Kaede45 Posted February 21, 2025 Share Posted February 21, 2025 I have been kitbashing a bit & had cut a few pieces to do so. I cut the chained skull & bone from a Grey Knight torso, which came off alright & cut the Imperium symbol from a Mystic’s staff, though it wasn’t as clean as I’d hoped. In both instances I used the clippers that I use for cutting the pieces out of the sprues, but I’m wondering if anyone knows of a better way that may not be as “destructive” so to speak? As always, any & all help & advice is greatly appreciated, thank you for your time & God bless! Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/ Share on other sites More sharing options...
Commissar Greif Posted February 21, 2025 Share Posted February 21, 2025 Do you have an X-acto knife? I find them great for cutting off more delicate pieces for kitbashing, plus they're good for trimming off flash, mould lines, and bits of sprue. Kaede45, jaxom and Tallarn Commander 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096196 Share on other sites More sharing options...
jaxom Posted February 21, 2025 Share Posted February 21, 2025 Scalpel style blade (x acto) and a Jewelers saw from a craft store. https://en.m.wikipedia.org/wiki/Piercing_saw I use it for anything where I want to preserve material. It makes very fine cuts and is less likely to slip off line compared to pressing down with a scalpel style blade. You may want a simple mask because the plastic dust is pretty fine. Firedrake Cordova, Kaede45 and Tallarn Commander 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096206 Share on other sites More sharing options...
Dr_Ruminahui Posted February 21, 2025 Share Posted February 21, 2025 (edited) I second the use of the jeweler's saw, which is particularly good for separating larger portions (arms, legs, heads, etc) from models. So, for example, with today's dynamic but monopose models, I find for reposing them its often easiest to build them then cut off their limbs and reposition them. Perhaps my project that made the most extensive use of my saw was giving my noise marines capes from the Fantasy Battles Chaos warriors - my tutorial for that is here. It is also by far the best tool for cutting metal models. Personally, my jeweler's saw is probably my best hobby tool. There are some things that an exacto style knife is better at, such as removing small details or relatively shallow portions of a model (for example, cutting a symbol off of a shoulder pad for use elsewhere). So, in other words, where the cut is parallels to the main surface of the model rather than perpendicular. The exacto knife is also easier (with a metal straightedge) for cutting long straight lines, so is usually better for cutting things like plasticard. Personally, I never use clippers except where I know I don't have any use for the remaining part, or to remove large chunks from a model where likewise I have no desire to reuse the removed portions. Edited February 22, 2025 by Dr_Ruminahui Kaede45, jaxom, Firedrake Cordova and 1 other 1 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096211 Share on other sites More sharing options...
Firedrake Cordova Posted February 22, 2025 Share Posted February 22, 2025 Clippers are great for cutting models out and separating things, but they often fail to leave a clean cut (requiring clean-up) or are a little inexact when looking at larger items. I'd second the suggestions for a scalpel/Xacto knife for small items, and a jewellers- or razor saw for larger items. Tallarn Commander and Kaede45 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096281 Share on other sites More sharing options...
Grotsmasha Posted February 22, 2025 Share Posted February 22, 2025 When looking at Razor/Jewelers/Hobby Saws, get one of the smaller ones that fit the xacto knife handle, this'll allow you to cut thicker pieces, as the larger saws are folded at the top for rigidity, and limit the depth you can saw through. Kaede45 and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096288 Share on other sites More sharing options...
Lord_Ikka Posted February 22, 2025 Share Posted February 22, 2025 The best razor saw that I've ever used is the JLC razor saw. It has a very thin, precise blade with two different sized teeth sides. I believe it is made in the Czech republic so it can be hard to find, but there are a few sites around that sell it, like this one. The replacement blades are actually pretty easy to order as even Amazon carries them, though not the saw itself last time I checked. Kaede45 and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096290 Share on other sites More sharing options...
Rusted Boltgun Posted February 23, 2025 Share Posted February 23, 2025 Tamiya also make a couple of useful products Handy Craft Saw Tamiya Razor Saw The razor saw is useful on larger projects such as vehicles, the smaller saw has blades that are quite thin and can flex (which can be quite useful sometimes). Kaede45 and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096455 Share on other sites More sharing options...
Bung Posted February 23, 2025 Share Posted February 23, 2025 (edited) On 2/22/2025 at 11:15 AM, Grotsmasha said: When looking at Razor/Jewelers/Hobby Saws, get one of the smaller ones that fit the xacto knife handle, this'll allow you to cut thicker pieces, as the larger saws are folded at the top for rigidity, and limit the depth you can saw through. Jewelers Saws are like this and cut nearly every thickness you may encounter in this Hobby Edited February 23, 2025 by Bung Kaede45 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096539 Share on other sites More sharing options...
jaxom Posted February 24, 2025 Share Posted February 24, 2025 16 hours ago, Rusted Boltgun said: Tamiya also make a couple of useful products Handy Craft Saw Tamiya Razor Saw The razor saw is useful on larger projects such as vehicles, the smaller saw has blades that are quite thin and can flex (which can be quite useful sometimes). 5 hours ago, Bung said: Jewelers Saws are like this and cut nearly every thickness you may encounter in this Hobby Huh, today I learned they make modeling saws similar to jeweler's saw.s Firedrake Cordova and Kaede45 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096565 Share on other sites More sharing options...
Evil Eye Posted February 24, 2025 Share Posted February 24, 2025 I'll definitely recommend the Tamiya saw. It's really good for getting clean, straight cuts on parts. I'll throw a question of my own in; does anyone have any recommendations for a saw for metal parts (including copper/brass tubes etc)? I'd rather not blunt my Tamiya saw on something it's not designed to cut. Kaede45 and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096603 Share on other sites More sharing options...
Brother Captain Vakarian Posted February 24, 2025 Share Posted February 24, 2025 The jeweler’s saw that @Bung recommended above will work for cutting metals. You can get different blades for different materials and they aren’t very expensive. I use them regularly for working on metal models (typically pewter). If you’re working on harder metals you’ll want to make sure the blades you buy are meant for the specific metal. Firedrake Cordova, Evil Eye, Kaede45 and 2 others 1 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/385363-cutting-for-kitbashing-recommendations/#findComment-6096626 Share on other sites More sharing options...
