Chapter Master Valrak Posted December 9, 2024 Share Posted December 9, 2024 Did a rumour video today (linked below for those who want the waffle), I've heard through the Whispers that they're getting some type of Robot battle unit with their release. It does kind of make sense because in a White Dwarf a few months back they got a story of sending them to the Pariah Nexus. Spoiler Shinespider, Brother Borgia, N1SB and 6 others 7 2 Back to top Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/ Share on other sites More sharing options...
Indy Techwisp Posted December 9, 2024 Share Posted December 9, 2024 TSons getting some kind of Battle robot, huh? LSM, dalmer, phandaal and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6079984 Share on other sites More sharing options...
Ahzek451 Posted December 9, 2024 Share Posted December 9, 2024 Indeed, that's what this stuff should be about: Dark Shepherd, LSM, Xenith and 14 others 12 2 3 Back to top Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6079985 Share on other sites More sharing options...
Ramell Posted December 9, 2024 Share Posted December 9, 2024 Mecha-Tzaangor Marshal Rohr, Tokugawa, Bev'an and 20 others 23 Back to top Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6079996 Share on other sites More sharing options...
-DonCorleone- Posted December 9, 2024 Share Posted December 9, 2024 (edited) New daemon characters are coming as well huh. There are still resin characters to be made in plastic for each god. Khorne - Skullmaster Tzeentch - Fluxmaster Nurgle - Epidemius Slaanesh - Tranceweaver/Viceleader Edited December 9, 2024 by -DonCorleone- Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080032 Share on other sites More sharing options...
Marshal Rohr Posted December 9, 2024 Share Posted December 9, 2024 1 hour ago, Ramell said: Mecha-Tzaangor You joke, but this is what it is. Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080034 Share on other sites More sharing options...
Indy Techwisp Posted December 9, 2024 Share Posted December 9, 2024 Just now, Marshal Rohr said: You joke, but this is what it is. Ideally not, but with GW you can never be sure... Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080035 Share on other sites More sharing options...
Indy Techwisp Posted December 9, 2024 Share Posted December 9, 2024 10 minutes ago, -DonCorleone- said: New daemon characters are coming as well huh. There are still resin characters to be made in plastic for each god. Khorne - Skullmaster Tzeentch - Fluxmaster Nurgle - Epidemius Slaanesh - Tranceweaver/Viceleader You missed the Blue Scribes for Tzeentch. Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080037 Share on other sites More sharing options...
TheMawr Posted December 9, 2024 Share Posted December 9, 2024 So with those rumor engines Im leaning heavily towards orks (or Necromunda wildcard as always), but aside from that: the "leg" ( as Im not sure if it even is a leg currently.) is very small, when looking closely it also seems to be all one piece, I think its a robotic/peg leg for a "normal" size character... or even a weird shoulder mounted contraption, with us actually seeing a bald head or top of a bare shoulder on the rumor engine. ( though it could also be a skull on the base, because if its a leg its standing on a rock.) the mechanical claw too is not very big it also has two notable things, an attached very rough flamerthing attached to it and a flesh/cloth element on the top right. Honestly, if those rumor engines are for TS, I think the mecha-tzaangor joke would be close actually, but I dont think its TS. I think GW wouldnt lean into a "human" sized ramshackle cyborg look for Thousand sons automatons, it would be a little bit out of place stylistically and the smaller size would compete with what rubric marines already are... Id expect bigger robots, and Id expect the trademark tzeentch decoration on it. I think the magical gun rumor engine could be related though, maybe. Would be interesting if its just one unit or there will also be a TS "tech"marine to go with it.. actually thinking about that the "leg" rumor engine could be related to the latter if its a shoulder mounted element, because that screw design Ive seen on two things only ( Ork mech suits, specifically the Big mek and Ghazkull, and the two primaris techmarine models... though the design is a little bit different there.) Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080048 Share on other sites More sharing options...
TheMawr Posted December 9, 2024 Share Posted December 9, 2024 (edited) 38 minutes ago, Indy Techwisp said: You missed the Blue Scribes for Tzeentch. I think blue scribes are purged, they are not in the AoS battletomes index anymore, wich they would probably remain in if they got plastic miniatures this AoS edition edit: Same for epidemus I believe. And the only reason the other "resin ones" are still there might be because they can be made from other plastic models. I personally think the daemons coming will be new offerings, rather than updates. Edited December 9, 2024 by TheMawr Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080049 Share on other sites More sharing options...
Indy Techwisp Posted December 9, 2024 Share Posted December 9, 2024 12 minutes ago, TheMawr said: Would be interesting if its just one unit or there will also be a TS "tech"marine to go with it.. actually thinking about that the "leg" rumor engine could be related to the latter if its a shoulder mounted element, because that screw design Ive seen on two things only ( Ork mech suits, specifically the Big mek and Ghazkull, and the two primaris techmarine models... though the design is a little bit different there.) TSons do have unique "Techmarines" from Horus Heresy, those being the Numerologists. No model ('cause HH) but they're basically just a Techmarine. LSM 1 Back to top Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080052 Share on other sites More sharing options...
Hathor42 Posted December 9, 2024 Share Posted December 9, 2024 The actual books for nurgle and Tzeentch aren't out yet in AOS so there's still a chance they could come back in plastic. Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080087 Share on other sites More sharing options...
jaxom Posted December 9, 2024 Share Posted December 9, 2024 Once GW had the new CAD files for HH ‘bots, it’d have been real simple to make 40k TSon versions off of them. Tokugawa 1 Back to top Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080092 Share on other sites More sharing options...
INKS Posted December 9, 2024 Share Posted December 9, 2024 please let space hulk be true, please let space hulk be true, please let space hulk be true, please let space hulk be true, please let space hulk be true, please let space hulk be true Ming the Merciless 1 Back to top Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080131 Share on other sites More sharing options...
AlanofAngels Posted December 9, 2024 Share Posted December 9, 2024 ALL IS DUST Cenobite Terminator, dalmer and Brother Carpenter 3 Back to top Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080134 Share on other sites More sharing options...
Xenith Posted December 10, 2024 Share Posted December 10, 2024 The similarity is there: It looks like it could maybe be a stripped down Whateverax this is? Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080195 Share on other sites More sharing options...
Jscarlos18 Posted December 10, 2024 Share Posted December 10, 2024 29 minutes ago, Xenith said: The similarity is there: It looks like it could maybe be a stripped down Whateverax this is? Yeah, that seems to be the unit from the rumour engine. Would have to see how changed it has become from being Warp-tainted. Link to comment https://bolterandchainsword.com/topic/384778-thousand-son-rumour/#findComment-6080206 Share on other sites More sharing options...
