Firedrake Cordova Posted January 28, 2025 Share Posted January 28, 2025 If you're worried about control, you could probably paint the Apethecary White into the recesses, as they're fairly well-defined (you could also use multiple thinner coats to build up the effect). It's possible that the "contrast effect" might not be so strong over the paint you used, so that might also go some way to mitigating that. ZeroWolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091001 Share on other sites More sharing options...
hd3 Posted January 29, 2025 Author Share Posted January 29, 2025 Thanks Cordova! I might just try that. Meanwhile, I have applied the agrax wash. I was so thrilled with how it looked that I wanted to show you all. PHS, Firedrake Cordova and ZeroWolf 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091186 Share on other sites More sharing options...
ZeroWolf Posted January 29, 2025 Share Posted January 29, 2025 Do love a good agrax wash, nice work. Firedrake Cordova and hd3 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091200 Share on other sites More sharing options...
Firedrake Cordova Posted January 29, 2025 Share Posted January 29, 2025 Looks like it came out well ZeroWolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091214 Share on other sites More sharing options...
hd3 Posted January 31, 2025 Author Share Posted January 31, 2025 So I tried the ushabti bone but it just didn't blend well at all. It was a really really sharp transition. So I redid the colours and tried putting apothecary white right on top of the agrax. Honestly, I don't think it looks terrible but to me it doesn't look quite...cloth like. I'm not sure how to fix it though. Maybe a mix of grey and ushabti with agrax over it? Any suggestions? Â I also started adding lead belcher on the gun and picking out more of the metallic details. For the skull icon stop the powerpack, I'm thinking retributor armor underneath with either highlights of canoptek alloy or maybe a dry brush of a lighter gold. ZeroWolf and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091764 Share on other sites More sharing options...
ZeroWolf Posted January 31, 2025 Share Posted January 31, 2025 Hmm I can see your point. You could try the grey-bone mix but maybe also try more thin layers to build up the transitions through glazing? Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091796 Share on other sites More sharing options...
hd3 Posted January 31, 2025 Author Share Posted January 31, 2025 19 minutes ago, ZeroWolf said: Hmm I can see your point. You could try the grey-bone mix but maybe also try more thin layers to build up the transitions through glazing? Think layers of gray with agrax over you mean? Honestly I kinda wish I'd stopped after the agrax the first time. That looked closer to cloth, albeit dirty cloth Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091800 Share on other sites More sharing options...
Firedrake Cordova Posted January 31, 2025 Share Posted January 31, 2025 (edited) I think it's one of those cases where the more you interfere with it, the more of a problem you'll make. Â Â You could re-do the base coat (carefully, using thinned paint to ensure you don't sacrifice the detail) and have another go. Â If you're trying to blend, it's generally advisable to use really thin, transparent paint, and build up opacity through several layers, each covering a bit less area. You could also mix the two colours to get a half-way tone, to reduce the jump between the colours. Edited January 31, 2025 by Firedrake Cordova Tallarn Commander and ZeroWolf 2 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091828 Share on other sites More sharing options...
ZeroWolf Posted January 31, 2025 Share Posted January 31, 2025 2 hours ago, hd3 said: Think layers of gray with agrax over you mean? Honestly I kinda wish I'd stopped after the agrax the first time. That looked closer to cloth, albeit dirty cloth Yeah, that's what I meant  Live and learn  Painting is all about experimentation. Cloth can be tricky depending on what the end result is your after. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6091830 Share on other sites More sharing options...
hd3 Posted February 1, 2025 Author Share Posted February 1, 2025 I might try that and if it fails just our agrax over it and call it a day.  I'm also trying to figure out how best to replicate the colours on the iron halo on top of the power pack. I thought maybe retributor armour with reikland fleshshade wash to make it a tad more amber, then old gold/liberator sporadically highlighted to give it contrast. Then probably nuln oil or nuln gloss on the skull. ZeroWolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092005 Share on other sites More sharing options...
ZeroWolf Posted February 1, 2025 Share Posted February 1, 2025 I think that looks likely to how it's been achieved, leaving the wash in the recesses. I almost want to say that a final (very thin) silver highlight is added at the tips of the points and edges. Bit hard to see clearly in the picture. Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092027 Share on other sites More sharing options...
hd3 Posted February 2, 2025 Author Share Posted February 2, 2025 I got invited to try kill team for the first time so I rushed my heavy intercessor to get him ready for game day. Picking out all the rivets with runefang steel was harder than it looks. I went with eshin gray for the deathwatch? veteran symbol in the right shoulder and flayed one flesh for the skull. I dunno why but the eye lenses in the blood ravens feel so much easier. Maybe the tesseract glow flows so much more easily. Then just a single spot of warp lightning in the corner for depth. Next decals and basing.  I'm gonna try to duplicate the pre made bases I bought as much as I can. So stirland, glue a few shrubs and rocks, thern valhallan blizzard.       phandaal, Grotsmasha, Tallarn Commander and 2 others 3 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092089 Share on other sites More sharing options...
ZeroWolf Posted February 2, 2025 Share Posted February 2, 2025 Really nice job there. Looks like you got that golden bit on the power pack where you wanted it. Yeah the rivets can be a right pain Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092105 Share on other sites More sharing options...
