Helias_Tancred Posted March 9, 2025 Share Posted March 9, 2025 I don't like GW's plastic glue. I don't like Army Painter's plastic glue. I'm a bit leery of the strong fumes from Tamiya thin cement ... are there any other brands worthy to try? Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/ Share on other sites More sharing options...
andes Posted March 9, 2025 Share Posted March 9, 2025 I use Tamiya extra thin for most jobs. For big joints I like Testors Model Master (though I think the Model Master brand is long gone). Be aware that all solvent (plastic) glues are going to have a chemical smell. Solvents are nasty. Either way, this stuff: Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099027 Share on other sites More sharing options...
Rusted Boltgun Posted March 9, 2025 Share Posted March 9, 2025 There is Revell Contacta Professional (in the UK/Europe at least) but it is also a bit fumey and the nozzle clogs (though it is designed so you can store it tipped to reduce the clogging potential). Revell.de Firedrake Cordova, m-p-constructions and Helias_Tancred 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099035 Share on other sites More sharing options...
Cpt_Reaper Posted March 10, 2025 Share Posted March 10, 2025 7 hours ago, Rusted Boltgun said: There is Revell Contacta Professional (in the UK/Europe at least) but it is also a bit fumey and the nozzle clogs (though it is designed so you can store it tipped to reduce the clogging potential). Revell.de The day I use anything other than Revell Contacta is the day I've been replaced with a changeling. Also on the clogged needle, I pull it out from the bottle and hold it with a set of pliers. Run a lighter over it and it'll burn the glue out. DO NOT DO THIS WITH THE NEEDLE IN THE BOTTLE. Firedrake Cordova, lhg033 and Helias_Tancred 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099061 Share on other sites More sharing options...
Grotsmasha Posted March 10, 2025 Share Posted March 10, 2025 1 hour ago, Cpt_Reaper said: The day I use anything other than Revell Contacta is the day I've been replaced with a changeling. Also on the clogged needle, I pull it out from the bottle and hold it with a set of pliers. Run a lighter over it and it'll burn the glue out. DO NOT DO THIS WITH THE NEEDLE IN THE BOTTLE. The glue dissolves itself, it's much easier to remove the tube, flip it and reinsert, then tip the glue to use it, it will take a few seconds, but will begin to flow all by itself. Brother Carpenter, m-p-constructions, Firedrake Cordova and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099068 Share on other sites More sharing options...
Grotsmasha Posted March 10, 2025 Share Posted March 10, 2025 10 hours ago, Helias_Tancred said: I don't like GW's plastic glue. I don't like Army Painter's plastic glue. I'm a bit leery of the strong fumes from Tamiya thin cement ... are there any other brands worthy to try? What is it that bugs you with GW's glue? Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099070 Share on other sites More sharing options...
Sky Potato Posted March 10, 2025 Share Posted March 10, 2025 The Tamiya extra thin quick-setting cement smells much less than the normal extra thin. Not to say it doesn't smell, just that its not as strong. Anecdotally, I can use the quick-setting glue around the wife without getting told off too much. If I use the standard Tamiya extra thin, or GW cement, she really complains. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099073 Share on other sites More sharing options...
Emperor Ming Posted March 10, 2025 Share Posted March 10, 2025 11 hours ago, Helias_Tancred said: I don't like GW's plastic glue. I don't like Army Painter's plastic glue. I'm a bit leery of the strong fumes from Tamiya thin cement ... are there any other brands worthy to try? Ditto, I've never liked gw plastic glue I've use loctite precision max on everything for over 20 years Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099076 Share on other sites More sharing options...
Urauloth Posted March 10, 2025 Share Posted March 10, 2025 Mr Hobby brand plastic glues are excellent but can be a real pain to get in the UK. Mr Cement S is similar to the Tamiya extra thin, while Mr Cement Deluxe is a brush-on goop you can use to fill small gaps as well as sticking things together (that one stinks, however). It's really hard to beat Revell Contacta as a general purpose glue though. I don't think I ever assemble plastic minis without using it somewhere. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099079 Share on other sites More sharing options...
Bung Posted March 10, 2025 Share Posted March 10, 2025 11 hours ago, Helias_Tancred said: I don't like GW's plastic glue. I don't like Army Painter's plastic glue. I'm a bit leery of the strong fumes from Tamiya thin cement ... are there any other brands worthy to try? You could try the Orange caped version with citrus scent. Its the only one the Lady of the House accepts. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099080 Share on other sites More sharing options...
Firedrake Cordova Posted March 10, 2025 Share Posted March 10, 2025 Revell Contacta is decent (and cheap), but I've found it to be quite "hot" (aggressive) and harder to control than Tamiya Extra Thin. I'm a little surprised to hear people finding the Tamiya glue to have a smell in normal use (it definitely does if you spill 30% of a bottle ) ... maybe I've gone "nose blind" crimsondave, Urauloth, Helias_Tancred and 1 other 3 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099227 Share on other sites More sharing options...
