Osteoclast Posted December 23, 2024 Share Posted December 23, 2024 Wish there were some more bodies in it but looks fun. Agramar_The_Luna_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082558 Share on other sites More sharing options...
Ultra kblock Posted December 23, 2024 Share Posted December 23, 2024 This is a nice kit. It would be even better if it was not just heads, but also some tyranid limbs or some arms with weapons still attached. Alby the Slayer, AutumnEffect and Mostwanted 3 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082563 Share on other sites More sharing options...
Corswain Posted December 23, 2024 Share Posted December 23, 2024 Not a single tactical rock!?!? Apart from that glaring omission this is a nice little surprise. Dark Shepherd, Dr_Ruminahui and Kurgan the Lurker 3 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082568 Share on other sites More sharing options...
Marshal Reinhard Posted December 23, 2024 Share Posted December 23, 2024 And I had been thinking i had about a hundred bases or so that needed more detail Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082573 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted December 23, 2024 Share Posted December 23, 2024 3 hours ago, Deus_Ex_Machina said: These heads don´t have a ball. I guess you need to add one made of Green Stuff to work. Yeah, I had already thought about that. Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082581 Share on other sites More sharing options...
Firedrake Cordova Posted December 23, 2024 Share Posted December 23, 2024 It looks like a nice kit. It's a shame the example images just have the skull glued onto the base, instead of being "embedded" into it to give a more immersive appearance (i.e. sand part of it down, or cut it in two so it looks like it's embedded in the ground and only part of it is showing). 3 hours ago, darkhorse0607 said: Wonder if the old skull only set is going away I'd hope not - it can be used in all of GW's systems. bloodhound23 1 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082585 Share on other sites More sharing options...
Nephaston Posted December 23, 2024 Share Posted December 23, 2024 (edited) 3 hours ago, Agramar_The_Luna_Wolf said: Yes! The extras I was looking for!Awesome! Some even can used as damaged headgear! Article says 288 bits to put on the base, so assuming that is the number post assembly (like the whole torso) this only depicts 184 bits. Meaning we still have yet to see 104 more bits. Even if the torso somehow counted as 5 bits we'd still have a hundred bits yet to be revealed. Edited December 23, 2024 by Nephaston Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082586 Share on other sites More sharing options...
bloodhound23 Posted December 23, 2024 Share Posted December 23, 2024 16 minutes ago, Nephaston said: Article says 288 bits to put on the base, so assuming that is the number post assembly (like the whole torso) this only depicts 184 bits. Meaning we still have yet to see 104 more bits. Even if the torso somehow counted as 5 bits we'd still have a hundred bits yet to be revealed. Is it possible that just means multiples of a particular set of bits? skylerboodie, Firedrake Cordova and Corswain 3 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082590 Share on other sites More sharing options...
Nephaston Posted December 23, 2024 Share Posted December 23, 2024 25 minutes ago, bloodhound23 said: Is it possible that just means multiples of a particular set of bits? The only way that would work is if we had three sprues, one unique and two identical ones. But the article says it is two sprues, which also means that the ones already depicted are more than one sprue, but not both sprues completely, since 184 is way more that half of 288. So unless they copy pasted some bits on the sprue itself, which is definitely possible, we're talking 288 unique bits. Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082601 Share on other sites More sharing options...
Marshal Reinhard Posted December 23, 2024 Share Posted December 23, 2024 1 hour ago, Nephaston said: So unless they copy pasted some bits on the sprue itself, which is definitely possible, I don't see them not doing this. I'd expect certain bits to be doubled, perhaps even more than once. Like the skulls. Certain ones, like the marine torso, will only feature once. The previously mentioned pack of skulls has certain bits repeated many many times. This one has a larger variety of unique bits, so the repetition will be less. But I would expect we've seen every unique bit on these images. Firedrake Cordova and skylerboodie 2 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082623 Share on other sites More sharing options...
The Praetorian of Inwit Posted December 23, 2024 Share Posted December 23, 2024 This looks really good. I'll pick up at least one, maybe a second at a later date. I look forward to decorating the bases of my Imperial Fists. Firedrake Cordova and DemonGSides 2 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082649 Share on other sites More sharing options...
HeadlessCross Posted December 24, 2024 Share Posted December 24, 2024 7 hours ago, Corswain said: Not a single tactical rock!?!? Apart from that glaring omission this is a nice little surprise. Isn't a skull the ultimate tactical rock? Corswain and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082661 Share on other sites More sharing options...
Deus_Ex_Machina Posted December 24, 2024 Share Posted December 24, 2024 12 hours ago, Chapter Master Valrak said: Very nice! All I want them to remake now is the fallen Space Marines for new objective markers! Good thinking! Then at last Chestnut can do his job which is not possible right now with the torsos Gee-Dubbs deemed suitable for gene-seed recovery. Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082674 Share on other sites More sharing options...
Emperor Ming Posted December 24, 2024 Share Posted December 24, 2024 (edited) Depends on le price as they say in france prob £25ish Edited December 24, 2024 by Emperor Ming Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082675 Share on other sites More sharing options...
Evil Eye Posted December 24, 2024 Share Posted December 24, 2024 Between this and Pete Harrison's Dead Animal Bits kit, it's a good time for people wanting dismembered corpses for their models! Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082682 Share on other sites More sharing options...
sbarnby71 Posted December 24, 2024 Share Posted December 24, 2024 Really liking these, I'm a big fan of the old skulls set. Good to see what looks like Space Marine size skulls and a return of my all time fav, the ork jaw-bone, I use these to make lower face masks for my Marines. Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082722 Share on other sites More sharing options...
Dark Shepherd Posted December 24, 2024 Share Posted December 24, 2024 Chapeau to Auspex Tactics for this idea: full sprue wasnt shown off to hide the Emperors Children helmet on the sprue Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082724 Share on other sites More sharing options...
Casual Heresy Posted December 24, 2024 Share Posted December 24, 2024 I love this! Exactly the kind of thing I want for making bases a little extra. I would love them to do a gothic urban rubble set in the same vein as well. Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082726 Share on other sites More sharing options...
Jukkiz Posted December 24, 2024 Share Posted December 24, 2024 This set tickles my brain in weird, but good, way~~ Bev'an, Cactus, Casual Heresy and 2 others 2 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082727 Share on other sites More sharing options...
TheVoidDragon Posted December 24, 2024 Share Posted December 24, 2024 20 hours ago, TheMawr said: Even in death Drukhari and grey knights are ignored ( Not being serious ) At least those are remembered enough to realize they've not been included in the set! The Leagues of Votann though... skylerboodie 1 Back to top Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082733 Share on other sites More sharing options...
Alby the Slayer Posted December 24, 2024 Share Posted December 24, 2024 This is so unexpected and it's great! So many interesting pieces. I bought 3 of the "old" skulls set but this is even better! So much variety, ogryn skulls, xenos skulls and even servo-skulls! Amazing. Link to comment https://bolterandchainsword.com/topic/384886-battlefield-trophies-set/page/2/#findComment-6082743 Share on other sites More sharing options...
