies, plasma etc) means 164 euros. Sure you have 24 tactical marines and 8 commands at the end too i guess, and a unit of each dread (not that any sane person would play assault cannons). But the vast majority will either never do this, or certainly before completing their 'main army' Or you just print what you need. This shattered group balance. And no people want to play their minis and their armies, and not have to borrow or proxy every second game. This isnt like 40k where people are trying to go full WAAC to win a GT or something, its simply the case of many many units being so bad that any normal person will quickly see they are DETRIMENTAL to winning. And while many have no issues playing slightly weak units here and there to keep it fluffy, LI took this to heights unseen. Likewise a person playing Ultramarines will always lose to a world eater if they both play on the same level and have equal luck, One is simply MUCH MUCH BETTER due to his free super rule running against a meh at best free rule. All while mech and SA wonder where their free rules are. This lead to many being faced with a choice, 1) Play the specific ways the game tells you are effective ( for marines this also means dumping your legion most times) while either massively investing money or getting prints (not every wants this), and again i dont think wanting 2-3 full units of termies is a crazy thing to want. 2) Move on to better games and for some (like me) paint up the minis cause you like painting. Some of these issues can be fixed, i still believe it would take a new edition with a total redesign but i may be wrong. But i dont know how they are going to get around the fact that if you want something as basic as say 3 units of assault marines (so 24 stands) you need 12 boxes at 41 Euros (retail) a pop. And for us this was a BARRIER. People wanted to play EPIC armies like the books, to launch mass terminator teleport assaults, and have waves of Blood Angel assault marines jump out of T hawks. And when they realised what that translates too in investment PLUS the fact they were making you buys duplicates of things you dont need (Command squads) or the game says are total waste of points (plasma gun) it killed it dead. Add to that the 1/6 who COULD get the models steamrolling over everyone, and again not WAAC, but simply not playing the total waste units other people HAD to field to get up to points and it was over. Your left with a badly designed both in rules and models (thats not even a dig at the actual infantry models like tactical marines), with internal balance so bad it makes the worse day of 40k look good, and a total lack of GW to do ANYTHING to fix anything and yeah R.I.P. LameBeard, Mandragola, Deschenus Maximus and 2 others 2 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6096632 Share on other sites More sharing options...
Crablezworth Posted February 24, 2025 Share Posted February 24, 2025 I agree with pretty much everything you've said. Skimask mohawk recently referred to LI's rules as shovelware and I honestly can't disagree. The point about 3d printing really amplifying the lack of internal balance is something that has worried me from the get go once I realized just how permissive the rules on army construction are. Because the cost of printing endless missile marines or drop pods or vanq russes or ogryns or any other good unit that may normally be locked behind other less than ideal models on the same sprue didn't matter in terms of printing. I'm certainly guilty of selling off the units that just don't work and printing more of the ones that do, but a lot of that isn't just a purely financial choice, the fact that some kits don't offer any weapon swaps on sprue given just how many components they've decided to make them, like the contenptors with kheres assault cannons, or some of the speeders, in the age of 3d printing that's just never gonna fly. But ya I think one benefit to being realistic about the sate of the game/rules is, at least to my thinking on it, it makes even incremental improvements that much more worthwhile in terms of hoping to at least reach for glass half full status. I get being cynical about even the prospect of attempting to improve li given all the flaws mentioned, largely around balance and cost and incentives being so auto take for a lot of things. I'm not thinking a few tweaks and all of a sudden the fact that weapons aren't costed won't still be a huge problem, like even with some of the changes, vanqs likely will still be the best choice for russ loadout etc, but I still think a big incentive shift would at least make the game better than it is currently, while still having most of its flaws. Like a coles notes top down approach might honestly still improve things, example: Titans, knights and vehicles scale 2 or higher can now just remove infantry in the open by ending their movement