Dr_Ruminahui Posted February 3, 2025 Share Posted February 3, 2025 It looks a lot like retributor with some golden griffon (a GW specific drybrush paint) over it, leaving some of the original colour at the connection points. Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092440 Share on other sites More sharing options...
hd3 Posted February 4, 2025 Author Share Posted February 4, 2025 I'm just so excited to share that I finally got o use the tiny crusade icon on the shoulder that I had to show off. I also added a little nuln to the iron halo on the powerpack. Grotsmasha, Firedrake Cordova, phandaal and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092468 Share on other sites More sharing options...
ZeroWolf Posted February 4, 2025 Share Posted February 4, 2025 Glorious hd3 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092562 Share on other sites More sharing options...
hd3 Posted February 5, 2025 Author Share Posted February 5, 2025 (edited) So I got the day off and stayed up the night prior as well to finally finish painting my Eliminators for a break. I managed to get everything done except the evil sunz highlights on two of them. I used mechancium, eshin and administratum grey to make triangles on the capes and copied my gun formula for the sniper rifles.  This was also my first real attempt at doing my own faces. The sergeant (bald) came out ok but the other two look a bit cartooonish to me, especially around the eyes. Luckily, their faces are mostly obscured by their hoods so I don't think anyone will notice.   Finally, I decided to try using that leftover sand I had from my army painter kit as a foundation for thy bases, instead of the normal stirland battlemire. Honestly, I thought it was far too bright so I went heavy with the valhallan blizzard to cover it up. I figure that makes sense in terms of basing consistency as the snipers would range farther out into the snow than the regular troops.  Next time, just the bright red highlights, the blizzard and blood ravens decal to go.  P.S This unit is number IV because it was the fourth blood ravens unit I started  P.P.S I might need to tidy up the belts with rhinox hide a little too.  Edited February 5, 2025 by hd3 Dr_Ruminahui, Tallarn Commander, ZeroWolf and 3 others 3 3 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092674 Share on other sites More sharing options...
Firedrake Cordova Posted February 5, 2025 Share Posted February 5, 2025 The camo came out nicely  Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092702 Share on other sites More sharing options...
hd3 Posted February 5, 2025 Author Share Posted February 5, 2025 42 minutes ago, Firedrake Cordova said: The camo came out nicely  Yeah the camo is what I am most happy with while the eye is the worst. Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092709 Share on other sites More sharing options...
ZeroWolf Posted February 5, 2025 Share Posted February 5, 2025 I feel your pain with the faces, I still can't get them right  I'll echo the comments about the camo, reminds me that I've got my own eliminators to do...and phobos Librarian hd3 and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6092741 Share on other sites More sharing options...
hd3 Posted February 7, 2025 Author Share Posted February 7, 2025 (edited) I added a hazard stripe to one of the cables on the heavy intercessor though I might use a little extra Abaddon black later to make the yellow segments more angular. I also painted the little bit of terrain at the foot. I wanted to make sure the shell casing was the same colour as the rounds you can see in the chamber. I still need to wash them with agrax though.   I also added the snow effects to the remaining Eliminators. Zerowolf was right, this stuff is tremendous for easy winter details. It just sets and freezes rigid in place. I'm interested to see how it goes on the other bases once I start moving onto bases where I don't want 100 percent snow.  I also added the evil sunz edge highlights. In retrospect, actually I think the eyes aren't too bad on the sergeant and the crouching sniper. It's just the one with the raised eliminator rifle that really looks off. He looks internally terrified like he just realized he forgot his passport as he's about to board the plane. Edited February 7, 2025 by hd3 ZeroWolf, phandaal, Grotsmasha and 5 others 5 3 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6093182 Share on other sites More sharing options...
ZeroWolf Posted February 9, 2025 Share Posted February 9, 2025 That's some good looking Blood Ravens   Glad you've found success with Valhallan Blizzard! The snow helps to make the red armour pop more Firedrake Cordova and hd3 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6093735 Share on other sites More sharing options...
hd3 Posted February 10, 2025 Author Share Posted February 10, 2025 13 hours ago, ZeroWolf said: That's some good looking Blood Ravens   Glad you've found success with Valhallan Blizzard! The snow helps to make the red armour pop more  Thanks zero. Unrelated, my blood ravens were victorious over the iron warriors in my first ever killteam game! Firedrake Cordova, Grotsmasha, Dr_Ruminahui and 1 other 1 3 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6093848 Share on other sites More sharing options...
ZeroWolf Posted February 10, 2025 Share Posted February 10, 2025 Well played! A nice set of gallowdark terrain there as well Firedrake Cordova and Tallarn Commander 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6093910 Share on other sites More sharing options...
hd3 Posted February 10, 2025 Author Share Posted February 10, 2025 Finishing up the primaris Lieutenant. I made sure to only use bronzes of various shades, starting with warplock on the knees and brighter Balthazar gold on the skulls. He's not a captain but he is an officer so he should have bling but not too much. I also did the skull on the chest aquilla in Balthazar.  The one place real gold appears is the primaris vambrace. Finally for the neo-volkite pistol I did gryph hound orange over corax white. Then canoptek alloy on top of the coils before more gryph orange.  I'm undecided what to write on the banner on the officer pauldron. Does anyone know what a traditional Lt. pauldron says? Otherwise, I'll add probably just pick something fitting in high gothic. Alas, I don't think "omnishambles" will fit. Tallarn Commander, ZeroWolf and Grotsmasha 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384743-guard-it-well-a-patrol-log/page/3/#findComment-6093977 Share on other sites More sharing options...
