TheMawr Posted November 27, 2024 Share Posted November 27, 2024 1 minute ago, Indy Techwisp said: So what do people think is leaving the Guard Codex to make way for this? It should be 5 kits that need to be removed to make space. I'm thinking it'll be Servitors, Regimental Attache, Stracken, Harker and Sly Marbo. I dont think there is a one in, one out rule, there never has been before.. the purging we have seen before is not to make place for new datasheets, but to get rid of finecast... that it often seemed 1 in 1 out is pure coincedence. By that same analogy however, again, purely coincidental.. I could see all of the above go yes as they are finecast. Servitors will almost definitely go, they where cut from all other codices they where in. Though I also wonder if the priest might go ( wich would be a shame ) because he can be taken through IA already. btw how do you get to 5 ? I count at least 7 new datasheets : Greir, Deathriders, Deathkorps command squad, Engineers, Deathkorps heavy weapons, the big artillery piece and Tempestus aquillons. DemonGSides, Inquisitor_Lensoven and Dalmyth 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077978 Share on other sites More sharing options...
Indy Techwisp Posted November 27, 2024 Share Posted November 27, 2024 (edited) 8 minutes ago, TheMawr said: I dont think there is a one in, one out rule, there never has been before.. the purging we have seen before is not to make place for new datasheets, but to get rid of finecast... that it often seemed 1 in 1 out is pure coincedence. By that same analogy however, again, purely coincidental.. I could see all of the above go yes as they are finecast. Servitors will almost definitely go, they where cut from all other codices they where in. Though I also wonder if the priest might go ( wich would be a shame ) because he can be taken through IA already. btw how do you get to 5 ? I count at least 7 new datasheets : Greir, Deathriders, Deathkorps command squad, Engineers, Deathkorps heavy weapons, the big artillery piece and Tempestus aquillons. From Auspex Tactics. 66 datasheets in the datasheet pack, minus the 3 from the Combat Patrol gives 63 datasheets or the codex. The new things being added are the entire Kreig Wave + Aquillons + Rogal Dorn Tank Commander. In order to make that amount + the existing fit into 63 datasheets, you need to lose 5 old ones. However, Auspex seems to have not counted the Aquillons, so Guard may actually be losing 6 old units, not 5. I think the Priest will stay, just with the new profile SoB and IA use. Instead, I think the Ogryn Bodyguard unit (basically a 3rd build option of Ogryns and Bullgryns) will be leaving. Either that or they're gonna Consolidate some Leman Russ variants. Edited November 27, 2024 by Indy Techwisp AutumnEffect and LSM 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077982 Share on other sites More sharing options...
Inquisitor_Lensoven Posted November 27, 2024 Share Posted November 27, 2024 29 minutes ago, Indy Techwisp said: So what do people think is leaving the Guard Codex to make way for this? It should be 5 kits that need to be removed to make space. I'm thinking it'll be Servitors, Regimental Attache, Stracken, Harker and Sly Marbo. Nothing needs to be removed. the marine codex proves they have no problem having bloated codexes. that being said I could definitely see servitors being removed since they were introduced before admech existed, and they don’t really fit in the faction Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077985 Share on other sites More sharing options...
Focslain Posted November 27, 2024 Share Posted November 27, 2024 So there are 61 current Datatsheets in the guard index. The new set is set to be 66 per the WarCom article. This gives five slots for new units. Of which we have 7 incoming. So only need to lose 2 which is a good bet it's the servitors (combined to the Enginseer IF they continue) and the Regimental Advisors (combined to command squads if they stay at all). That would give us the 66. DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077986 Share on other sites More sharing options...
