greatcrusade08 Posted March 24, 2025 Share Posted March 24, 2025 So i love left field armies. With games being won or lost on objectives, would an all infantry force be viable? Anti tank would be probelmatic sure. I was thinking Ventris for deep striking a large unit of hellblasters. run him with bladeguard? Max eradicator (3x3) max bodies, so 5 squads of intercessors and 2 assault intercessors? would we need infiltrators to get to objectives early? Link to comment https://bolterandchainsword.com/topic/385555-is-infantry-only-army-viable/ Share on other sites More sharing options...
Galron Posted March 24, 2025 Share Posted March 24, 2025 There are some serious hard counters but yeah it could work in some match ups. Just thinking about who I normally face and my own forces. Nidzilla would roast you and would love you to jump on the objectives early, just means they get that much closer faster. Not sure how my marine anti-Nidzilla list would do if I ran into it, its a lot of vehicles with some big guns but they are big low volume shots. I think my NL chaos force which is slightly more balanced would do better. My IG would really depend on the force I brought, I have too many of those including my own all infantry force. My main IW list would have a field day. But my lists are skewed in a certain direction due to one of my regular opponents whom I have to tailor against which means I will annihilate certain lists but am very weak vs others. I dont bring much melee as its almost pointless until the end for a final punch to take an objective. Link to comment https://bolterandchainsword.com/topic/385555-is-infantry-only-army-viable/#findComment-6101366 Share on other sites More sharing options...
greatcrusade08 Posted March 24, 2025 Author Share Posted March 24, 2025 thats true, skew lists always have a hard counter. i was thinking of firestorm detachment for +1S firing at close range. Might help vs monsters a bit, anything T8/9 is 5s instead of 6s to wound? Link to comment https://bolterandchainsword.com/topic/385555-is-infantry-only-army-viable/#findComment-6101370 Share on other sites More sharing options...
Karhedron Posted March 24, 2025 Share Posted March 24, 2025 Firestorm is good but half of the stratagems revolve around the use of Transports so you may find that you are not "playing with a full deck" when it comes to strats. Take a look at the Goonhammer reviews as there are quite often infantry-only SM lists that do well there. The ones I seem most often are Vanguard or Liberator Assault Group as these have the most goodies targeted at infantry. greatcrusade08 1 Back to top Link to comment https://bolterandchainsword.com/topic/385555-is-infantry-only-army-viable/#findComment-6101384 Share on other sites More sharing options...
HeadlessCross Posted March 24, 2025 Share Posted March 24, 2025 1 hour ago, greatcrusade08 said: thats true, skew lists always have a hard counter. i was thinking of firestorm detachment for +1S firing at close range. Might help vs monsters a bit, anything T8/9 is 5s instead of 6s to wound? The main issue is that Firestorm requires transports for half the strats and almost locks you into using Salamanders/Vulkan. You'd have more luck with Gladius or Vanguard, but if you want to go outside thr codex you can do three good Blood Angels detachments (the Death Company one is legit trash). You'll need to keep in mind that certain armies can teleport and basically delete your infantry with zero issues. Eldar is a primary problem here with the Warp Spiders + Phoenix Lord or Dire Avengers + Phoenix Lord. Other armies will just thank you like most Custodes lists. greatcrusade08 1 Back to top Link to comment https://bolterandchainsword.com/topic/385555-is-infantry-only-army-viable/#findComment-6101396 Share on other sites More sharing options...
greatcrusade08 Posted March 24, 2025 Author Share Posted March 24, 2025 55 minutes ago, Karhedron said: Firestorm is good but half of the stratagems revolve around the use of Transports so you may find that you are not "playing with a full deck" when it comes to strats. Take a look at the Goonhammer reviews as there are quite often infantry-only SM lists that do well there. The ones I seem most often are Vanguard or Liberator Assault Group as these have the most goodies targeted at infantry. ah I hadn’t considered strategems I’ll check out the reviews thank you Link to comment https://bolterandchainsword.com/topic/385555-is-infantry-only-army-viable/#findComment-6101401 Share on other sites More sharing options...
Solution Galron Posted March 25, 2025 Solution Share Posted March 25, 2025 Vanguard would likely be the best out of the main books with its inherent -1 to hit and getting cover plus a lot of decent infantry strats. Against bugs I use it with my armored force just to try and blunt the insane firepower coming my way. greatcrusade08 1 Back to top Link to comment https://bolterandchainsword.com/topic/385555-is-infantry-only-army-viable/#findComment-6101530 Share on other sites More sharing options...
greatcrusade08 Posted March 25, 2025 Author Share Posted March 25, 2025 yeah thats always a solid back up Link to comment https://bolterandchainsword.com/topic/385555-is-infantry-only-army-viable/#findComment-6101554 Share on other sites More sharing options...
