Valkyrion Posted January 22, 2025 Share Posted January 22, 2025 Without mangling your mini? Resin and metal you can often gently 'snap' off due to the superglue, but if you've polycemented your tactical marine to your black plastic circle, what do? Link to comment https://bolterandchainsword.com/topic/385137-how-to-rebase-painted-minis/ Share on other sites More sharing options...
Grotsmasha Posted January 22, 2025 Share Posted January 22, 2025 Clippers really are your best bet. clip as close as you can around the feet, then tidy up with a knife. Then using a nail file, sand the base off the feet. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385137-how-to-rebase-painted-minis/#findComment-6089488 Share on other sites More sharing options...
TwinOcted Posted January 22, 2025 Share Posted January 22, 2025 I just did this last night. It was on square base minis, but it should still work for you. I snipped off the base rim with clippers and filed the bottom of the base smooth, then glued it onto the new base. You can then build up around the raised area with a basing texture of your choice so it doesn't look too obvious. Alternatively, you can keep snipping the base until it's all gone, but I was a bit too lazy for that . Hope this helps. Khulu, Firedrake Cordova and Grotsmasha 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385137-how-to-rebase-painted-minis/#findComment-6089489 Share on other sites More sharing options...
Chaplain Raeven Posted January 22, 2025 Share Posted January 22, 2025 Snipping of the base around the mini with huge clippers and sanding the rest off with a coarse grit or use a scroll saw to saw of the soles of the mini. Plenty of options if you don't care about the original base. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385137-how-to-rebase-painted-minis/#findComment-6089491 Share on other sites More sharing options...
Khulu Posted January 22, 2025 Share Posted January 22, 2025 37 minutes ago, TwinOcted said: I just did this last night. It was on square base minis, but it should still work for you. I snipped off the base rim with clippers and filed the bottom of the base smooth, then glued it onto the new base. You can then build up around the raised area with a basing texture of your choice so it doesn't look too obvious. Alternatively, you can keep snipping the base until it's all gone, but I was a bit too lazy for that . Hope this helps. This is what I did, and it worked pretty well. Firedrake Cordova, TwinOcted and sbarnby71 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/385137-how-to-rebase-painted-minis/#findComment-6089492 Share on other sites More sharing options...
Dr_Ruminahui Posted January 22, 2025 Share Posted January 22, 2025 If it isn't on a tactical rock and you don't want to demolish the base, you might be able to get the edge of an exacto style hobby knife between the model and the base and then then cutting between the two - you might lose a tiny bit of the bottom of the foot, but unlikely enough to be visible. This obviously works best if the contact area is small - doesn't really work if you are trying to remove a tactical rock, for example. I did this recently with my lord discordant when I wanted to get at the bottom of the model mid painting, and it worked quite well as its connection points were the bottom of 6 very pointy legs. Would be a lot harder if it had wider feet, like say a dreadnought. Khulu and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/385137-how-to-rebase-painted-minis/#findComment-6089619 Share on other sites More sharing options...
Khulu Posted January 22, 2025 Share Posted January 22, 2025 40 minutes ago, Dr_Ruminahui said: If it isn't on a tactical rock and you don't want to demolish the base, you might be able to get the edge of an exacto style hobby knife between the model and the base and then then cutting between the two - you might lose a tiny bit of the bottom of the foot, but unlikely enough to be visible. This obviously works best if the contact area is small - doesn't really work if you are trying to remove a tactical rock, for example. I did this recently with my lord discordant when I wanted to get at the bottom of the model mid painting, and it worked quite well as its connection points were the bottom of 6 very pointy legs. Would be a lot harder if it had wider feet, like say a dreadnought. I have done this before, and sometimes it worked great, but as you say it depends on the model. Doing this with Necron infantry just broke a lot of ankles, for instance, but heftier stuff worked much better. Huge contact points like rocks are not something I had to deal with as much, though. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385137-how-to-rebase-painted-minis/#findComment-6089635 Share on other sites More sharing options...