overlapping their base. Infantry now can only charge stuff 1 scale higher, 2 max but now having to pass morale. Infantry only charge their movement stat, not double, and only run double, not triple. Infantry on first fire can double their weapon range for any weapon 10 inches or less in stat, (bolters become 16 on ff and so on) Tarantulas and rapiers can no longer be in structures. Infiltrate is 12 inches and can't charge turn 1. Saves allowed in close combat. All formations 0-1, detachment/activation caps indexed to point level of game. All knight or all titan armies relegated to titandeath only. Mech still allows titans and knigts to be taken outside the 30% allies anyway. No warmasters outside of 2k+ End game scoring instead of progressive. Added/forced reserves. I get that none of that fixes weapons largely not having a cost/upgrade cost. Might still need a blanket like no more than x of the same unit/model to combat ml launcher marines or c beam myrmidons or spamming tarantulas/heavy sentinels. The change to infiltrate still should probably have a hard cap where the rest of the units have to swap out infiltrate for outflank or forward deployment. It wouldn't fix titans weapons all costing the same, but would hopefully help mitigate titans being out activated/swamped in cc by infantry. I still feel like it'd be a good start towards improving things. Pay to win would still largely be there, but part of that as well is the focus on huge battles. It's a game that could also be really interesting with smaller engagement and possibly on smaller boards as well. Something gw never tried because they want everyone to think they need 3k just to play, but I've honestly found small and mid sized games to be better than the huge games, its also where stuff falls apart even more imo. DuskRaider and Nagashsnee 2 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6096660 Share on other sites More sharing options...
Nagashsnee Posted February 25, 2025 Share Posted February 25, 2025 (edited) Oh the game can be vastly improved with little effort, dont get me wrong, i am not saying steps cant be taken to help it get to a better place. But i think on the off chance the designers ever see/hear its important to stress the fact that the game needs a top to bottom re work and re imagining. But for day 1 much of what you said i agree with, in addition to a points errata, now i dont want them to make ANYTHING cheaper, the game is costly enough to get already, just make the too good stuff COST MORE. This will both help the weaker units see play and make the good units help fill out lists easier. Example being tactical marines having the plasma support costed the same as missiles or termies. Dont make plasma cheaper, make termies and missiles 1-2 points more expensive. Lascannon dreads vs assault cannon dreads, etc etc. But they need to do something, fast before the new people who arent just 20 year epic veterans totally give up and disappear. Edited February 25, 2025 by Nagashsnee DuskRaider and Crablezworth 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6096759 Share on other sites More sharing options...
Crablezworth Posted February 26, 2025 Share Posted February 26, 2025 On 2/25/2025 at 2:18 AM, Nagashsnee said: Oh the game can be vastly improved with little effort, dont get me wrong, i am not saying steps cant be taken to help it get to a better place. But i think on the off chance the designers ever see/hear its important to stress the fact that the game needs a top to bottom re work and re imagining. Well, I'd infinitely prefer they don't throw the baby out with the bathwater just yet, I'd like to see them attempt a faq/errata before jumping to a new edition. For starter one would at least serve as a test bed for building trust that 2nd edition will actually be an improvement and not just a financial ask on gw's part. The amount of books required to play legion or solar aux is already something you basically want to hide from new players. On 2/25/2025 at 2:18 AM, Nagashsnee said: But for day 1 much of what you said i agree with, in addition to a points errata, now i dont want them to make ANYTHING cheaper, the game is costly enough to get already, just make the too good stuff COST MORE. This will both help the weaker units see play and make the good units help fill out lists easier. I think they also still need to cap thing in addition to fixing costs. Right now the good units tend to only have a mild tax in terms of whatever the compulsory slots are that need to be filled in order to field the better units. I still think there's a conflict of interest there between sound rules making and marketing who think any limit on someone's wallet is bad. I agree points need to be fixed but if there's no equivalent to an foc, then its still not a big enough fix. I still feel like a lot of that is only possible with a 2nd edition. There's