Karhedron Posted March 16, 2025 Share Posted March 16, 2025 I am considering add one or two War Walkers to my roster. Eldar have always been able to bring massed mid-strength shooting to bear with units like Avengers, Jetbikes, Shroudrunners etc. War Walkers can tag a units and further attacks against that unit get an extra point of AP. So I am wondering how best to make use of it. I am thinking about the classic Scatterlaser and Brightlance combo. The Scatter Laser provides 6 shots at decent range to tag something for other units and be sure of scoring a hit. The alternative is a missile Launcher which has even longer range and the benefit of 2 firing modes. The Brightlance is there for an extra anti-tank shot which is never going to be a bad idea. To work with this I thinking Shuricannon jetties. With Lethal Hits and Ap2 they can shred MEQs and even threaten monsters/vehicles. Adding a Warlock Skyrunner for Ignores Cover really helps too. Any other people have any thoughts? Kryczek 1 Back to top Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/ Share on other sites More sharing options...
Iron Father Ferrum Posted March 16, 2025 Share Posted March 16, 2025 I've used three, each with paired aeldari missile launchers, in my two games so far and they've given sterling service. My usage so far hinges on the following points: 1. Individual lethality is wonderful, but the Crystal Matrix giving all subsequent shooting at that target an extra pip of AP is amazing. The AML's range means I can point a missile at whatever I need, almost anywhere on a board, to ensure I can land a hit to trigger that effect. 2. AML's have been maligned for a while as a middle child of the Craftworlds' armory. Bright lances are better at anti-armor, while out vast array of shuriken weaponry can cover most anti-infantry. However, I delight in the flexibility I get from having two firing modes. The scatter laser gives you a high rate of fire for triggering the Matrix, but so can Sunburst missiles -- and those have AP baked into the profile. 3. War walkers, as much as I love them, are fragile little things. If you want to rely on having one available to trigger the Matrix, you'll need more than one or two. The AML's can help a little bit here, as the long range gives you a semi-stand off capability, but the need to play around terrain may mitigate that in turn. I've considered other warloads -- a squad of two both with paired starcannons is a nasty customer for minimum-sized Marine squads -- but I don't feel the need to put lances on them. They're just much more useful for the AP buff then for direct-damage. Karhedron and Mordekiem 2 Back to top Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6100195 Share on other sites More sharing options...
Magos Takatus Posted March 17, 2025 Share Posted March 17, 2025 I am so glad I magnetised mine. War Walkers give you so much freedom from a weapon selection perspective. Karhedron and Kryczek 2 Back to top Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6100321 Share on other sites More sharing options...
Xenith Posted March 17, 2025 Share Posted March 17, 2025 I've only used scatter/lance, again for the reasons outlined above. I think the lance is the bets weapon by far, long range anti everything outside of a prism cannon, but suffers from bs3+. The scatter is there to guarantee a hit on an infantry unit. Ideally you bring 2x scat/lance walkers or the second to tag a vehicle with the lance if the first misses, and also to take advantage of the targeting rule. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6100356 Share on other sites More sharing options...
MadEdric Posted March 18, 2025 Share Posted March 18, 2025 I currently have 2 with dual AML and one with starcannon/scatter laser (I don't know why or what edition this was the thing). The 2 with AML were mainly AT for me in the one game I've gotten in so far, usually what ever they fired on was gone, so the extra AP boost didn't matter. The mixed one was great at that though. This was in the Guardian Host detachment, so War Walkers get a bit of a boost while in that detachment. Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6100511 Share on other sites More sharing options...
Bouargh Posted July 27, 2025 Share Posted July 27, 2025 I am in the process of building 2 walkers. And I am thinking about the tooling too. I lack AT but for me the WW have a limited life expectation. Too hard to hide. I plan to use these as early hitters and then if they survive it is bonus time. I will probably go for ML and BL on the first one. And BL plus SL on the second one. It Will give me enough flexibilty for appropriate variety at any game size. BTW these will be aligned as separated units. Comments? Ideas ? Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6124542 Share on other sites More sharing options...
Karhedron Posted July 27, 2025 Author Share Posted July 27, 2025 I think BL + AML is looking decent at the moment. The drop of Armigers and Wardogs to T9 makes S10 more relevant in the current meta. Brightlances were good already and big Knights going to T11 only makes them better. SvenIronhand and Bouargh 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6124545 Share on other sites More sharing options...
Bouargh Posted August 6, 2025 Share Posted August 6, 2025 And here they are: Ready to walk to war. Which is the minimum expected for a Warwalker, isn't it? Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6126501 Share on other sites More sharing options...
Captain Coolpants Posted August 12, 2025 Share Posted August 12, 2025 I miss the old corsair versions, they could deep strike, surprising how handy that was Magos Takatus, Bouargh and Karhedron 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6127534 Share on other sites More sharing options...
Karhedron Posted August 12, 2025 Author Share Posted August 12, 2025 Deep Strike is good but Scout 9" is pretty handy too as it allows you to reposition once you know whether you have got the first turn or not. Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6127537 Share on other sites More sharing options...
Bouargh Posted August 12, 2025 Share Posted August 12, 2025 6 hours ago, Captain Coolpants said: I miss the old corsair versions, they could deep strike, surprising how handy that was If you play legends, the Wasp Assault walker still can be aligned. Deepstriking is OK but Fly keyword on it is also very handy. And 4+ inv save is also better than the Warwalker 5+. all the package for +10 pts per model. Of course you have to swallow the reduced Ld (by 1pt) and the 10 extra points per model. Plus the fact that unit size is 1 model only. But in most games the Wasp can still bring a nice-add on because of the low number of other deep striking models in aeldari roosters. Except with Ynnari's trnasports that boosts the count, we have only hawks, spiders and falcon that can do it, correct? so it is a rather limited amount of stuff and tactical roles if you compare for exemple with Drukharii. Link to comment https://bolterandchainsword.com/topic/385508-war-walker-load-out-and-usage/#findComment-6127585 Share on other sites More sharing options...
