EmprahsStrongestGuardsman Posted December 12, 2024 Share Posted December 12, 2024 I got a Krieg Commissar from Ebay, he has a fairly thin coat of paint on him. I was just wondering if nail varnish remover WITHOUT acetone is safe to use on this. If not I might just paint over it. Link to comment https://bolterandchainsword.com/topic/384808-forgeworld-resin-paint-stripping-acetone-free-nail-varnish-remover/ Share on other sites More sharing options...
Sothalor Posted December 12, 2024 Share Posted December 12, 2024 Nail varnish remover still seems like it'd be harsher than I'd want to try (I don't have any proof or experience, just gut intuition here). I'd start with soaking the piece in a Simple Green solution first. I've had good results with Simple Green in the past when it comes to working with FW resin pieces.. Soak for an hour or so, give it a scrub with an old toothbrush, and see what kind of progress that makes. Re-soak and re-scrub as needed. Link to comment https://bolterandchainsword.com/topic/384808-forgeworld-resin-paint-stripping-acetone-free-nail-varnish-remover/#findComment-6080776 Share on other sites More sharing options...
Corswain Posted December 12, 2024 Share Posted December 12, 2024 I've also had good results with Dettol if that's available in your country. Link to comment https://bolterandchainsword.com/topic/384808-forgeworld-resin-paint-stripping-acetone-free-nail-varnish-remover/#findComment-6080789 Share on other sites More sharing options...
Firedrake Cordova Posted December 13, 2024 Share Posted December 13, 2024 (edited) Not answering your question directly as I've never tried what you're asking about, but I've seen others get good results from AK Interactive and Green Stuff World's paint strippers. I'm guessing that if you don't already have them, it makes the Commissar a bit expensive, but mentioning it just in case it's helpful. Edited December 13, 2024 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/384808-forgeworld-resin-paint-stripping-acetone-free-nail-varnish-remover/#findComment-6080842 Share on other sites More sharing options...
EmprahsStrongestGuardsman Posted December 13, 2024 Author Share Posted December 13, 2024 Well I went ahead with it. I had a bit of FW resin spare, a chunk that bits of the Krieg command squad came attached to, and I dunked that in nail varnish remover for a while, prodded it every so often. It didn't go soft or flaky or rubbery. So I dunked the Commissar, his paint flaked off immediately and I quickly scrubbed him with a toothbrush, running him under water every 30 seconds or so. He seems fine. However, he now smells very strongly of perfume, so perhaps a bad idea overall suggesting as it does the nefarious influence of Slaanesh... Firedrake Cordova, Bryan Blaire and Oxydo 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384808-forgeworld-resin-paint-stripping-acetone-free-nail-varnish-remover/#findComment-6080966 Share on other sites More sharing options...
Sky Potato Posted December 15, 2024 Share Posted December 15, 2024 (edited) I dunked a Forgeworld resin gate in a tub of Biostrip as a test once. The Biostrip did nothing to the resin, there was no deformation, warping or damage to the resin - and Biostrip is brilliant at removing paint. Edited December 15, 2024 by Sky Potato Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384808-forgeworld-resin-paint-stripping-acetone-free-nail-varnish-remover/#findComment-6081150 Share on other sites More sharing options...
Firedrake Cordova Posted December 15, 2024 Share Posted December 15, 2024 On 12/13/2024 at 9:29 PM, EmprahsStrongestGuardsman said: However, he now smells very strongly of perfume, so perhaps a bad idea overall suggesting as it does the nefarious influence of Slaanesh.. Plot twist - they really are a follower of Slaanesh sent to corrupt your Krieg to the Dark Powers, and removing the paint released the smell ... have you got another Commissar or Inquisitor to watch over this one? EmprahsStrongestGuardsman 1 Back to top Link to comment https://bolterandchainsword.com/topic/384808-forgeworld-resin-paint-stripping-acetone-free-nail-varnish-remover/#findComment-6081175 Share on other sites More sharing options...
EmprahsStrongestGuardsman Posted December 15, 2024 Author Share Posted December 15, 2024 Worry not citizen, an application of the Emperor's Most Holy Undercoat Spray has sealed the Daemonic influence once and for all. Commissar Coconut Oil's faith in the Emperor is unwavering. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384808-forgeworld-resin-paint-stripping-acetone-free-nail-varnish-remover/#findComment-6081229 Share on other sites More sharing options...