TheMawr Posted November 27, 2024 Share Posted November 27, 2024 Just now, Indy Techwisp said: From Auspex Tactics. 66 datasheets in the datasheet pack, minus the 3 from the Combat Patrol gives 63 datasheets or the codex. The new things being added are the entire Kreig Wave + Aquillons + Rogal Dorn Tank Commander. In order to make that amount + the existing fit into 63 datasheets, you need to lose 5 old ones. However, Auspex seems to have not counted the Aquillons, so Guard may actually be losing 6 old units, not 5. I think the Priest will stay, just with the new profile SoB and IA use. Instead, I think the Ogryn Bodyguard unit (basically a 3rd build option of Ogryns and Bullgryns) will be leaving. Either that or they're gonna Consolidate some Leman Russ variants. Ah ok, that wasnt clear to me, I dont follow Auspex.. the voice.. Ogryn bodyguard is actually a fourth build option, there is also Nork dedugg from that kit, imho one of the main reasons for the ogryn bodyguard to be there in the first place was so you have a use for the leftover 2 ogryns when building Nork, without having variable point lists like harlequins and custodes have. It could be consolidated into one datasheet, but I personally think the priest going is just as likely. I really dont follow tanks, and guard have ALOT of tank profiles artificially boosting their datasheets, but are these really mergable ? The_Oni_of_Hindsight 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077987 Share on other sites More sharing options...
Indy Techwisp Posted November 27, 2024 Share Posted November 27, 2024 1 minute ago, Focslain said: So there are 61 current Datatsheets in the guard index. The new set is set to be 66 per the WarCom article. This gives five slots for new units. Of which we have 7 incoming. So only need to lose 2 which is a good bet it's the servitors (combined to the Enginseer IF they continue) and the Regimental Advisors (combined to command squads if they stay at all). That would give us the 66. Thing is, 3 of those datasheets are the Combat Patrol version of Rough Riders, Kasrkin and Command Squad. So it's 63 "actual" datasheets and 5 lost units in total. Additionally, the Aquillons are currently a WarCom download, but they may be reprinted in the Codex. If so, then you need to lose 6 units to make the space. LSM 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077989 Share on other sites More sharing options...
Emperor Ming Posted November 27, 2024 Share Posted November 27, 2024 Are combat patrol datasheets even in codexs? Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077992 Share on other sites More sharing options...
TheMawr Posted November 27, 2024 Share Posted November 27, 2024 Honestly with the Krieg ( who I hadnt even commented on yet, I like them more than I'd expected.. I never thought they fit 40k very well, more games like dust etc. but now they do, more so than some other guard elements... reiterating; for my taste/interpretation of 40k.) its an even bigger shame that wyrdvane bit the dust. They where always a psyker unit that for me tied guard better into the setting (together with actual priests leading the guardsmen into battle in some iconic art pieces, even if the actual models never conveyed that vibe.) Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077993 Share on other sites More sharing options...
Indy Techwisp Posted November 27, 2024 Share Posted November 27, 2024 7 minutes ago, Emperor Ming said: Are combat patrol datasheets even in codexs? They're not in the Codex, but they are in the Datacard Pack, which has 66 cards. So you take the Datacard Pack's 66, remove the 3 Datasheets for the Combat Patrol and you get the 63 datasheets for the Codex. LSM and Emperor Ming 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6077998 Share on other sites More sharing options...
Mogger351 Posted November 27, 2024 Share Posted November 27, 2024 26 minutes ago, Inquisitor_Lensoven said: Nothing needs to be removed. the marine codex proves they have no problem having bloated codexes. that being said I could definitely see servitors being removed since they were introduced before admech existed, and they don’t really fit in the faction Them being ok with bloated books doesn't mean it's smart or correct to do so Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078002 Share on other sites More sharing options...
Focslain Posted November 27, 2024 Share Posted November 27, 2024 27 minutes ago, Indy Techwisp said: Thing is, 3 of those datasheets are the Combat Patrol version of Rough Riders, Kasrkin and Command Squad. So it's 63 "actual" datasheets and 5 lost units in total. Additionally, the Aquillons are currently a WarCom download, but they may be reprinted in the Codex. If so, then you need to lose 6 units to make the space. Didn't think the CP datasheets would count as that seems a bit wierd to me, but confirmed it's how they do the count (via the BA datacard descript). My 61 count included the Aquuillons btw. I just counted what was on the app. So that would be 6 new. Adding Sgt Harker and the priest to my list of possible cuts. Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078008 Share on other sites More sharing options...
sairence Posted November 27, 2024 Share Posted November 27, 2024 38 minutes ago, Inquisitor_Lensoven said: Nothing needs to be removed. the marine codex proves they have no problem having bloated codexes. that being said I could definitely see servitors being removed since they were introduced before admech existed, and they don’t really fit in the faction It has nothing to do with a bloated codex. We know how many datasheets there will be because they said as much on the reveal stream. So, considering we know how much new is coming and how much currently exists, something will go. ThaneOfTas 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078010 Share on other sites More sharing options...