definitely realities and problems that are shared across different gw games that stem from really weird design ethos/choices. Like kill team also for some reason doesn't have saves in close combat I believe, and 10th ed has that huge core problem like li of just not costing weapon options so things get very cynical instead of simpler. They can't be doing that in the age of 3d printing. Just like they can't get away with stuff like the dreadnoughts having just las or an assault cannon that is objectively worse. On 2/25/2025 at 2:18 AM, Nagashsnee said: Example being tactical marines having the plasma support costed the same as missiles or termies. Dont make plasma cheaper, make termies and missiles 1-2 points more expensive. Lascannon dreads vs assault cannon dreads, etc etc. Even titanicus ran into this problem where its really difficult to cost weapon to weapon, largely in integers of 5pts. Titanicus has the same problem with upgrades/corruptions. I think just as much as they have to consider fewer a or b or a/b/c choices where we pretend all are equal, even with more upgrade costs for some weapons, it gets really awkward at scale. Also can still feel like an auto take even where there is an upgrade cost. It's like 3pts on a thunderbolt to upgrade to avenger gatling cannons. Even with the upgrade its still the cheapest solar aux flyer by a couple points. I do think a new edition will need to do this, I can't think its realistic to expect much change given all the books/cards would need reprinting. That said, they definitely can faq combat to be less prevalent or auto choice, which would at least give the shooting weapons room to breath. On 2/25/2025 at 2:18 AM, Nagashsnee said: But they need to do something, fast before the new people who arent just 20 year epic veterans totally give up and disappear. I think I almost fear a new book. They painted themselves into a corner on the last one, showing they can indeed include 4 whole army lists in one book if they try. Why legions or solar aux required the rulebook and 2 other books is a bit nuts. As much as I want more units for both, I don't really want a new book. Especially if its just going to be more 30k art and some random scenarios. If they did a matched play book to try and tighten things up I'd be on board, especially if it had scenarios for low point levels to try and bring in new blood. It's sort of unforgiveable they didn't do a series with like more or less the contents of the battlegroup boxes squaring off at low point levels like 1k or 1250pts. Show potential new players a path forward instead of scaring them off. But ya they need to do something. Pacific81 and Nagashsnee 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6097123 Share on other sites More sharing options...
Nagashsnee Posted March 1, 2025 Share Posted March 1, 2025 On 2/26/2025 at 5:09 PM, Crablezworth said: If they did a matched play book to try and tighten things up I'd be on board, especially if it had scenarios for low point levels to try and bring in new blood. It's sort of unforgiveable they didn't do a series with like more or less the contents of the battlegroup boxes squaring off at low point levels like 1k or 1250pts. Show potential new players a path forward instead of scaring them off. But ya they need to do something. It has to be a free errata/pdf, they cant ask you to buy a book to fix the other books, plus the way they design releases it would be invalidate the moment the next mini wave/book comes out. Free pdf for everything up to now, and day 1 pdf like 40k gets for any book already finished/at printers. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6097763 Share on other sites More sharing options...
Crablezworth Posted March 1, 2025 Share Posted March 1, 2025 8 hours ago, Nagashsnee said: It has to be a free errata/pdf, they cant ask you to buy a book to fix the other books, plus the way they design releases it would be invalidate the moment the next mini wave/book comes out. Free pdf for everything up to now, and day 1 pdf like 40k gets for any book already finished/at printers. Certainly the faq/errata needs to be free. My only point was a new book seems inevitable given how they've done things so far, so my only hope was that at least part of it or most of it was dedicated to tightening things up in terms of scenarios/missions. I don't think a faq can really introduce concepts like capping detachments/formations, that's something more relegated to scenario/missions imo. So like with the matched play book for AT, which honestly was much needed given how bad the core matched play rules were for AT, if they're going to churn out books no matter what, I just hope that'd the focus of the next one. Nagashsnee 1 Back to top Link to comment https://bolterandchainsword.com/topic/384436-how-to-fix-li/page/2/#findComment-6097890 Share on other sites More sharing options...
