How to strip paint from larger models?
Go to solution Solved by Jolemai,
IMG_20250205_101217.jpg?ex=67a48b3d&is=67a339bd&hm=70ae69deb52c55887253f6ac7ed990eceb41ca678ded20c9eca380a02eb48e05&=
I recently received this handsome chap from a good friend of mine and I would like to see it repainted in the same colours of my Kreig regiment. To that end I'd like to strip a few layers of paint off if possible. The problem is, it's a pretty chunky lad and I think just pouring paint stripper into a bucket and dropping it in seems a bit wasteful. It there any other way I can do this without wasting tons of paint remover? Thanks in advance.
  • Solution
As you're UK based, I recommend this. It's thick and gloopy (so you can dollop it on and spread it around), and it's fine for resin. Give it 20-30 minutes (until you get a feeling for using it), then take a toothbrush to it. Worth pointing out that it's messy, and now available at The Range since Wilko went under.
Register a new account
Sign in
