Dr_Ruminahui Posted May 12, 2025 Share Posted May 12, 2025 (edited) Greetings Generals, Warlords, Nobles, Priests, Champions and Others Favoured by the Warp Call to Arms is back this year, but I'm running it for @Grotsmasha. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, loyal Astartes (which is new this year), Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for loyal Astartes being their own stronghold. Check out the full rules here If you've got any questions, give me or one of the Mods a shout! Edited May 13, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/ Share on other sites More sharing options...
Teetengee Posted May 15, 2025 Share Posted May 15, 2025 So when the time comes, can I post my space skaven here? I know they don't have any tabletop rules, but given the way call to arms works I don't think that should matter? Dr_Ruminahui and Tallarn Commander 2 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6110064 Share on other sites More sharing options...
Dr_Ruminahui Posted May 15, 2025 Author Share Posted May 15, 2025 I guess there are few ways of looking at it. The first is how do you think you would field it - would you use them using the mortal units in the CSM codex plus assorted vehicles? If so,, this is the right place. Or do you think you would use the genestealer cultists rules? If so, GSC would be the right place. The second is what makes the best connection to your background? This is how it is permissible to post traitor guard armies using the AM/IG rules here, and vow them from here. Is it due to skaven's chaotic nature and/or their use of chaos forces? If so, here seems right. Or does the "out of the warrens uprising" vibe of GSC work better? So I think either of here or GSC works for your "home" for this army, depending on where you put the focus of your army. Anyway, let me know your thoughts. Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6110069 Share on other sites More sharing options...
Teetengee Posted May 16, 2025 Share Posted May 16, 2025 My intention is that they are a chaos force from a background perspective, and since they don't have rules, they might even fall under Quote Any models that fall outside of the Strongholds, such as Necromunda, Blackstone Fortress, terrain, etc, may be pledged to ANY Stronghold. I am unsure if I intend to run them using any existing ruleset, to be honest, but traitor guard definitely seems the closest parallel, regardless of what they end up being mechanically. Tallarn Commander, Bonehead and Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6110148 Share on other sites More sharing options...
Dr_Ruminahui Posted May 16, 2025 Author Share Posted May 16, 2025 Sounds good - and sounds fine to run them from here, then. I look forward to seeing them vowed (and completed)! Tallarn Commander and Teetengee 2 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6110213 Share on other sites More sharing options...
Dr_Ruminahui Posted June 1, 2025 Author Share Posted June 1, 2025 (edited) STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Realm of Chaos go to the The Chaos Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for the Realm of Chaos The below list should cover every model for the Realm of Chaos (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); 1pt Cultists, Traitor Guard 2pts Ogryns Rough Riders, Spawn 3pts HWTs, Sentinals 4pts Ordnance Batteries, War Dog Knights 5pts Taurox, Chimera Chassis Tanks, Leman Russ Chassis tanks 6pts Valkyrie, Vulture, Rogal Dorn, Malcador Chassis tanks, Macharius Chassis tanks 8pts Baneblades, Shadowswords, Hellhammers etc) 10pts Lord of Skulls, Kytan Daemon Engine, Despoiler, Rampager, Abominant, Tyrant and Cerastus Knights 5pts Psykers, Castellans, Commissars, Tech-Priests Note: points are on a per model basis, so a command squad is 5 points for the character, 1 point for everyone else (or 2 if an Ogrynn) 40K Scale Titans 20pts Arcastus Knights, Warhound Titan 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 20 Traitor Guard(1ptx20), 3 Heavy Weapons Teams (2ptsx3), a Leman Russ (5pts), and a Traitor Commissar (5pts), your vow would be worth 36pts Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Realm of Chaos and Chaos to Victory!!! After June 15th, please do the same in the Chaos Stronghold! Rules and Place your Vow => The Chaos Stronghold Edited June 1, 2025 by Dr_Ruminahui Tallarn Commander 1 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6113373 Share on other sites More sharing options...
Tallarn Commander Posted June 2, 2025 Share Posted June 2, 2025 Here is what I'll be pledging as my Lost & the Damned Traitor Guard pledge: A handful of Nostroman 9th Traitor Guard troopers and a Nostroman 9th "heavy stalk tank" (a Rogal Dorn-Defiler kitbash, counts as Defiler) Nostroman 9th, "Hell's Horde" Bonehead, Dr_Ruminahui and sitnam 3 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6113665 Share on other sites More sharing options...
Dr_Ruminahui Posted June 2, 2025 Author Share Posted June 2, 2025 (edited) I can't wait to see how your Dornfiler turns out! If my experience on my own Russfiler is relevant, you should get working on that conversion ASAP as it will likely take some work. My own vows are going to be all EC this year. Edited June 2, 2025 by Dr_Ruminahui Tallarn Commander 1 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6113686 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these threads in the faction forums - if you have any questions, please ask me in the Strongholds or @Dr_Ruminahui Bonehead 1 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6116272 Share on other sites More sharing options...
Bonehead Posted June 15, 2025 Share Posted June 15, 2025 Building terrain for a game until early July. Then I'll probably pledge a bunch of traitor gaurd. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6116366 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 22 minutes ago, Bonehead said: Building terrain for a game until early July. Then I'll probably pledge a bunch of traitor gaurd. Sounds good. If you are painting the terrain, you can pledge it too, even without any actual traitor guard models yet. Bonehead 1 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6116375 Share on other sites More sharing options...
Bonehead Posted June 17, 2025 Share Posted June 17, 2025 Well then, I will. I Bonehead, being, as far as anyone here is legally going to be able to prove, of sound mind and majority, officially pledge to finish building, wiring and painting this here large scratchbuilt storage facility/refinery section piece. I also pledge to build, wire and paint not less than two adjoining gantry/catwalk pieces with connectable modular lighting. I will admit that since you said that I could pledge it it's moved on a touch, but it's still extremely unfinished due to all the textured plasticard I ordered not being here yet. I did paint a few bits of it already, but purely because they're going to be completely unreachable by anyone larger than a mouse once the thing is finished. This is the rough shape of it as of this weekend: Tallarn Commander 1 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6116947 Share on other sites More sharing options...
Dr_Ruminahui Posted June 17, 2025 Author Share Posted June 17, 2025 How much have you already painted? Really, for the purpose of the event its better for you to not paint any of it and just leave it unassembled enough to get to the bits that will become inaccessible. Other than that possible issue, it looks fine, but you'll need to go vow it in the Chaos stronghold in the WIP section. Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6116970 Share on other sites More sharing options...
Bonehead Posted June 22, 2025 Share Posted June 22, 2025 Well, I've finished it now. but it was merely painted only on the parts that needed painting before assembly when I posted that. Not to worry, I've got more crap to build, and barely two weeks to build it Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6117889 Share on other sites More sharing options...
Dr_Ruminahui Posted June 22, 2025 Author Share Posted June 22, 2025 Good luck! Bonehead 1 Back to top Link to comment https://bolterandchainsword.com/topic/385853-event-call-to-arms-2025-lost-and-the-damned/#findComment-6117899 Share on other sites More sharing options...
