Helias_Tancred Posted January 14, 2025 Share Posted January 14, 2025 Subject line says it all. Painted up one Imperial Fist to go in one of my Black Templar intercessor squads, and I finished him and was applying decals and ... UGGGGHHHH ..... the Maize Yellow Speedpaints have had over two days to dry. Still reactivated it enough for a yellow sheen to get on the decals and the white area around the knee. I did a slap chop method for his armor using Maize Yellow Speedpainter 2.0 for the power armor. If I ever do another one it will be the traditional method using standard acrylics. This is sorta BS imo. I only used contrast and speed paints for very technical uses. I'll stick to that. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/ Share on other sites More sharing options...
W.A.Rorie Posted January 14, 2025 Share Posted January 14, 2025 Did you do a clear coat before decals? Firedrake Cordova and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087216 Share on other sites More sharing options...
Grotsmasha Posted January 14, 2025 Share Posted January 14, 2025 Should definitely be doing a Gloss Varnish over paint before decals. It gives a smoother surface for you to place and position the decal, and it protects the underlying paintwork. Marshal Loss, beefeb, crimsondave and 5 others 1 7 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087221 Share on other sites More sharing options...
Cadmus Tyro Posted January 14, 2025 Share Posted January 14, 2025 Also, try and carefully mop up any excess, as it pools in the recesses it will react with the paint. I generally find contrast type paints to have pretty poor durability, rubbing off to expose the base primer whilst handling. Cadmus Helias_Tancred, Firedrake Cordova and crimsondave 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087225 Share on other sites More sharing options...
Sky Potato Posted January 14, 2025 Share Posted January 14, 2025 I've had Micro Sol and Set take off regular Citadel acrylics, never mind the generally much less durable Contrast paints. I've never used Speedpaints, after all the talk of re-activating, I probably won't either. You absolutely need to be applying gloss varnish before putting decals down. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087316 Share on other sites More sharing options...
crimsondave Posted January 14, 2025 Share Posted January 14, 2025 I agree with the others about a varnish. I’ve put decals on top of regular acrylics but I usually even varnish over that. I definitely would varnish over contrast paint first. PeteySödes and Helias_Tancred 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087334 Share on other sites More sharing options...
Helias_Tancred Posted January 14, 2025 Author Share Posted January 14, 2025 14 hours ago, W.A.Rorie said: Did you do a clear coat before decals? Yes. Vallejo polyurethane matte varnish from the bottle. W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087357 Share on other sites More sharing options...
Grotsmasha Posted January 14, 2025 Share Posted January 14, 2025 How long after the Speed Paint did you apply the varnish? I'm just hypothesizing, but if it was before the Speed Paint was 100% dry, rather than covering the Speed Paint it mixed a little and that is what's reactivated? I also don't know if it's because it's a matte vs satin vs gloss varnish? Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087366 Share on other sites More sharing options...
Mana Posted January 15, 2025 Share Posted January 15, 2025 1 hour ago, Helias_Tancred said: Yes. Vallejo polyurethane matte varnish from the bottle. In tale of painters review of the new game color paints review is the following: ".... Polyurethane varnishes are more durable, but more aggressive and can reactivate Inks, Contrast and Xpress Colors as well as washes and Shade paints and also damage decals." source: https://taleofpainters.com/2023/01/review-new-vallejo-game-color-range-now-for-pro-painters-only/ So maybe that's what happend. If you use vallejo products, you can buy the varnishes from the new model color range, those are water based and I never had a problem. Hope this helps. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087369 Share on other sites More sharing options...
Helias_Tancred Posted January 15, 2025 Author Share Posted January 15, 2025 (edited) 1 hour ago, Mana said: In tale of painters review of the new game color paints review is the following: ".... Polyurethane varnishes are more durable, but more aggressive and can reactivate Inks, Contrast and Xpress Colors as well as washes and Shade paints and also damage decals." source: https://taleofpainters.com/2023/01/review-new-vallejo-game-color-range-now-for-pro-painters-only/ So maybe that's what happend. If you use vallejo products, you can buy the varnishes from the new model color range, those are water based and I never had a problem. Hope this helps. LOL ... well now I know. Thanks for that! I also have a bottle of the regular vallejo matt varnish (not with polyurethane in the title) .. lol looks like I used the wrong one? It's even funnier because my LGs where I got the polyurethane matte varnish from, they specifically said the normal acrylic one is garbage compared to the polyurethane one I bought from them! I've always used the water based one too with no problems! I also just recently picked up the W&N Galeria matte varnish too! Any knowledge of that? I saw it on a Youtube painter's channel, the guy swore by it. Edited January 15, 2025 by Helias_Tancred W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087374 Share on other sites More sharing options...
Firedrake Cordova Posted January 15, 2025 Share Posted January 15, 2025 It's probably worth adding that Vallejo's polyurethane varnish is still water-based. It might not be relevant, but I seem to remember there being some re-branding of the varnishes, with some words being added/removed from the names when the new branding was applied (it looks like the two varnishes shown above are from the Model Colour [70.x] and Game Colour [72.x] lines, respectively). I guess if in doubt, ask Vallejo? Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087395 Share on other sites More sharing options...
Cadmus Tyro Posted January 15, 2025 Share Posted January 15, 2025 I tend to use Vallejo Rattle can varnish, it seems pretty durable. I’ve found airbrush varnishes are generally better as finishing product, rather than providing protection. The other thing I’ve used in the past is a hand painted layer of “Ard coat”. Can leave a slight irregularity to the surface though. Cadmus Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6087416 Share on other sites More sharing options...
Helias_Tancred Posted January 20, 2025 Author Share Posted January 20, 2025 Well ... I'm doing a second Imperial Fist that has been seconded to my Black Templars and after trying another method (I didn't like it) I'm back to doing the slap-chop armor method with an Averlund Sunset base, then dry brush this time with a heavy amount of Phalanx Yellow, then Corax White, then use Army Painter Speed paints 2.0 Maize Yellow. He looks great, but this time I MUST have him sealed with varnish before the final step of putting the decals on him because that Micro-Sol reactivates the speed paint a bit :( Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385072-uggghhhh-micro-sol-sorta-reactivates-speedpaints/#findComment-6088914 Share on other sites More sharing options...
