hd3 Posted January 3, 2025 Share Posted January 3, 2025 There are quite a few resin HH models I want to add as proxies and some 3d printed models that will also be resin I was hoping to add to my army. But I've only ever used plastic cement because I've only made plastic models so far. What's the best glue to use for resin models? Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/ Share on other sites More sharing options...
Mithrilforge Posted January 3, 2025 Share Posted January 3, 2025 First off - wash the models in warm soapy water...or all your painting will be for naught... Any Cyanoacrylate glue (super glue) will suffice, some are thin and some are thicker consistency. don't buy the dollar store one, go for a mid range priced glue. Cheers, Mithril Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084672 Share on other sites More sharing options...
hd3 Posted January 3, 2025 Author Share Posted January 3, 2025 33 minutes ago, Mithrilforge said: First off - wash the models in warm soapy water...or all your painting will be for naught... Any Cyanoacrylate glue (super glue) will suffice, some are thin and some are thicker consistency. don't buy the dollar store one, go for a mid range priced glue. Cheers, Mithril Like gorilla glue? Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084675 Share on other sites More sharing options...
AutumnEffect Posted January 3, 2025 Share Posted January 3, 2025 I use this after I saw some tests that showed Loctite was the strongest super glue (at least in that test) and I love the squeeze bottle. Makes things muuuuch more convenient. I've never looked back. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084676 Share on other sites More sharing options...
Khulu Posted January 3, 2025 Share Posted January 3, 2025 Gorilla Glue gel(blue cap, clear liquid) works very well for me, at long asthe model is washed. I use it for 3d prints and FW resin. It's on the thick side, though, so I have other glues for whenit needs to be thinner. Mithrilforge and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084677 Share on other sites More sharing options...
NovemberIX Posted January 3, 2025 Share Posted January 3, 2025 I used to use loctite before switching to Cyapro medium viscosity, I'd say both are pretty good, though these days I do prefer Cyapro for the price. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084678 Share on other sites More sharing options...
Grotsmasha Posted January 3, 2025 Share Posted January 3, 2025 Any super glue works well, but the real secret to a really secure bond on resin, whether it's cast or printed, is sanding both sides of the join (sanding stick, nail file etc). W.A.Rorie and Mithrilforge 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084680 Share on other sites More sharing options...
hd3 Posted January 3, 2025 Author Share Posted January 3, 2025 33 minutes ago, Grotsmasha said: Any super glue works well, but the real secret to a really secure bond on resin, whether it's cast or printed, is sanding both sides of the join (sanding stick, nail file etc). I thought sanding resin was supposed to be toxic to something? Or is that just a scurrilous rumour to trick me into buying GW plastic? Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084681 Share on other sites More sharing options...
Grotsmasha Posted January 3, 2025 Share Posted January 3, 2025 *Technically* yes. HOWEVER, that warning is meant for commercial volume. At consumer volume of dust there's no more risk vs. sanding GWs regular plastic. Best practice for both is eye protection and a mask for BOTH Xenith, Mithrilforge and W.A.Rorie 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084682 Share on other sites More sharing options...
hd3 Posted January 3, 2025 Author Share Posted January 3, 2025 2 minutes ago, Grotsmasha said: *Technically* yes. HOWEVER, that warning is meant for commercial volume. At consumer volume of dust there's no more risk vs. sanding GWs regular plastic. Best practice for both is eye protection and a mask for BOTH Regular cheap flu face mask ok? Also do glasses count as eye protection? For the join, how smooth so I need to make the join? Should I use my metal Tamiya file I use on plastic or a cheap disposable nail file? Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084683 Share on other sites More sharing options...
