INKS Posted January 2, 2025 Share Posted January 2, 2025 Pro acryl is my preferred paint then ak then fanatic what are the colors being used for the genestealer flesh and carapace i can see its like some kind of purple and dark blue? But not sure on shades N1SB 1 Back to top Link to comment https://bolterandchainsword.com/topic/384976-genestealer-colors-pro-acryl/ Share on other sites More sharing options...
Bryan Blaire Posted January 2, 2025 Share Posted January 2, 2025 (edited) Monument PA Blue Alien Skin Tutorial: https://monumenthobbies.com/blogs/methodologies/methodology-26-blue-alien-skin There may be a short or stream with that in it on YouTube, but can’t find t off-hand. Purple metal short might be of interest, but you would probably want to tone down the specularity/reflection/bright points for a more living material, unless you wanted to give a more metallic or super high gloss feel to the carapace: Edited January 2, 2025 by Bryan Blaire Firedrake Cordova and INKS 2 Back to top Link to comment https://bolterandchainsword.com/topic/384976-genestealer-colors-pro-acryl/#findComment-6084419 Share on other sites More sharing options...
N1SB Posted January 2, 2025 Share Posted January 2, 2025 I tried something and it turned out pretty interesting: Zenithal basecoat with just a very matte black then a very matte white. The purple-pink flesh was GW Carroburg Crimson Shade. The bluey carapace is GW Drakenhof Nightshade Shade. Some white drybrush. In short, it's just a Zenithal basecoat with 2 Shades/inks. Brother Inks, are you planning a Space Hulk-themed project? Firedrake Cordova and INKS 2 Back to top Link to comment https://bolterandchainsword.com/topic/384976-genestealer-colors-pro-acryl/#findComment-6084472 Share on other sites More sharing options...
INKS Posted January 2, 2025 Author Share Posted January 2, 2025 Gsc to start. But a new space hulk would be most welcome N1SB and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384976-genestealer-colors-pro-acryl/#findComment-6084485 Share on other sites More sharing options...
Bryan Blaire Posted January 5, 2025 Share Posted January 5, 2025 (edited) INKS, saw on the Monument Hobbies stream yesterday someone asked a specific question about edge highlighting a purple Nid carapace, so thought you might be interested (assuming it wasn’t you and you haven’t already heard this): Time stamp is right round 1:11:00 for the question and answer (ends about 1:13:30) - thought it was applicable and a neat discussion on the color thought behind selecting some highlight colors. One thing I’ve done starting in the last year and a half or so is to always have my paint journal (an actual physical heavy off-white ring-bound paper set) when I’m mixing my paints to record mixes that I really like and want to repeat - I fill the square with the mid-tone, record the mix, and then paint my highlighting colors (with recorded mixes) and my shadow color(s) in the block above (or I will fill two squares with the mid-tone and paint across both) so I can see practically exactly what the colors do over each other. I was painting some zombies and really like using Rakarth Flesh for that, and ended up stumbling across a mix that looks enough like Rakarth Flesh for me to use it with ProAcryl - 1 Red Grey:2 Warm Flesh:1 Bright Neutral Grey. I then highlighted it up with a 1 drop White Blue and shaded down mixing in a drop of Mahogany (for zombies, I like the cold highlights, but warm shadows to give it more of a dead tone). I like the ProAcryl results better than mixing with GW paints because I feel like the results are more consistent over all from being able to predict what a mix is going to look like better to the actual consistency of the paint itself. Hope that helps and if my ramble at the end was interesting, cool ( and maybe someone likes the paint recipe)! Edited January 5, 2025 by Bryan Blaire INKS and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384976-genestealer-colors-pro-acryl/#findComment-6085024 Share on other sites More sharing options...
INKS Posted January 5, 2025 Author Share Posted January 5, 2025 It was not me, but I really appreciate this, thank you Bryan Blaire 1 Back to top Link to comment https://bolterandchainsword.com/topic/384976-genestealer-colors-pro-acryl/#findComment-6085026 Share on other sites More sharing options...
Bryan Blaire Posted January 5, 2025 Share Posted January 5, 2025 (edited) Jason/Slowfuse actually did a good discussion on mixing of colors all the way through to almost 1:32:00 - I like the concepts involved and doing my own color mixing now, getting away from GW’s triad system, so I think that if anyone is interested as well, give at least that chunk of this video a watch. Edited January 5, 2025 by Bryan Blaire Firedrake Cordova and INKS 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384976-genestealer-colors-pro-acryl/#findComment-6085030 Share on other sites More sharing options...
INKS Posted January 5, 2025 Author Share Posted January 5, 2025 Yeah, super insightful and helpful. 100% Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384976-genestealer-colors-pro-acryl/#findComment-6085039 Share on other sites More sharing options...
