Valkyrion Posted March 28, 2025 Share Posted March 28, 2025 Evenin boyz, can you model the ork dread with four heavy weapons, or do they share some pieces in common that prevents it? Ta! Link to comment https://bolterandchainsword.com/topic/385596-ork-dreads-can-you-mount-4-guns/ Share on other sites More sharing options...
The Neverborn Posted March 28, 2025 Share Posted March 28, 2025 (edited) None of the guns it has or can have, have the “heavy” keyword. But you can replace the two Dread Klaws with two guns. Add the two guns the profile starts with for a total of four Edit please forgive me being remarkably dense! as soon as I pressed post I realised this is a modelling question Edited March 28, 2025 by The Neverborn Link to comment https://bolterandchainsword.com/topic/385596-ork-dreads-can-you-mount-4-guns/#findComment-6102536 Share on other sites More sharing options...
Inquisitor_Lensoven Posted March 28, 2025 Share Posted March 28, 2025 If you wanted to, sure. Not particularly sure why you’d want to since you’d be losing so much effectiveness by doing so. Valkyrion 1 Back to top Link to comment https://bolterandchainsword.com/topic/385596-ork-dreads-can-you-mount-4-guns/#findComment-6102575 Share on other sites More sharing options...
Solution AutumnEffect Posted March 29, 2025 Solution Share Posted March 29, 2025 (edited) 11 hours ago, Valkyrion said: Evenin boyz, can you model the ork dread with four heavy weapons, or do they share some pieces in common that prevents it? Ta! The Deff Dread kit comes with: 4 Klaws 2 Big Shootas 2 Kustom Mega Blastas 2 Rokkit Launchas 1 Skorcha There are 4 heavy weapon joints that connect to the dread's body, though they are sized a bit smaller than the ones for the top row of arms that usually mount Klaws. It shouldn't really look too obvious though, especially if you cover it up a bit with some armor plates. So yes, it's possible to model from one kit a Dredd with, say, 2 Rokkit Launchas and 2 Kustom Mega Blastas. However, if you want 4 of the same weapon then it will require another kit or some bit-buys to get the other 2 weapons. I'd also add that it's very easy to magnetize the arms on a Deff Dread. 4 Kustom Mega Blastas in More Dakka! is very fun and I highly encourage it. Edited March 29, 2025 by AutumnEffect Valkyrion and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385596-ork-dreads-can-you-mount-4-guns/#findComment-6102602 Share on other sites More sharing options...
Rusted Boltgun Posted March 29, 2025 Share Posted March 29, 2025 (edited) I've just built a Dredd and think the weapons are limited to two by the mountings, parts 66 and 67. I've not checked the sprue to see whether there are multiples (I built mine with the box art load out for Combat Patrol) Not saying you couldn't get round it with a little creativity, mind. Edit: dig out the sprue - there are four mounting gubbins. Only three in the photo because I had used one Edited April 3, 2025 by Rusted Boltgun Spacings / second photo Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385596-ork-dreads-can-you-mount-4-guns/#findComment-6102675 Share on other sites More sharing options...