Grotsmasha Posted January 3, 2025 Share Posted January 3, 2025 (edited) I use a regular flu mask, and I have those hardware-style wrap-around protective glasses. Rough, you want it rough vs smooth, it gives the glue more surface area, and a deeper hold in the pieces. I use the rough side of one of those foam nail files. edit: I also have a pedestal fan, and when I'm sanding, I turn it around with its back to me, this sucks any of the smallest particles away and out my door. Edited January 3, 2025 by Grotsmasha W.A.Rorie, sbarnby71 and Khulu 3 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084684 Share on other sites More sharing options...
sbarnby71 Posted January 3, 2025 Share Posted January 3, 2025 For me cheap super glue works great. Make sure you only apply to one surface/part you're bonding and keep the layer of glue thin. Also I never apply directly to model, I have a scrap piece of plastic I put the glue on, then use a steel dental pick to dip into the glue and apply it with more accuracy. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084687 Share on other sites More sharing options...
Xenith Posted January 3, 2025 Share Posted January 3, 2025 (edited) Superglue for FW and 3d print resin as said, great tips from grot about sanding, something I'm guilty of not doing. If you paint in sub assemblies, you might want to scrape the paint away from the join as otherwise you'll be gluing paint to paint, and the paint-paint bond will be stronger than the paint-model bond, and they will come apart - best to stick model to model, and with a slightly roughened surface so the glue can 'key' in. Edited January 5, 2025 by Xenith Mithrilforge and W.A.Rorie 2 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084704 Share on other sites More sharing options...
Firedrake Cordova Posted January 3, 2025 Share Posted January 3, 2025 (edited) 5 hours ago, hd3 said: I thought sanding resin was supposed to be toxic to something? It's supposed to be quite nasty for the lungs (it's pretty fine and an irritant at least). Any of the (K)N95/FFP2 masks should filter it out. Obviously, there are significantly less risks if you're assembling one infantry model, as opposed to a Warlord titan, so proportionate measures and all that. ++EDIT: You could also try wet-sanding. The wet file/glass paper should "capture" the majority of the dust (you will likely end up with a smoother surface as the water will reduce the "cut" of the abrasive a bit). Edited January 3, 2025 by Firedrake Cordova W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084707 Share on other sites More sharing options...
Evil Eye Posted January 3, 2025 Share Posted January 3, 2025 One other thing you CAN do is a trick called "resin welding". Decant a very, very small amount of 3D resin (preferably the same you used to print the model) and using an old brush spread it onto the surface as you would with glue. Join the parts, then blast it with a UV curing lamp, and it'll set the resin solid. Depending on the joint it might be best to superglue it first and then fill any gaps with resin-welding, to avoid any chance of pockets of uncured resin (which can offgas and crack the joint open again) but for gap-filling it's pretty great. Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084778 Share on other sites More sharing options...
hd3 Posted January 4, 2025 Author Share Posted January 4, 2025 On 1/3/2025 at 1:45 PM, AutumnEffect said: I use this after I saw some tests that showed Loctite was the strongest super glue (at least in that test) and I love the squeeze bottle. Makes things muuuuch more convenient. I've never looked back. Autumn has sold me on giving loctite a try. Im so sick of opening a new super glue and it immediately drying up and gunking. I've also had a lot of bad luck with gorilla glue frosting. Firedrake Cordova, Mithrilforge and AutumnEffect 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084876 Share on other sites More sharing options...
Grotsmasha Posted January 4, 2025 Share Posted January 4, 2025 I use dollar bottles with brush applicator for infantry sized models, and have done so for years Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084886 Share on other sites More sharing options...
Arikel Posted January 4, 2025 Share Posted January 4, 2025 11 hours ago, hd3 said: Autumn has sold me on giving loctite a try. Im so sick of opening a new super glue and it immediately drying up and gunking. I've also had a lot of bad luck with gorilla glue frosting. Gorilla glue gel for sure will frost plastic, but it is very easy to work with. Generally use gorilla glue liquid instead now for plastic, no issues. The liquid glue worked for the resin chaplain I worked on, haven’t tried the gel with resin yet. Link to comment https://bolterandchainsword.com/topic/384988-what-is-the-strongest-glue-for-3d-resin-printed-models/#findComment-6084961 Share on other sites More sharing options...
