Helias_Tancred Posted April 24 Share Posted April 24 (edited) The new Death Guard codex rules have leaked. Looks like Plague Marines will be T6, and their Terminators will be T7. What's going to be the best way to kill these Nurgle-afflicted traitors? Hellblasters initially come to mind, for starters. Edit: Also anything Dark Angels specific come to mind as good killers of Death Guard? Thanks all. Edited April 24 by Helias_Tancred Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/ Share on other sites More sharing options...
Tawnis Posted April 24 Share Posted April 24 Aggressors up close could probably handle that pretty well. Things that give lance or +1 to wound like Chaplains will probably be a big help too. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106536 Share on other sites More sharing options...
Karhedron Posted April 24 Share Posted April 24 Who are you fielding? Blood Angels are S6 on the charge which will help against regular PMs which Sang Guard, BGVs Van Vets etc are S7 on the charge. Plasma Inceptors will do good work, especially as they are 2D normally and can overcharge to 3D. Even regular Bolter Inceptors are not too shabby thanks to twin-linked. A Vindicator or three is always going to be a solid option. Cenobite Terminator and Helias_Tancred 2 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106538 Share on other sites More sharing options...
Inquisitor_Lensoven Posted April 24 Share Posted April 24 Plasma and autocannons. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106540 Share on other sites More sharing options...
HeadlessCross Posted April 24 Share Posted April 24 The jump from T6 to T7 isn't that important for the Terminators. The T6 is though for Plague Marines since the S5 Power Weapons you would've used before will be less effective. All the S4 and S8 you were using, though, will still be effective vs both due to wounding at the same exact rate. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106548 Share on other sites More sharing options...
Tacitus Posted April 25 Share Posted April 25 4 hours ago, HeadlessCross said: The jump from T6 to T7 isn't that important for the Terminators. The T6 is though for Plague Marines since the S5 Power Weapons you would've used before will be less effective. All the S4 and S8 you were using, though, will still be effective vs both due to wounding at the same exact rate. Small quibble - they won't wound at the same rate. They don't wound on 5's (S5 vs T4), but they also won't wound on 2's (S8 vs T4) Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106573 Share on other sites More sharing options...
Tokugawa Posted April 25 Share Posted April 25 29 minutes ago, Tacitus said: Small quibble - they won't wound at the same rate. They don't wound on 5's (S5 vs T4), but they also won't wound on 2's (S8 vs T4) Plaguemarine were t5 since 1990s. Helias_Tancred and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106579 Share on other sites More sharing options...
Malakithe Posted April 25 Share Posted April 25 Massed Terminators. Fist everything. Done. Cenobite Terminator, Helias_Tancred and Knightsword 3 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106604 Share on other sites More sharing options...
Karhedron Posted April 25 Share Posted April 25 Predator Destructor. The Autocannon has 4 attacks (6 attacks within 24") at S9, AP-2 D3. That will clear both Plague Marines and Terminators pretty efficiently. The Heavy Bolters will struggle as they will need 5s to Wound but every bit helps. Or just put on Lascannons. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106612 Share on other sites More sharing options...
HeadlessCross Posted April 25 Share Posted April 25 4 hours ago, Karhedron said: Predator Destructor. The Autocannon has 4 attacks (6 attacks within 24") at S9, AP-2 D3. That will clear both Plague Marines and Terminators pretty efficiently. The Heavy Bolters will struggle as they will need 5s to Wound but every bit helps. Or just put on Lascannons. While the Heavy Bolters will need 5s to wound, with the Predator they'd be AP-2 at least, which isn't a bad spot to hit either target. That said, Lascannons are likely better into the Terminators. Helias_Tancred and Karhedron 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106664 Share on other sites More sharing options...
Tokugawa Posted April 25 Share Posted April 25 On a 10th vehicle, if one weapon option could pick between lascannon and heavy bolter, with same BS, no extra cost and no extra rules about making wounds(e.g. reroll wounds, devastating wounds), then competitive list would always choose lascannon and never choose heavy bolter. There is gap in raw power. If you can farm MW from devwound or other tricks, it could be effective against DG. DG have few to none protection against MW. Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106740 Share on other sites More sharing options...
Tacitus Posted April 26 Share Posted April 26 17 hours ago, Tokugawa said: Plaguemarine were t5 since 1990s. My mistake, I raced through as generic Chaos/Loyalist stat line. As to the answer to the question: I'd try and do it with Plasma Inceptors. Your vehicles will likely have plenty of their vehicles to target, and Plamsa Inceptors feel like they rub salt into the wound. I'm T6 too. I also move 10". Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106750 Share on other sites More sharing options...
