Harrowmaster Posted November 17, 2024 Share Posted November 17, 2024 Hi all, I was wondering what kind of experience people have had with Mortian's printed products. I notice that any of the 3d prints (such as the mini crawlers) are listed as being "pre-cured" which means that "you must put the models in UV light for half an hour (sunlight also works but might take longer depending on the UV intensity of your location) to fully cure." Has anyone ever had to do this and what was your experience of the process? Link to comment https://bolterandchainsword.com/topic/384613-mortian-3d-print-experience/ Share on other sites More sharing options...
Grotsmasha Posted November 17, 2024 Share Posted November 17, 2024 This is an odd choice, and best guess is, being partially cured, allows it some flexibility, and therefore more resiliance in the mail, which in turn prevents more parts arriving broken. Being pre-cured to me reads as only the surface has had a light cure, and that there *shouldn't* be any liquid resin on the model. There may however, be some leakage if the model was printed hollow. I would still recommend gloves, and curing the pieces with multiple rotations to ensure a full cure before touching ungloved. Harrowmaster 1 Back to top Link to comment https://bolterandchainsword.com/topic/384613-mortian-3d-print-experience/#findComment-6076146 Share on other sites More sharing options...
Harrowmaster Posted November 18, 2024 Author Share Posted November 18, 2024 9 hours ago, Grotsmasha said: This is an odd choice, and best guess is, being partially cured, allows it some flexibility, and therefore more resiliance in the mail, which in turn prevents more parts arriving broken. Being pre-cured to me reads as only the surface has had a light cure, and that there *shouldn't* be any liquid resin on the model. There may however, be some leakage if the model was printed hollow. I would still recommend gloves, and curing the pieces with multiple rotations to ensure a full cure before touching ungloved. Thanks, I do believe Mortian recommends gloves when handling the resin. It's not something I have ever encountered before so was curious as to how it works out in practice. Link to comment https://bolterandchainsword.com/topic/384613-mortian-3d-print-experience/#findComment-6076178 Share on other sites More sharing options...
Matcap86 Posted November 25, 2024 Share Posted November 25, 2024 Huh I like Mortian's stuff, but this would be a big no-no to me. If I'm buying 3d printed stuff I expect it to be fully cured and done and not "you'll have to see if this toxic chemical is still active or not. And if it is, well good luck dealing with it." TwinOcted, LameBeard and Harrowmaster 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384613-mortian-3d-print-experience/#findComment-6077459 Share on other sites More sharing options...
Harrowmaster Posted November 25, 2024 Author Share Posted November 25, 2024 1 hour ago, Matcap86 said: Huh I like Mortian's stuff, but this would be a big no-no to me. If I'm buying 3d printed stuff I expect it to be fully cured and done and not "you'll have to see if this toxic chemical is still active or not. And if it is, well good luck dealing with it." It is putting me off ordering tbh, it's a decent bit of extra work and I'm not confident I'd do it properly. I'm also not 100% sure which of Mortian's kits are still cast resin. Link to comment https://bolterandchainsword.com/topic/384613-mortian-3d-print-experience/#findComment-6077473 Share on other sites More sharing options...
Matcap86 Posted November 25, 2024 Share Posted November 25, 2024 1 hour ago, Harrowmaster said: It is putting me off ordering tbh, it's a decent bit of extra work and I'm not confident I'd do it properly. I'm also not 100% sure which of Mortian's kits are still cast resin. Good call, might need to inquire with them. Just saw thay their Main battle tank line has gone full 3d print, which is disappointing. I get that it's easier/cheaper for them but I'd still prefer the cast resin stuff tbh. Harrowmaster and LameBeard 2 Back to top Link to comment https://bolterandchainsword.com/topic/384613-mortian-3d-print-experience/#findComment-6077484 Share on other sites More sharing options...
Harrowmaster Posted November 25, 2024 Author Share Posted November 25, 2024 7 hours ago, Matcap86 said: Good call, might need to inquire with them. Just saw thay their Main battle tank line has gone full 3d print, which is disappointing. I get that it's easier/cheaper for them but I'd still prefer the cast resin stuff tbh. Absolutely, particularly if the printed stuff isn't fully cured Matcap86 1 Back to top Link to comment https://bolterandchainsword.com/topic/384613-mortian-3d-print-experience/#findComment-6077589 Share on other sites More sharing options...