Helias_Tancred Posted March 10, 2025 Author Share Posted March 10, 2025 11 hours ago, Grotsmasha said: What is it that bugs you with GW's glue? The applicator! and you don't get much for the price either. Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099237 Share on other sites More sharing options...
Jukkiz Posted March 12, 2025 Share Posted March 12, 2025 i love this, easy application and if the metal tube gets glogged, you can just yoink it out and give it abit lighter and it should clear itself out in most cases. Others, use thin but firm metal wire after the lighter treatment. sarabando and Helias_Tancred 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099493 Share on other sites More sharing options...
Helias_Tancred Posted March 12, 2025 Author Share Posted March 12, 2025 I ordered a bottle of that stuff! Its arriving Friday and I look forward to trying it out. Firedrake Cordova and Urauloth 2 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099600 Share on other sites More sharing options...
Brother Carpenter Posted March 13, 2025 Share Posted March 13, 2025 I'm using Revell contacta as well, or UHU plastic kleber. But the metal snout of the Revell product beats all the other application tools of date I have used. I can also recommend pure thinner, do be mindful of the used amount because it will dissolve plastic, you get an almost unbreakable bond as it fuses the contact points. It also gives you great inspiration and releases your inner unrestricted artist when used in an enclosed unventilated room Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099667 Share on other sites More sharing options...
Helias_Tancred Posted March 13, 2025 Author Share Posted March 13, 2025 (edited) Been using it today [yesterday] to build a 6 man aggressor squad ... I love it! The Revell Contacta Professional Plastic Glue is the best I've used! ... the builds have been cleaner in terms of any excess glue versus using the Army Painter plastic glue. I love the metal applicator, and you get a good amount in the bottle for the price (compared to GW's pitiful offering, plus their terrible applicator). Edited March 14, 2025 by Helias_Tancred Rusted Boltgun and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099764 Share on other sites More sharing options...
Antarius Posted March 14, 2025 Share Posted March 14, 2025 (edited) On 3/10/2025 at 8:59 PM, Firedrake Cordova said: Revell Contacta is decent (and cheap), but I've found it to be quite "hot" (aggressive) and harder to control than Tamiya Extra Thin. That's pretty much why I switched to Tamiya after having used Revell for at least a decade and I don't think I'll ever go back to Revell, except maybe for terrain and stuff like that. Having said that, Revell is much better application-wise than GW and AP glues. Tamiya is just so much easier to use and yields better results, in my experience. Around here, it's about the same price as Revell too. However, both do smell quite strongly and even if they didn't, I doubt breathing them are good for you, so I always keep my workplace well-ventilated and immediately put the minis somewhere else to dry (I'm lucky enough that I have a well-ventilated conservatory-type room, but even if you don't, at least place them next to an open window). I'm not quite at the point of wearing a mask while I use it, but one of my friends do and honestly, he's probably going about this much more sensibly than me. You only get the one brain, after all. Edited March 14, 2025 by Antarius Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099858 Share on other sites More sharing options...
m-p-constructions Posted March 14, 2025 Share Posted March 14, 2025 Revell, all the time for 30+ years now. I tried different ones over the years and they all where a waist of investment for me. It´s a really old Modelling Company and i think you notice that they have lots of experience. cya Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6099889 Share on other sites More sharing options...
Ming the Merciless Posted March 15, 2025 Share Posted March 15, 2025 I really like Citadel's plastic glue, easy to apply and see how much you have left (and clear with a lighter as described) plus it smells great! Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6100096 Share on other sites More sharing options...
WARMASTER_ Posted March 16, 2025 Share Posted March 16, 2025 On 3/12/2025 at 9:49 AM, Jukkiz said: i love this, easy application and if the metal tube gets glogged, you can just yoink it out and give it abit lighter and it should clear itself out in most cases. Others, use thin but firm metal wire after the lighter treatment. This is the gold standard Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6100199 Share on other sites More sharing options...
sarabando Posted March 17, 2025 Share Posted March 17, 2025 just replaced my run out Contacta, its great. The needle applicator means it can be used accurately Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6100398 Share on other sites More sharing options...
TwinOcted Posted March 19, 2025 Share Posted March 19, 2025 On the same topic, does anyone have any recommendations for thicker plastic glue? I find it better for scenery, but GW stopped selling it ages ago. I'm in the UK, for clarity. Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6100633 Share on other sites More sharing options...
Firedrake Cordova Posted March 19, 2025 Share Posted March 19, 2025 The regular (white cap) Tamiya glue? TwinOcted 1 Back to top Link to comment https://bolterandchainsword.com/topic/385460-plastic-glues/#findComment-6100645 Share on other sites More sharing options...
