kabaakaba Posted April 18, 2025 Share Posted April 18, 2025 I have few resie minis and use cianacrilate glue last time, and it's works bad. it's don't hold and easily breaks apart. also it's dry way to long. what glue do you use for resine kits? Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/ Share on other sites More sharing options...
Solution Grotsmasha Posted April 18, 2025 Solution Share Posted April 18, 2025 I use dollar store super glue that comes in a bottle with a brush applicator. Super Glue works best on a rough surface, so a rough sand, or simply scoring both sides with your hobby knife prior to gluing will aid in a stronger bond. If you really, REALLY dont want bits to come off, you can drill and insert a pin to further hold the pieces together. Brass rod, and paper clips are common choices for this. Firedrake Cordova and kabaakaba 2 Back to top Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6105672 Share on other sites More sharing options...
Oxydo Posted April 18, 2025 Share Posted April 18, 2025 If you haven't, wash the resin in soap and water before gluing and painting. Unwashed resin can prevent cyanoacrylate glue from hardening properly. Firedrake Cordova, kabaakaba and LameBeard 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6105677 Share on other sites More sharing options...
phandaal Posted April 18, 2025 Share Posted April 18, 2025 Liquid Loctite. That is cyanoacrylate, but the liquid part is the key. Glue jel is horrible, liquid glue locks the parts down in a few seconds. kabaakaba 1 Back to top Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6105708 Share on other sites More sharing options...
crimsondave Posted April 20, 2025 Share Posted April 20, 2025 My experience using super glue got way better when I started using this stuff…. Spoiler Just don’t get super glue on your hand and accidentally spray this on it. It burns. I know. Firedrake Cordova and MadGreek 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6105919 Share on other sites More sharing options...
Sky Potato Posted April 21, 2025 Share Posted April 21, 2025 On 4/18/2025 at 9:04 PM, phandaal said: Liquid Loctite. That is cyanoacrylate, but the liquid part is the key. Glue jel is horrible, liquid glue locks the parts down in a few seconds. My experience is the opposite. I really like the gel superglue by Gorilla Glue, its my go-to for assembling Forge World resin items. MadGreek 1 Back to top Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6106009 Share on other sites More sharing options...
phandaal Posted April 21, 2025 Share Posted April 21, 2025 1 hour ago, Sky Potato said: My experience is the opposite. I really like the gel superglue by Gorilla Glue, its my go-to for assembling Forge World resin items. Gorilla Glue must hate me then, because that is exactly what I was thinking of talking about how bad the gel stuff is. Gorilla Glue gel is a huge pain whenever I use it... Takes forever to get a good hold. Liquid stuff on the other hand is like super fast super strong bond. Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6106022 Share on other sites More sharing options...
Grotsmasha Posted April 22, 2025 Share Posted April 22, 2025 On 4/22/2025 at 3:52 AM, phandaal said: Gorilla Glue must hate me then, because that is exactly what I was thinking of talking about how bad the gel stuff is. Gorilla Glue gel is a huge pain whenever I use it... Takes forever to get a good hold. Liquid stuff on the other hand is like super fast super strong bond. When assembling Forge World models, I actually use both. The Gel glue in the centre of the bond, with regular super glue around the edges. Firedrake Cordova, phandaal and crimsondave 3 Back to top Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6106219 Share on other sites More sharing options...
kabaakaba Posted April 27, 2025 Author Share Posted April 27, 2025 Ohhkey... Me ordered another glue, loctite exactly, cause my CA glue looks like a some kind of counterfeit. Even for two slightly rough surfaces ideally adjusted one to another it broke with lil force applied. Gonna see what how it be with loctite Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6106858 Share on other sites More sharing options...
kabaakaba Posted May 1, 2025 Author Share Posted May 1, 2025 (edited) THIS IS AMAZING. Got loctite delivered today. Just now tried to glue head to body. Well. I have 3 sec to adjust and absolutely dead lock after that. I break guardian neck while trying remove a head. On 4/18/2025 at 11:04 PM, phandaal said: Liquid Loctite. That is cyanoacrylate, but the liquid part is the key. Glue jel is horrible, liquid glue locks the parts down in a few seconds. Thanks for suggestions. Bought liquid loctite 401 Edited May 1, 2025 by kabaakaba Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/385718-resine-glue/#findComment-6107583 Share on other sites More sharing options...
