Viking Slade Posted November 4, 2024 Share Posted November 4, 2024 (edited) I'm looking to rebase my Firstborn models onto current base sizes, but I also would like to add some height to the models in order to bring them close to Primaris model height. My plan is to run my models as their Primaris equivalents, but I know LOS is an issue with that, hence adding height to my Firstborns' bases. Can someone give me a rough estimate of the height difference between Firstborn and Primaris models (assuming a basic, non-action pose, just standing up mostly straight)? And same question for Firstborn vs Primaris Dreadnought height? Edited November 4, 2024 by Viking Slade N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/384468-firstborn-vs-primaris-model-height-difference/ Share on other sites More sharing options...
Evil Eye Posted November 4, 2024 Share Posted November 4, 2024 Here's a size comparison between a converted Primaris Marine (using Tactical arms, head and backpack and lots of resculpting but with no height changes) and a metal Firstborn captain. The Primaris is slightly raised by virtue of the sculpted base, but hopefully this gives some idea. N1SB and Viking Slade 2 Back to top Link to comment https://bolterandchainsword.com/topic/384468-firstborn-vs-primaris-model-height-difference/#findComment-6074324 Share on other sites More sharing options...
N1SB Posted November 4, 2024 Share Posted November 4, 2024 From our friends at Tale of Painters: https://taleofpainters.com/2022/05/scale-comparison-mkvi-horus-heresy-space-marine-legionaries/ Viking Slade, sockwithaticket and bloodhound23 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/384468-firstborn-vs-primaris-model-height-difference/#findComment-6074325 Share on other sites More sharing options...
Solution Grotsmasha Posted November 4, 2024 Solution Share Posted November 4, 2024 (edited) The easiest way to make up the height is to glue the models on their old bases on top the new, larger bases and the build up the empty area on the new base to the height of the old base, and then match the basing style. Edited November 4, 2024 by Grotsmasha Viking Slade, N1SB and Karhedron 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/384468-firstborn-vs-primaris-model-height-difference/#findComment-6074326 Share on other sites More sharing options...
Viking Slade Posted November 4, 2024 Author Share Posted November 4, 2024 25 minutes ago, Grotsmasha said: The easiest way to make up the height is to glue the models on their old bases on top the new, larger bases and the build up the empty area on the new base to the height of the old base, and then match the basing style. I was hoping it would be (at least close to) this easy. That makes me so happy. Thanks for all the replies, everyone, this helps me immensely. N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/384468-firstborn-vs-primaris-model-height-difference/#findComment-6074327 Share on other sites More sharing options...
bloodhound23 Posted November 4, 2024 Share Posted November 4, 2024 I used cork board for basing and so it leaves my Firstborn just barely shorter than Primaris. Viking Slade 1 Back to top Link to comment https://bolterandchainsword.com/topic/384468-firstborn-vs-primaris-model-height-difference/#findComment-6074328 Share on other sites More sharing options...
Firedrake Cordova Posted November 4, 2024 Share Posted November 4, 2024 Just to throw another comparison in courtesy of MiniCompare: Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/384468-firstborn-vs-primaris-model-height-difference/#findComment-6074337 Share on other sites More sharing options...
