large.Xenos-GSC.png.5fa4a23b1ac0725ae7b4
Greetings all Broodcoven leaders.
Call to Arms is back this year, but @Dr_Ruminahui will be running it for @Grotsmasha.  For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th!
The forum is split up into 5 Strongholds: Imperium, loyal Astartes (which is new this year), Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating.  For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for loyal Astartes being their own stronghold.
Check out the full rules here
If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout!
  • 3 weeks later...
STRONGHOLDS OPEN JUNE 15, 2025
For the Full Rules and where to place your vows for the Genestealer Cults go to the  The Xenos Stronghold
Start Date: 15th June
End Date: 15th September
Here is a more detailed list of points per model specifically for the Genestealer Cults
The below list should cover every model for the Genestealer Cults (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them);
1pt    Cultists, Aberrants, Hybrids, Genestealers
2pts   Jackals
3pts   Walkers (Dreadnaughts, Sentinels, Armigers)
4pts   Ridgerunner
5pts   Goliath Chassis vehicles
5pts    Biophagus, Clamavus, Kellermorph, Locus, Reductus, Sanctus, Nexos, Primus, Magus, Patriarch
Terrain
1pt    3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges
2pts   Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade
3pts   Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks
4pts   Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls
5pts   Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier
6pts   Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent
8pts   Fronteris Hab Bunker, Manufactorum Administratus,
10pts Zone Morialtis Gang Stronghold
Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing.
All points are per model. For example if you pledge 20 Cultists (1ptx20), 3 Jackals (2ptsx3), a Riderunner (4pts), and a Magus (5pts), your vow would be worth 35pts
Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Genestealer Cults and Xenos to Victory!!!  After June 15th, please do the same in the Xenos Stronghold!
Rules and Place your Vow =>  The Xenos Stronghold
  • 2 weeks later...
* ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS *
Happy painting!  Be sure to cheer on your fellow stronghold participants!
As a reminder, all vows must be completed by September 15th.
I will no longer be monitoring these threads in the faction forums - if you have any questions, please ask me in the Strongholds or @Dr_Ruminahui
Register a new account
Sign in
