I've never attached the bases to the previous Stormravens I've built and owned. I attach the plastic flight stand to the base and then leave it like that. The Stormraven is made so that it will sit on the stand when it is put on it correctly. If you are putting it on the flight stand and it keeps tilting backwards and fall off you need to put it going the other direction on the stand.
That's what I did. The base and stand are glued together, and I don't plan on going out to the model itself. My question pertains to the actual Stormraven. See my attached pics above. My question is can I glue the top piece to the bottom piece and still have it safely fit in the monster figure case.
  • Solution
Its been a while for me, but if I recall, yes you can. You take out the top tray, and the insert of the bottom tray, and it will fit in there.
So your case still has the two foam trays and their inserts on one side for your miniatures, but the other side is all Stormraven and the stand/base. I think I even took out the wavy insert and used it as padding around the model too?
Edited by Helias_Tancred
Cool, thank you!
I didn't glue the wings on my stormraven - the wing tab slots perfectly between the upper plate and the air intake thing, and holds with friction. I can slide the wings off mine and it fits perfectly into one tray in a GW crusade case.
Register a new account
Sign in
