Focslain Posted January 8, 2025 Share Posted January 8, 2025 (edited) 1 hour ago, Inquisitor_Lensoven said: It should be noted there’s a difference between being in cover, and having the effect of cover. if rule says it ignores cover, imho that doesn’t mean it ignores special rules that provide the effect of cover, unless there’s a rule somewhere that I’m currently unaware of that says otherwise. Actually Ignore Cover does remove Benefit of Cover regardless of where the unit gets it from. Just that all references of Benefit of Cover refer back to the terrain ability so it doesn't need to be written out multiple times. They also cover this in the rules commentary (pg 18 of the pdf). Edited January 8, 2025 by Focslain 2 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6085992 Share on other sites More sharing options...
DemonGSides Posted January 8, 2025 Share Posted January 8, 2025 50 minutes ago, Inquisitor_Lensoven said: The BRB clearly states the primary rule is in regard to terrain. pg44 of the BRB’s rule section ”models can sometimes gain a measure of protection from terrain features” this is a special rule, not terrain. What does the Ability say? It says confers the Benefit of Cover (capitalization is important. It denotes a rule). Go on and look up what Benefit of Cover means in the BRB. I'll wait. You can come back and admit you're wrong and we can all move on. Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6085994 Share on other sites More sharing options...
TheArtilleryman Posted January 8, 2025 Share Posted January 8, 2025 (edited) Anyone know if the Medusa and Earthshaker carriages are still going to be in the codex? Was surprised they were in the index tbh but I see they have got a lot of use in tournaments and they are cool models. Edited January 8, 2025 by TheArtilleryman Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6085999 Share on other sites More sharing options...
sairence Posted January 8, 2025 Share Posted January 8, 2025 19 minutes ago, TheArtilleryman said: Anyone know if the Medusa and Earthshaker carriages are still going to be in the codex? Was surprised they were in the index tbh but I see they have got a lot of use in tournaments and they are cool models. They won't be in the codex, because they're FW models. They're currently in the Imperial Armour index, not in the main Astra Militarum index. So until the IA index gets updated they'll stay exactly as they are now. Probably best to mentally prepare for a good amount of those older FW resin kits to get legend'd. 2 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086001 Share on other sites More sharing options...
DemonGSides Posted January 8, 2025 Share Posted January 8, 2025 21 minutes ago, TheArtilleryman said: Anyone know if the Medusa and Earthshaker carriages are still going to be in the codex? Was surprised they were in the index tbh but I see they have got a lot of use in tournaments and they are cool models. I'm assuming the Imperial Armor index will just stay the same, but there isn't anyone else with the same level of FW support that was still supported going into the edition so it's hard to lean on precedence. Space Marines got to keep the Astraeus and the Thunder hawk, and Custodes got to keep damn near everything. Meanwhile, Tau were gutted, as were Necrons. So its tough to say outright. That being said, the new artillery piece is a pretty good facsimile, could run the old versions and call em that and I wouldn't be mad. Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086003 Share on other sites More sharing options...
TheArtilleryman Posted January 8, 2025 Share Posted January 8, 2025 Thanks for the info. I didn’t realise it wasn’t in the main index - I’m surprised then that tournaments have allowed these to be used. I remember seeing a few lists that were leaving heavily into use of Medusas and the reinforcements strategem. I was thinking of picking up a couple of earthshaker carriages because I like them better than the basilisk. Might still anyway, because rule of cool. 1 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086004 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 8, 2025 Share Posted January 8, 2025 1 hour ago, DemonGSides said: What does the Ability say? It says confers the Benefit of Cover (capitalization is important. It denotes a rule). Go on and look up what Benefit of Cover means in the BRB. I'll wait. You can come back and admit you're wrong and we can all move on. Show me where it says it doesn’t. the recon rule also says the rule stacks which the BRB explicitly states it doesn’t, so clearly the rule doesn’t work the same as the core rule. Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086012 Share on other sites More sharing options...
Emperor Ming Posted January 8, 2025 Share Posted January 8, 2025 2 hours ago, Inquisitor_Lensoven said: The BRB clearly states the primary rule is in regard to terrain. pg44 of the BRB’s rule section ”models can sometimes gain a measure of protection from terrain features” this is a special rule, not terrain. Ah, don't read the rulebook, its mostly been replaced by the 60+ pages of rulebook errata and commentary If i had a £1 for every time that comes up......... But the rulebook sates...... Ah, but did you check errata p45, section 3 paragraph.. 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086016 Share on other sites More sharing options...
DemonGSides Posted January 9, 2025 Share Posted January 9, 2025 Gonna put this here and probably also in the other thread. These are the points from the back of the new book; legitimately useless as far as figuring out what things cost, but good for giving us an idea of what's still in the book. Good bye, regimental advisors :( 1 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086111 Share on other sites More sharing options...
Focslain Posted January 9, 2025 Share Posted January 9, 2025 43 minutes ago, DemonGSides said: Gonna put this here and probably also in the other thread. These are the points from the back of the new book; legitimately useless as far as figuring out what things cost, but good for giving us an idea of what's still in the book. Good bye, regimental advisors :( This is only half the list and doesn't confirm the lose of the advisors. Granted I'm sure they are gone. But need the full list first. Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086125 Share on other sites More sharing options...
SteveAntilles Posted January 9, 2025 Share Posted January 9, 2025 Whole thing, no advisors. No Straken or Harker either. 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086128 Share on other sites More sharing options...
sairence Posted January 9, 2025 Share Posted January 9, 2025 Full image: No more Advisors, Sentinels down to 1-2. Marbo somehow survives, that absolute hero. 1 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086129 Share on other sites More sharing options...
