Santaclauswitz Posted November 11, 2024 Share Posted November 11, 2024 I hope this isn't too dumb! What stratagems can Creed's ability be used on? I'm sure it's changed as 10th has progressed. I'm seriously considering putting 2 HWS lascanon squads in my list for double overwatch if Creed can do it. Link to comment https://bolterandchainsword.com/topic/384574-what-stratagems-can-creeds-ability-be-used-on/ Share on other sites More sharing options...
sairence Posted November 11, 2024 Share Posted November 11, 2024 You can no longer double up on strategems when playing games using the matched play balance data slate. All generic CP-reduction abilities were aligned in that way. The only abilities that let you double up on a strat use would be things that call out a specific strat. So for example the Death Korps Marshall lets you use Insane Bravery twice in the same Command Phase. The Knight Lancer lets you use Tank Shock a second time after finishing a charge move. So Creed only lets you reduce to cost of a strat used on a unit in range of her by 1 CP. (This still doesn't let you reduce the cost of Reinforcements! btw) Link to comment https://bolterandchainsword.com/topic/384574-what-stratagems-can-creeds-ability-be-used-on/#findComment-6075323 Share on other sites More sharing options...