Tacitus Posted April 26 Share Posted April 26 1 hour ago, Tokugawa said: On a 10th vehicle, if one weapon option could pick between lascannon and heavy bolter, with same BS, no extra cost and no extra rules about making wounds(e.g. reroll wounds, devastating wounds), then competitive list would always choose lascannon and never choose heavy bolter. There is gap in raw power. If you can farm MW from devwound or other tricks, it could be effective against DG. DG have few to none protection against MW. Don't forget Lethals. Assault Intercessors rerolling to hit, rerolling to wound, and adding 1 to wound (which doesn't create more lethals but still helps) getting lethals from a Lieutenant isn't terrible. Probably not good, but its not "Our weapons are useless". Deathwing Knights also have some interesting applications here. Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106751 Share on other sites More sharing options...
Chaplain Augustus Posted April 26 Share Posted April 26 I like sternguard with combis for any super tough infantry. Dr. Clock and Cenobite Terminator 2 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106755 Share on other sites More sharing options...
HeadlessCross Posted April 26 Share Posted April 26 2 hours ago, Chaplain Augustus said: I like sternguard with combis for any super tough infantry. Combi-Weapons have practical application vs the Terminators, but you're better with the Bolt Rifle build into Plague Marines. Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106762 Share on other sites More sharing options...
Chaplain Augustus Posted April 26 Share Posted April 26 2 minutes ago, HeadlessCross said: Combi-Weapons have practical application vs the Terminators, but you're better with the Bolt Rifle build into Plague Marines. No doubt. I like both builds but whenever I see huge guys on the other side of the board I feel smart for bringing combi weaps... that being said, I have 10 dudes with combis that used to be Sargeants in tac squads that need to see action and they are itching to blast away at t6+ baddies Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106763 Share on other sites More sharing options...
Sinus Posted April 26 Share Posted April 26 Get around the wound roll. So use Sternguard with combiweapons. Or a Lieutenant with normal intercessors and fish for LH Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106782 Share on other sites More sharing options...
Cenobite Terminator Posted April 26 Share Posted April 26 I don’t see lots of auto cannons available or commonly used, so you’d probably have to list tailor, plus AP1 is easy to negate and you’ll be hard pressed to bring any significant weight of fire. Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106801 Share on other sites More sharing options...
Inquisitor_Lensoven Posted April 26 Share Posted April 26 1 hour ago, Cenobite Terminator said: I don’t see lots of auto cannons available or commonly used, so you’d probably have to list tailor, plus AP1 is easy to negate and you’ll be hard pressed to bring any significant weight of fire. Yeah it is a little weird how marines have lack of access to autocannons, but 3 predators and a unit or two of those flying autocannon dudes provide quite a bit of autocannon fire Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106805 Share on other sites More sharing options...
Tacitus Posted April 26 Share Posted April 26 2 hours ago, Cenobite Terminator said: I don’t see lots of auto cannons available or commonly used, so you’d probably have to list tailor, plus AP1 is easy to negate and you’ll be hard pressed to bring any significant weight of fire. Firestrikes, Suppressors, Predators plus potential AssCans from Terminators, Land Raiders, Dreads, Repulsors and the Reaper. Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106808 Share on other sites More sharing options...
Tokugawa Posted April 27 Share Posted April 27 4 hours ago, Tacitus said: Firestrikes, Suppressors, Predators plus potential AssCans from Terminators, Land Raiders, Dreads, Repulsors and the Reaper. You just listed two names which your opponent would appreciate you for taking them. Also, new Deathshroud has FOUR wounds per model, not three. Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106827 Share on other sites More sharing options...
Tacitus Posted April 27 Share Posted April 27 2 hours ago, Tokugawa said: You just listed two names which your opponent would appreciate you for taking them. Also, new Deathshroud has FOUR wounds per model, not three. No, I listed sources of Autocannons, their brothers from another mother the Assault Cannons, and then their sister from another Mister the Onslaught Gatling Cannon in response to someone commenting on there not being very many sources. Cenobite Terminator 1 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106834 Share on other sites More sharing options...
Cenobite Terminator Posted April 27 Share Posted April 27 (edited) Assault cannons aren't anything like an autocannon… 21 hours ago, Inquisitor_Lensoven said: Yeah it is a little weird how marines have lack of access to autocannons, but 3 predators and a unit or two of those flying autocannon dudes provide quite a bit of autocannon fire lLke I said that just feels like list tailoring, but I don’t think it’ll be all that effective. Edited April 27 by Cenobite Terminator Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106872 Share on other sites More sharing options...
Evil Eye Posted April 27 Share Posted April 27 Shoot them until they die. Oh, wait, sorry. Wrong game! Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106920 Share on other sites More sharing options...
HeadlessCross Posted April 27 Share Posted April 27 On 4/25/2025 at 8:27 PM, Chaplain Augustus said: No doubt. I like both builds but whenever I see huge guys on the other side of the board I feel smart for bringing combi weaps... that being said, I have 10 dudes with combis that used to be Sargeants in tac squads that need to see action and they are itching to blast away at t6+ baddies I mean that's definitely fine for a suicide drop pod unit. I was doing that until I discovered that Bolt Rifles were actually not far behind mathematically and just treated everyone as the same. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/385746-how-best-to-kill-t6-and-t7-death-guard/#findComment-6106925 Share on other sites More sharing options...
