Nekro83 Posted November 6, 2024 Share Posted November 6, 2024 Ballistus conversion ideas gathering...so...i will mount a twin linked lascannon on one of the arms...now I am trying to figure out where to put the missile launcher...this is my first option...mounting them on the top and leaving a fist on the other arm. (I am using another levi from my IW to try to see the possibile result).The other option is to mount the launcher on the other arm (but I am still waiting for the 3d printed launcher to arrive, it will be a whirlwind turret one)...what do you think? I d like to hear your honest opinions...both on the overall look and on how much this woukd be acceptable (considering it will have both the correct loadout, and base size). So missiles on top...yes or no? Kurgan the Lurker 1 Back to top Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/ Share on other sites More sharing options...
Karhedron Posted November 7, 2024 Share Posted November 7, 2024 Missiles on the top look cool. Maybe for the arm you could mount some sort of scanner on it. A bit like the old Cyclone Missile Launcher Terminators. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6074716 Share on other sites More sharing options...
Firedrake Cordova Posted November 7, 2024 Share Posted November 7, 2024 From a perspective of being armed as the rules say, having the missiles on the arm (or having no weapons on the arm) is probably the least likely to cause confusion. However, I generally tend to follow the rule of cool - as you've got the other part coming, try it with both and see which you prefer the look of. Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6074720 Share on other sites More sharing options...
Grotsmasha Posted November 7, 2024 Share Posted November 7, 2024 I too run with rule of cool, however, if you intend on playing with randoms or competitively, I'd ensure the overall height matches the Ballistus. Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6074740 Share on other sites More sharing options...
Nekro83 Posted November 7, 2024 Author Share Posted November 7, 2024 35 minutes ago, Grotsmasha said: I too run with rule of cool, however, if you intend on playing with randoms or competitively, I'd ensure the overall height matches the Ballistus. Should be not too different Karhedron and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6074747 Share on other sites More sharing options...
Grotsmasha Posted November 7, 2024 Share Posted November 7, 2024 27 minutes ago, Nekro83 said: Should be not too different The added height from the missile pods is what I was thinking about. Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6074755 Share on other sites More sharing options...
Nekro83 Posted November 7, 2024 Author Share Posted November 7, 2024 Yes, i mean, regular leviathan is a bit shorter than redemptor/ballistus, so with the pods they shall be similar. Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6074768 Share on other sites More sharing options...
Tallarn Commander Posted November 7, 2024 Share Posted November 7, 2024 Missiles on top looks really nifty. Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6074780 Share on other sites More sharing options...
Nekro83 Posted November 29, 2024 Author Share Posted November 29, 2024 Ballistus converted from Leviathan v2, this has the launcher on the other arm. More in line with the original i think...what do you think? GhostMalone, Dr_Ruminahui, W.A.Rorie and 4 others 5 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6078377 Share on other sites More sharing options...
Firedrake Cordova Posted November 30, 2024 Share Posted November 30, 2024 A nice conversion and looks super-imposing Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/384534-need-opinions-about-making-a-ballistus-from-leviathan/#findComment-6078419 Share on other sites More sharing options...
