Teetengee Posted April 10, 2025 Share Posted April 10, 2025 So, I do a lot of kitbashing and have noticed a bigger issue with time. In days of yore, I could largely just organize a bit box into arms, legs, heads, etc... But with the rise of more and more monopose kits, parts are often not interchangeable but can be hard to tell which parts go with each other once they're snipped from sprue. How are you all organizing your bit boxes these days? Link to comment https://bolterandchainsword.com/topic/385671-bit-box-organization/ Share on other sites More sharing options...
Firedrake Cordova Posted April 10, 2025 Share Posted April 10, 2025 My "bitz box" is one of the old mail order boxes (the ones with Da Trollz on them) - most things are simply in their own 4"x6" resealable plastic bag with a Post-It! note on it. It's worked since the 1990's ... Teetengee, LameBeard and sbarnby71 3 Back to top Link to comment https://bolterandchainsword.com/topic/385671-bit-box-organization/#findComment-6104477 Share on other sites More sharing options...
Grotsmasha Posted April 10, 2025 Share Posted April 10, 2025 I use a big box and sandwich bags. After a bit of practice I can pick out matching arms (or at least ones that will work) just by looking at the wrist positions. For monopose torsos/legs like Intercessors, I usually glue torso/waist/legs together before they go in the bits bag. LameBeard, Firedrake Cordova and Teetengee 3 Back to top Link to comment https://bolterandchainsword.com/topic/385671-bit-box-organization/#findComment-6104485 Share on other sites More sharing options...
W.A.Rorie Posted April 10, 2025 Share Posted April 10, 2025 fine tip sharpie parts that match up Link to comment https://bolterandchainsword.com/topic/385671-bit-box-organization/#findComment-6104545 Share on other sites More sharing options...
NovemberIX Posted April 10, 2025 Share Posted April 10, 2025 I have a bead box with largish sections that I use, for larger projects I have a set of plastic parts drawers that can fit things as big as a land speeder. Examples below DemonGSides and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/385671-bit-box-organization/#findComment-6104555 Share on other sites More sharing options...
Ramell Posted April 10, 2025 Share Posted April 10, 2025 I keep my models split up in drawer setups not unlike what frater November IX posted, with dividers in the drawers. In those drawers I keep matching parts (bodies, bolt rifle arms, things like that), together in the same subdivision. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385671-bit-box-organization/#findComment-6104558 Share on other sites More sharing options...
Jukkiz Posted April 11, 2025 Share Posted April 11, 2025 iuse the method of cutting arms that hold weapons, with bit of sprue. Best if they´re close together and in other cases, i glue the bit of sprues together so i don´t lose pairs. LameBeard and Teetengee 2 Back to top Link to comment https://bolterandchainsword.com/topic/385671-bit-box-organization/#findComment-6104658 Share on other sites More sharing options...
Corswain Posted April 13, 2025 Share Posted April 13, 2025 Space marines are still largely done by heads, arms, legs etc. but everything else is now organised by army ie. Thousand Sons, Soulblight Gravelords. Link to comment https://bolterandchainsword.com/topic/385671-bit-box-organization/#findComment-6104853 Share on other sites More sharing options...