Focslain Posted January 9, 2025 Share Posted January 9, 2025 (edited) Thanks guys. So Hammer of the Emperor is looking to be the Tank Company detachment. Hoping LRBT gain battleline in it? Edited January 9, 2025 by Focslain 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086134 Share on other sites More sharing options...
DemonGSides Posted January 9, 2025 Share Posted January 9, 2025 30 minutes ago, Focslain said: This is only half the list and doesn't confirm the lose of the advisors. Granted I'm sure they are gone. But need the full list first. Just forwarded what a friend sent, glad the full thing is out. Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086148 Share on other sites More sharing options...
Emperor Ming Posted January 9, 2025 Share Posted January 9, 2025 Well that will stop the endless spam and rampage of the sentinel spam lists Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086149 Share on other sites More sharing options...
TheArtilleryman Posted January 9, 2025 Share Posted January 9, 2025 41 minutes ago, sairence said: Full image: No more Advisors, Sentinels down to 1-2. Marbo somehow survives, that absolute hero. What are the last few things on the page with the light washing it out? 1 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086153 Share on other sites More sharing options...
SteveAntilles Posted January 9, 2025 Share Posted January 9, 2025 1 minute ago, TheArtilleryman said: What are the last few things on the page with the light washing it out? Ursula Creed, Valkyrie, Wyvern 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086155 Share on other sites More sharing options...
Emperor Ming Posted January 9, 2025 Share Posted January 9, 2025 Shame the battle cannon is still ap1 Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086179 Share on other sites More sharing options...
DemonGSides Posted January 9, 2025 Share Posted January 9, 2025 It got two more strength over where it was in 9th, which gives it the better to wound over the targets it's aiming at over S8. S8 LRBT feels so weak in hindsight. Happy to leave it at -1 with how easy it is for IG to find extra AP. Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086216 Share on other sites More sharing options...
Tokugawa Posted January 9, 2025 Share Posted January 9, 2025 New siege cannon is somehow a modified medusa cannon(125 pts). It would possibly replace the latter, which go retirement. So the cost can't be 75pts when it is online. 100+ pts is a reasonable guess. Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086290 Share on other sites More sharing options...
Emperor Ming Posted January 10, 2025 Share Posted January 10, 2025 1 hour ago, Tokugawa said: New siege cannon is somehow a modified medusa cannon(125 pts). It would possibly replace the latter, which go retirement. So the cost can't be 75pts when it is online. 100+ pts is a reasonable guess. I wouldn't pay 75 Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6086302 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 21, 2025 Share Posted January 21, 2025 (edited) Does the armored fist detachment have a mount up stratagem in it? edit found the auspex video on it. i am generally disappointed by this detachment. i feel the detachment rule is a little bit…meh. id have preferred something like this were the rule transports within 3” of an infantry unit gets +1 to wound and infantry gets reroll 1s after disembarking. Edited January 21, 2025 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6089211 Share on other sites More sharing options...
Galron Posted January 21, 2025 Share Posted January 21, 2025 +1 to wound when dismounting is far better than +1 to hit. We have orders to buff our shooting ability but very little that buffs wounding. Granted, its legends, but my 25 man Death Korps blob disembarking from a Gorgon with either the first rank fire second rank fire or the +1 to hit order is going to hurt something, especially if backed up by something else with 5 men in it. Or 5 man engineer squad hopping out of a Centaur after it scouted, moved and advanced with shotguns and flamers :) sure AP sucks but if I already used the grenade strat elsewhere. If you live somewhere they dont allow legends, that sucks for you but I am getting use out of my chunks of resin. 3 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6089364 Share on other sites More sharing options...
Inquisitor_Lensoven Posted January 21, 2025 Share Posted January 21, 2025 51 minutes ago, Galron said: +1 to wound when dismounting is far better than +1 to hit. We have orders to buff our shooting ability but very little that buffs wounding. Granted, its legends, but my 25 man Death Korps blob disembarking from a Gorgon with either the first rank fire second rank fire or the +1 to hit order is going to hurt something, especially if backed up by something else with 5 men in it. Or 5 man engineer squad hopping out of a Centaur after it scouted, moved and advanced with shotguns and flamers :) sure AP sucks but if I already used the grenade strat elsewhere. If you live somewhere they dont allow legends, that sucks for you but I am getting use out of my chunks of resin. Good thing I didn’t say anything about +1 to hit. the detachment rule is very situational. Either you’re using a lot of CP to jump back in the transport out of sequence, or you’re wasting time disembarking and reembarking to get the benefit. a mechanized detachment should encourage transports and infantry supporting each other, rather than just a random unexplainable ‘weapons get stronger for a second or two after leaving a transport.’ 3 Back to top Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6089374 Share on other sites More sharing options...
DemonGSides Posted January 21, 2025 Share Posted January 21, 2025 (edited) Who cares if your Chimera gets +1 to wound? That's worthless. +1 to wound on a unit of Kasrkin or Scions dumping out of their respective expected transports is way more powerful and meaningful than your the transport being slightly better at getting their anemic damage through. Reroll 1's is fine but even that isn't very exciting. Bridgehead is probably just the better version of it, though, that's for sure. Mechanized Assault is one of the meh detatchments. Edited January 21, 2025 by DemonGSides Link to comment https://bolterandchainsword.com/topic/385016-platoon-command-squad-and-platoon-infantry-squads-gone/page/3/#findComment-6089380 Share on other sites More sharing options...