Indy Techwisp Posted November 27, 2024 Share Posted November 27, 2024 (edited) 22 minutes ago, Focslain said: My 61 count included the Aquuillons btw. I just counted what was on the app. So that would be 6 new. Adding Sgt Harker and the priest to my list of possible cuts. Harker, Stracken, Sly Marbo, the Regimental Attache and the Servitors are all Finecast/Resin minis, so are easy guesses to be removed (tho not 100% certainties, as Trazyn and the Firestrike Marksman can attest to). Edited November 27, 2024 by Indy Techwisp Focslain and Emperor Ming 2 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078017 Share on other sites More sharing options...
Orange Knight Posted November 28, 2024 Share Posted November 28, 2024 19 hours ago, Inquisitor_Lensoven said: Nothing needs to be removed. the marine codex proves they have no problem having bloated codexes. I think the Marine codex needs a massive clear out and streamlining! Lots of units need to be culled, lots more need to be consolidated into a single datasheet. Casual Heresy, Emperor Ming, Metzombie and 2 others 2 3 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078114 Share on other sites More sharing options...
Evil Eye Posted November 28, 2024 Share Posted November 28, 2024 1 minute ago, Orange Knight said: I think the Marine codex needs a massive clear out and streamlining! Lots of units need to be culled, lots more need to be consolidated into a single datasheet. Orange Knight, this is the 15th time you've shown "All the classic Marines need to be removed" in class show-and-tell. DemonGSides, ThaneOfTas, SteveAntilles and 4 others 1 6 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078115 Share on other sites More sharing options...
Orange Knight Posted November 28, 2024 Share Posted November 28, 2024 11 minutes ago, Evil Eye said: Orange Knight, this is the 15th time you've shown "All the classic Marines need to be removed" in class show-and-tell. I also think the Primaris range needs massive consolidation across a lot of units! Emperor Ming and Casual Heresy 2 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078118 Share on other sites More sharing options...
AutumnEffect Posted November 28, 2024 Share Posted November 28, 2024 19 hours ago, Indy Techwisp said: Instead, I think the Ogryn Bodyguard unit (basically a 3rd build option of Ogryns and Bullgryns) will be leaving. I also think the Ogryn Bodyguard will be going. They have gotten rid of some of the other 'character in box' units like the Tyranid Prime (non-winged) and Neurothrope. I also don't think I've ever seen an army in person or online that ever fielded Nork or an Ogryn Bodyguard so I don't think they will be missed. Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078119 Share on other sites More sharing options...
Emperor Ming Posted November 28, 2024 Share Posted November 28, 2024 30 minutes ago, Orange Knight said: I also think the Primaris range needs massive consolidation across a lot of units! Absolutely Do they all need their own datasheet Captain with feathered hat Captain with feathered hat with extra feathers and so on Many units could have consolidated datasheets with loadout options added. Orange Knight, ThaneOfTas, AutumnEffect and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078123 Share on other sites More sharing options...
Evil Eye Posted November 28, 2024 Share Posted November 28, 2024 54 minutes ago, Emperor Ming said: Absolutely Do they all need their own datasheet Captain with feathered hat Captain with feathered hat with extra feathers and so on Many units could have consolidated datasheets with loadout options added. Ah, but then you might be able to equip a Captain with a feathered hat AND pocket watch! And they don't have a model for that, so that's no good! I'd agree that the Marine 'dex could stand some consolidation of units, and I've always been of the opinion that few datasheets with many options is infinitely superior to multiple bespoke datasheets with few options (I will never forgive what they did to Tyranid Warriors). For instance, they could give Intercessors the ability to take a special and heavy weapon (1 of each per squad) and make them fully interchangeable with Tactical Marines. There really is no reason to have a rules distinction between Primaris and Firstborn anymore at the individual Marine level; at this point it would be better if they just made the Firstborn v Primaris difference purely aesthetic. Let any Marine ride in any transport (except Terminators obviously), make bolters the same regardless of who's using them, get rid of the absurd character restrictions on joining units. Re: Krieg, it's a shame that the new Malcador isn't allowed to be used in 40K (I think), it'd go very nicely with the new Kriegers. apologist, Emperor Ming, ThaneOfTas and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078133 Share on other sites More sharing options...
