Stef Coudou Posted March 23, 2025 Share Posted March 23, 2025 (edited) Hi Fratus ! As I definatly love the Blackstone Fortress minis, specially the "regular" team, I begin here this new topic in order to know if ever someone has already swapped profiles of this BF team for games like Killteam or Necromunda ? If not, that would probably be quite interesting to talk about it... Here is the Team i'm thinking of : Edited March 23, 2025 by Stef Coudou Dr_Ruminahui and W.A.Rorie 2 Back to top Link to comment https://bolterandchainsword.com/topic/385549-blackstone-fortress-minis-for-kill-team-or-necromunda/ Share on other sites More sharing options...
Stef Coudou Posted April 27, 2025 Author Share Posted April 27, 2025 (edited) And here is the nearly painted team... I think the easiest way to play them is by using the Crusade rules. Edited April 27, 2025 by Stef Coudou Mandragola, firestorm40k, Trokair and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/385549-blackstone-fortress-minis-for-kill-team-or-necromunda/#findComment-6106871 Share on other sites More sharing options...
Mandragola Posted April 27, 2025 Share Posted April 27, 2025 Great job painting those models. It wouldn’t be easy to use them as any of the existing kill teams, unfortunately. They’re such an individual team that I’m not sure who they could count as. Also, Kill team uses fixed base sizes, which mostly won’t match what those models have. Some of the models could find a use. For example the priest guy could be a confessor in a sanctifier team and you could use Vorne as the eviscerator and hand flamer guy in the team - ideally on a 25mm base. The two ratlings could go into a rattling team, obviously. So if you’re happy to use one or two of them into some teams, to have your own different models, then you’re set. Using all of them as a single team would be harder. Link to comment https://bolterandchainsword.com/topic/385549-blackstone-fortress-minis-for-kill-team-or-necromunda/#findComment-6106898 Share on other sites More sharing options...
