Galron Posted January 25, 2025 Share Posted January 25, 2025 Is there a rule somewhere that says you cant shoot overwatch at something if you are a vehicle or monster and are engaged in close combat? I cant find anything, but I have seen several TableTop Titans episodes where they specifically mention this on their live stream and it has come up in games in the past or like today when I charged a ghost keel with a raider and incubi. Link to comment https://bolterandchainsword.com/topic/385166-overwatch-while-engaged-in-combat/ Share on other sites More sharing options...
Dr_Ruminahui Posted January 26, 2025 Share Posted January 26, 2025 You can't - Big Guns Never Tire only applies in the Shooting phase. That was "clarified" in the FAQ section of the Rules Commentary - its at page 12. Not the conclusion I would have come to based on the rules without the explanation, but BGNT is strong enough, IMHO, without it also allowing overwatch. m-p-constructions, Emperor Ming, Galron and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/385166-overwatch-while-engaged-in-combat/#findComment-6090489 Share on other sites More sharing options...
DemonGSides Posted January 26, 2025 Share Posted January 26, 2025 (edited) Yeah Big Guns Never Tire specifically mentions that it only works in the shooting phase. If you're searching the app, look for "Out of phase rules". Edited January 27, 2025 by DemonGSides Dr_Ruminahui, Galron and Xenith 3 Back to top Link to comment https://bolterandchainsword.com/topic/385166-overwatch-while-engaged-in-combat/#findComment-6090561 Share on other sites More sharing options...
m-p-constructions Posted February 2, 2025 Share Posted February 2, 2025 The Out of Phase Rule is one of the most unintuitive rules in the game in my opinion. You really have to wrap your head arround it to internalise the mechanic. I am reading different forums existing worldwide and the most questions repeatedly posted refer to OoP. I hope to the next edition will come up with somthing to iron this out. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385166-overwatch-while-engaged-in-combat/#findComment-6092101 Share on other sites More sharing options...
Darwhine Posted February 6, 2025 Share Posted February 6, 2025 Hello, I am taking advantage of the subject to ask the question: is it possible to overwatch after an enemy unit has finished its charge or does it have to be done at the declaration and before the movement of the models? If it is possible to overwatch at the end of a charge movement, is it possible for me to overwatch with pistols a unit that has just charged one of my units? Link to comment https://bolterandchainsword.com/topic/385166-overwatch-while-engaged-in-combat/#findComment-6092940 Share on other sites More sharing options...
Dr_Ruminahui Posted February 6, 2025 Share Posted February 6, 2025 (edited) Yes, as per the overwatch stratagem on page 42 of the Core Rules, it can be used on one unit of yours that would be eligible to shoot in the shooting phase, at one enemy unit at the start or end of a Normal, Advance, Fall Back or Charge move. My struck out answer was wrong due to changes in Balance Dataslate - see below for the correct answer - thanks for the correction, @Darwhine. Edited February 8, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385166-overwatch-while-engaged-in-combat/#findComment-6092943 Share on other sites More sharing options...
Darwhine Posted February 6, 2025 Share Posted February 6, 2025 I did some research and apparently there were changes in the latest dataslate: you can only overwatch in the charge phase at the charge declaration. You can no longer overwatch after the charge move. Quote WHEN: Your opponent’s Movement or Charge phase, just after an enemy unit is set up or when an enemy unit starts or ends a Normal, Advance or Fall Back move, or declares a charge.TARGET: One unit from your army that is within 24" of that enemy unit and that would be eligible to shoot if it were your Shooting phase.EFFECT: If that enemy unit is visible to your unit, your unit can shoot that enemy unit as if it were your Shooting phase.RESTRICTIONS: You cannot target a TITANIC unit with this Stratagem. Until the end of the phase, each time a model in your unit makes a ranged attack, an unmodified Hit roll of 6 is required to score a hit, irrespective of the attacking weapon’s Ballistic Skill or any modifiers. You can only use this Stratagem once per turn. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385166-overwatch-while-engaged-in-combat/#findComment-6093039 Share on other sites More sharing options...
