Brother Tyler Posted May 15, 2025 Share Posted May 15, 2025 Greetings all Warlords and Warbosses. Call to Arms is back this year, but @Dr_Ruminahui will be running it for @Grotsmasha. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, loyal Astartes (which is new this year), Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for loyal Astartes being their own stronghold. Check out the full rules here If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout! Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 1, 2025 Share Posted June 1, 2025 STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Orks go to the The Xenos Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for the Orks The below list should cover every model for the Orks (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); 1pt Grotz, Boyz, Nobz, Mega Nobz, Flash Gitz, Lootas, Kommanos, Storm Boyz 2pts Snotling Base, Mek Guns, Warbikes, Deff Kopta, Squig Hogz 3pts Killa Kans 4pts Deff Dread 5pts Snazzwagon, Wartrike, Boosta-Blasta, Megatrakk, Rukkatruck, Shokkjump, Trukk 6pts Battlewagon, Hunter/Kill Rig, Blitz/Burna Bommer, Blasta/Dakkajet 8pts Superheavies (Baneblades etc) 10pts Gorkanaut, or was that Morkanaut? 5pts Mek, Big Mek, Boss 10pts Beastboss on Squigosaur, Mozrog Skragbad, Ghazghkull Thraka 20pts Stompa Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 20 Boyz(1ptx20), 3 Deff Koptas (2ptsx3), a Snazzwagon (4pts), and a Warboss (5pts), your vow would be worth 35pts Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Orks and Xenos to Victory!!! After June 15th, please do the same in the Xenos Stronghold! Rules and Place your Vow => The Xenos Stronghold Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/#findComment-6113381 Share on other sites More sharing options...
YoungWolf7 Posted June 2, 2025 Share Posted June 2, 2025 @Dr_Ruminahui - I see the following model entries missing from the list above: Painboss (Counts as Boss? 40mm + 25mm base) Painboy (Bigger/more complex than a standard Boy, but still a 32mm base) Thanks! Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/#findComment-6113745 Share on other sites More sharing options...
Dr_Ruminahui Posted June 2, 2025 Share Posted June 2, 2025 (edited) Are they both characters? If so, they are each 5 points and any attendants they might have (that are on separate bases) are 1 point each. Edited June 2, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/#findComment-6113746 Share on other sites More sharing options...
YoungWolf7 Posted June 2, 2025 Share Posted June 2, 2025 They both have the character keyword, yes. Thanks! Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/#findComment-6113749 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Share Posted June 15, 2025 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these threads in the faction forums - if you have any questions, please ask me in the Strongholds or @Dr_Ruminahui zulu.tango 1 Back to top Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/#findComment-6116278 Share on other sites More sharing options...
Rusted Boltgun Posted June 15, 2025 Share Posted June 15, 2025 'Ullo, Gitz! I've joined the Orks for this year's CTA and pledged some Goff Boyz to the cause. 21 points to kick things off. If I do well, there's a Big Mek, Trukk and maybe even a Mek Gun that could be added! zulu.tango 1 Back to top Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/#findComment-6116312 Share on other sites More sharing options...
Kora'tau Posted June 27, 2025 Share Posted June 27, 2025 (edited) I've decided to join the CTA pledge to help me finish off my orks. I am pledging a total of 22 points So time to Increase the WAAGGGHHH!!!!!! Sadly the points will only count as the 2 bomb squigs, 10 lootas, and a warboss. I also have a mek that i will be picking up this week, so it could actually be 18-22 points depending on if i can include him and what points he would cost. Edited June 27, 2025 by Kora'tau Rusted Boltgun and zulu.tango 2 Back to top Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/#findComment-6118710 Share on other sites More sharing options...
Kora'tau Posted August 15, 2025 Share Posted August 15, 2025 Vow Completed. I have finished the 10 lootas, a warboss, a mek, and 2 bomb squigs. Took me longer than i was anticipating but life got in the way more than expected. Sadly I wont be making any other vows, due to time. The last pic is showing my now 2 meks side by side, just so no one thinks i just reused my first mek. Did a nice head swap on the second mek. I posted this in the xenos stronghold as well. Rusted Boltgun 1 Back to top Link to comment https://bolterandchainsword.com/topic/385878-event-call-to-arms-2025-orks/#findComment-6128169 Share on other sites More sharing options...
