large.Chaos-ThousandSons.png.80c676a802c
Greetings Lords, Ladies, Sorcerers, Apostles, Masters, Mistresses, Princes, Princesses, and Other Seekers of Forbidden Knowledge and Entities Favoured by the Warp
Call to Arms is back this year, but I'm running it for @Grotsmasha.  For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th!
The forum is split up into 5 Strongholds: Imperium, loyal Astartes (which is new this year), Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating.  For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for loyal Astartes being their own stronghold.
Check out the full rules here
If you've got any questions, give me or one of the Mods a shout!
Edited by Dr_Ruminahui
  • 3 weeks later...
STRONGHOLDS OPEN JUNE 15, 2025
For the Full Rules and where to place your vows for the Thousand Sons, go to the  The Chaos Stronghold
Start Date: 15th June
End Date: 15th September
Here is a more detailed list of points per model specifically for the Thousand Sons
The below list should cover every model for the Thousand Sons (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them);
1pt    Rubrics, Scarabs, Tzaangors, Horrors, Flamers, Screamers
2pts   Spawn, Sekhetar, Tzaangor Enlightened
3pts   Helbrute
4pts   War Dog Knights
5pts   Rhino Chassis tanks, Sicaran Chassis tanks, Forge/Maulerfiend
6pts   Mutalith, Land Raider, Spartan, Heldrake, Defiler
8pts   Glaive, Fellblade, Falchion, Fire Raptor, Storm Eagle
10pts Despoiler, Rampager, Abominant, Tyrant and Cerastus Knights
5pts   Sorcerers, Terminator Sorcerer, Exalted Sorcerers (walking or disked), Infernal Master, Tzaangor Shaman, Daemon Princes
10pts Magnus, Ahriman, Lords of Change, Kairos
40K Scale Titans
20pts Arcastus Knights, Warhound Titan, Thunderhawk
30pts Reaver Titan
40pts Warbringer Titan
50pts Warlord Titan, Stormbird
Terrain
1pt    3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges
2pts   Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade
3pts   Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks
4pts   Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls
5pts   Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier
6pts   Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent
8pts   Fronteris Hab Bunker, Manufactorum Administratus,
10pts Zone Morialtis Gang Stronghold
Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing.
All points are per model. For example if you pledge 20 Tzaangors (1ptx20), 3 Sekhetar (2ptsx3), a Helbrute (3pts), and a Exalted Sorcerer (5pts), your vow would be worth 34pts
Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Thousand Sons and Chaos to Victory!!!  After June 15th, please do the same in the Chaos Stronghold!
Rules and Place your Vow =>  The Chaos Stronghold
* ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS *
Happy painting!  Be sure to cheer on your fellow stronghold participants!
As a reminder, all vows must be completed by September 15th.
I will no longer be monitoring these threads in the faction forums - if you have any questions, please ask me in the Strongholds or @Dr_Ruminahui
Register a new account
Sign in