redmapa Posted November 28, 2024 Share Posted November 28, 2024 Quote it's a shame that the new Malcador isn't allowed to be used in 40K They are not Legends yet, they're in the Imperial Armor download section along with most Krieg stuff and other tanks like Carnodons or Trojan support vehicle, granted they are worse than a Rogal Dorn but I would gladly play a Malcador heavy list so fingers crossed the rules remain right where they are and not turned to legends, worst case scenario I'll proxy my one Malcador and any other I get as Dorns. Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078148 Share on other sites More sharing options...
Orange Knight Posted November 28, 2024 Share Posted November 28, 2024 1 hour ago, Evil Eye said: Ah, but then you might be able to equip a Captain with a feathered hat AND pocket watch! And they don't have a model for that, so that's no good! I'd agree that the Marine 'dex could stand some consolidation of units, and I've always been of the opinion that few datasheets with many options is infinitely superior to multiple bespoke datasheets with few options (I will never forgive what they did to Tyranid Warriors). For instance, they could give Intercessors the ability to take a special and heavy weapon (1 of each per squad) and make them fully interchangeable with Tactical Marines. There really is no reason to have a rules distinction between Primaris and Firstborn anymore at the individual Marine level; at this point it would be better if they just made the Firstborn v Primaris difference purely aesthetic. Let any Marine ride in any transport (except Terminators obviously), make bolters the same regardless of who's using them, get rid of the absurd character restrictions on joining units. Re: Krieg, it's a shame that the new Malcador isn't allowed to be used in 40K (I think), it'd go very nicely with the new Kriegers. I understand that GW want to only allow models that can be properly represented. Still, things like a Captain can still be consolidated into one datasheet. Just make a list of every single wargear combination possible on one page, and list mutliple profiles for different armour types. AutumnEffect and Emperor Ming 2 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078153 Share on other sites More sharing options...
Orange Knight Posted November 28, 2024 Share Posted November 28, 2024 28 minutes ago, redmapa said: They are not Legends yet, they're in the Imperial Armor download section along with most Krieg stuff and other tanks like Carnodons or Trojan support vehicle, granted they are worse than a Rogal Dorn but I would gladly play a Malcador heavy list so fingers crossed the rules remain right where they are and not turned to legends, worst case scenario I'll proxy my one Malcador and any other I get as Dorns. I'm not holding my breath. I already got burned by the Spartan. I bought one specifically for my 40k Fist army. The model looks perfect too, it's so big and the kit is just superb. And yet for some reason, it's a Legend unit. We waited so long for iconic Forgeworld units to become plastic, and just as they did GW decided to seperate the range even more. The best looking tracked vehicles available to the Marines are the Forgeworld designs too, and with those gone I'm fully on board with the Grav tanks. redmapa, crimsondave, phandaal and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078157 Share on other sites More sharing options...
Robbienw Posted November 28, 2024 Share Posted November 28, 2024 Just switch to 30k mate. Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078158 Share on other sites More sharing options...
Orange Knight Posted November 28, 2024 Share Posted November 28, 2024 14 minutes ago, Robbienw said: Just switch to 30k mate. I have a fully painted 30k Legion, over 4k points. And no one in my local scene plays the game.... Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078163 Share on other sites More sharing options...
Indy Techwisp Posted November 28, 2024 Share Posted November 28, 2024 So speaking of the KREIG BOXSET, it seems a little strange for the Engineers to not have been doubled up. I get having a Deathriders focus with the new character, but there's a noticeable lack of infantry in the boxset for the army known for infantry. Emperor Ming, skylerboodie and Aarik 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384659-krieg-boxset/page/7/#findComment-6078214 Share on other sites More sharing options...
