Mandragola Posted April 15, 2025 Share Posted April 15, 2025 At this point it doesn’t look like plague marines or AoD will get a separate release. It’s a bit frustrating if you run them as it means you’ll never get tokens. Third parties can make those for you though. Otherwise, the individual teams get their releases when the next set is released. Ratlings and wreckas came out along with blood and zeal. Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105355 Share on other sites More sharing options...
INKS Posted April 15, 2025 Share Posted April 15, 2025 2 hours ago, Mandragola said: At this point it doesn’t look like plague marines or AoD will get a separate release. It’s a bit frustrating if you run them as it means you’ll never get tokens. Third parties can make those for you though. Otherwise, the individual teams get their releases when the next set is released. Ratlings and wreckas came out along with blood and zeal. the bigger problem is I can't get them... boxes are sold out for a long time and I don't think GW is going to make more? so ebay? seems odd not to release them Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105377 Share on other sites More sharing options...
TheMawr Posted April 15, 2025 Share Posted April 15, 2025 (edited) 17 minutes ago, INKS said: the bigger problem is I can't get them... boxes are sold out for a long time and I don't think GW is going to make more? so ebay? seems odd not to release them Its the base starterset for the edition, not a limited box like the others.. so it should be available for 2 more years at least. Thats a big should nowadays though, because indeed GW is often out of stock on a lot of things... I dont think it would help much if they where available seperate either ( it would probably help less as there would be one less barrier for those who want either team just for their 40k armies.) edit: You probably are not talking about the starterset, as it doesnt show as out of stock on GWs webstore for me Edited April 15, 2025 by TheMawr Mandragola 1 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105378 Share on other sites More sharing options...
INKS Posted April 15, 2025 Share Posted April 15, 2025 1 hour ago, TheMawr said: Its the base starterset for the edition, not a limited box like the others.. so it should be available for 2 more years at least. Thats a big should nowadays though, because indeed GW is often out of stock on a lot of things... I dont think it would help much if they where available seperate either ( it would probably help less as there would be one less barrier for those who want either team just for their 40k armies.) edit: You probably are not talking about the starterset, as it doesnt show as out of stock on GWs webstore for me I was talking about the starter set. it does say in stock in my country but I tend not to buy from GW - so that mistake is on me. Locally, it's been sold out for a long time and they can't seem to order more from GW for whatever reason. who knows. I don't know that the starter set does anything for 40k? The DG give you some plague marines and a character, the space marines? I am not even sure... i guess you can use them in a squad but I don't think they have their own data sheet? Regardless of that buying a more expensive starter box when you only want one team is ... less desirable. Not sure why they wouldn't or aren't releasing them as individual teams. Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105388 Share on other sites More sharing options...
Mandragola Posted April 16, 2025 Share Posted April 16, 2025 9 hours ago, INKS said: I was talking about the starter set. it does say in stock in my country but I tend not to buy from GW - so that mistake is on me. Locally, it's been sold out for a long time and they can't seem to order more from GW for whatever reason. who knows. I don't know that the starter set does anything for 40k? The DG give you some plague marines and a character, the space marines? I am not even sure... i guess you can use them in a squad but I don't think they have their own data sheet? Regardless of that buying a more expensive starter box when you only want one team is ... less desirable. Not sure why they wouldn't or aren't releasing them as individual teams. I was lucky to have all the death guard from the 8e starter available to convert into my plague marine team. There were some fairly straightforward conversions, like giving a bolter guy the big axe from the lord to make a fighter. quite pleased with how they came out. The starter from GW isn’t terrible value. You might even enjoy using the angels of death sometimes, or of course you could sell them. It’s useful to have the token sheet too, though annoying it doesn’t include the full rules. INKS, MoriyaSchism and LameBeard 3 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105419 Share on other sites More sharing options...
TheWarmaster Posted April 16, 2025 Share Posted April 16, 2025 I am genuinely perplexed by the people complaining that these servitors aren’t all mindless zombie thralls with minimal brain function.. Obviously there are different classes and grades of servitors in 40K. I’m pretty sure technoarchaeologists and other high ranking adepts embarking on dangerous missions into hostile territories to find and recover STC’s will be able to requisition much higher grade combat servitors to protect them. They aren’t going to take base level servitors that are monotasked to clean toilets and scrub floors to find STC’s which are like their Holy Grails, are they.. INKS, sitnam, Xirix and 2 others 2 3 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105425 Share on other sites More sharing options...
Frogian Posted April 16, 2025 Share Posted April 16, 2025 10 hours ago, INKS said: I was talking about the starter set. it does say in stock in my country but I tend not to buy from GW - so that mistake is on me. Locally, it's been sold out for a long time and they can't seem to order more from GW for whatever reason. who knows. I don't know that the starter set does anything for 40k? The DG give you some plague marines and a character, the space marines? I am not even sure... i guess you can use them in a squad but I don't think they have their own data sheet? Regardless of that buying a more expensive starter box when you only want one team is ... less desirable. Not sure why they wouldn't or aren't releasing them as individual teams. here (UK) the space marine team sells for half the price of the box, so its probably the cheapest way to get into KT. They are all on individual sprues and meant to pop out so i can see why they might not end up boxing them as individual teams. They might not even be made at the Nottingham factory?? It went out of stock in the UK for a while but has come back in now You can use the captain in 40k easily, the others can be used to partly fill out the Company Heroes (especially if you have the banner guy and the lieutenant with power sword from the DI box) Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105427 Share on other sites More sharing options...
INKS Posted April 16, 2025 Share Posted April 16, 2025 5 hours ago, Frogian said: here (UK) the space marine team sells for half the price of the box, so its probably the cheapest way to get into KT. They are all on individual sprues and meant to pop out so i can see why they might not end up boxing them as individual teams. They might not even be made at the Nottingham factory?? It went out of stock in the UK for a while but has come back in now You can use the captain in 40k easily, the others can be used to partly fill out the Company Heroes (especially if you have the banner guy and the lieutenant with power sword from the DI box) I see. I don't play space marines so I don't really have a use for them. I could sell them I guess. kind of a hassle. I did not know they were all on individual sprues but this makes sense since they were blind boxes at one point. They could gather them up and sell them in a nex box but maybe they dn't want to do that. Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105451 Share on other sites More sharing options...
Interrogator Stobz Posted April 21, 2025 Share Posted April 21, 2025 Hey Team, Did we get any info on release date? I didn't see any yet... Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105940 Share on other sites More sharing options...
INKS Posted April 21, 2025 Share Posted April 21, 2025 Nothing yet. New data slate coming for kill team but no news on this release. maybe in a week or 2? Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105941 Share on other sites More sharing options...
PerfectChocolateMadeleine Posted April 21, 2025 Share Posted April 21, 2025 i love the underseer model!!!! might use her and some bits from the other models to make a Magos Dominus for my Mechanicum allies in HH!!! :D just need to find someone locally to split the box with when it comes out Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6105997 Share on other sites More sharing options...
Mandragola Posted April 21, 2025 Share Posted April 21, 2025 13 hours ago, INKS said: Nothing yet. New data slate coming for kill team but no news on this release. maybe in a week or 2? My guess would be not for at least a month and maybe two. Blood and zeal only arrived in shops last weekend and they’ll definitely be spaced out more than a month. These previews can create an expectation that things are coming very soon, but they’re showing us the next few months worth of releases. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6106025 Share on other sites More sharing options...
Bouargh Posted April 21, 2025 Share Posted April 21, 2025 2 minutes ago, Mandragola said: My guess would be not for at least a month and maybe two. Blood and zeal only arrived in shops last weekend and they’ll definitely be spaced out more than a month. The release pace used to be approx 8 weekend between 2 KT boxes. And it was short. So I would say your estimate looks reasonnable Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6106026 Share on other sites More sharing options...
Interrogator Stobz Posted April 22, 2025 Share Posted April 22, 2025 Thanks for the replies Brothers. I have time to save, just spent the short term hobby budget on some OOP BL books... Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6106052 Share on other sites More sharing options...
Jscarlos18 Posted June 4, 2025 Share Posted June 4, 2025 (edited) The new datasheets for the two teams are now free to download: https://www.warhammer-community.com/en-gb/downloads/warhammer-40000/ I'm very happy to see that the Raveners still have all the options accessible for normal 40k, one for classic kit and other for the new models. And they are organized so the two versions can be attached together in teams of 10. Edited June 4, 2025 by Jscarlos18 firestorm40k 1 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6114065 Share on other sites More sharing options...
Mogger351 Posted June 4, 2025 Share Posted June 4, 2025 2 minutes ago, Jscarlos18 said: The new datasheets for the two teams are now free to download: https://www.warhammer-community.com/en-gb/downloads/warhammer-40000/ I'm very happy to see that the Raveners still have all the options accessible for normal 40k, one for classic kit and other for the new models. And they are organized so the two versions can be attached together in teams of 10. They lost the pistol chest for the normal unit and changed in size, so if you ran squads of 3 youre 2 short and squads of 6 you have one spare. Kinda annoying for existing collections I suppose. skylerboodie 1 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6114066 Share on other sites More sharing options...
Jscarlos18 Posted June 4, 2025 Share Posted June 4, 2025 Just now, Mogger351 said: They lost the pistol chest for the normal unit and changed in size, so if you ran squads of 3 youre 2 short and squads of 6 you have one spare. Kinda annoying for existing collections I suppose. Ooof, glad I didn't get them yet. Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6114067 Share on other sites More sharing options...
Herschet Posted June 8, 2025 Share Posted June 8, 2025 Yeah, it's coming. And there are 15 terrain pieces within. Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6114914 Share on other sites More sharing options...
firestorm40k Posted June 8, 2025 Share Posted June 8, 2025 Also, I didn't realise, but the set also contains a squad of Hormagaunts - which makes it really good value Ming the Merciless, Rusted Boltgun and ZeroWolf 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6114915 Share on other sites More sharing options...
Herschet Posted June 8, 2025 Share Posted June 8, 2025 Is there a price already known? Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6114918 Share on other sites More sharing options...
Mogger351 Posted June 8, 2025 Share Posted June 8, 2025 32 minutes ago, Herschet said: Is there a price already known? No, im interested to see one though. Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6114922 Share on other sites More sharing options...
ZeroWolf Posted June 8, 2025 Share Posted June 8, 2025 We'll find out tomorrow morning Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6114925 Share on other sites More sharing options...
Redsun Posted June 9, 2025 Share Posted June 9, 2025 £100 apparently skylerboodie and ZeroWolf 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6115142 Share on other sites More sharing options...
lhg033 Posted June 10, 2025 Share Posted June 10, 2025 I'm expecting about £100 with the squad of hormagaunts and as it seems to have 2x the terrain I though was included in the preview. £100 seems 'reasonable' ZeroWolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6115174 Share on other sites More sharing options...
The Praetorian of Inwit Posted June 10, 2025 Share Posted June 10, 2025 It is good to see Tyranids having received some proper support this edition. Link to comment https://bolterandchainsword.com/topic/385575-kill-team-typhon/page/4/#findComment-6115175 Share on other sites More sharing options...
