W.A.Rorie Posted May 15, 2025 Share Posted May 15, 2025 Greetings Lords, Ladies, Commanders, Commissars, and Soldiers of the Imperium of Mankind. Call to Arms is back this year, but @Dr_Ruminahui will be running it for @Grotsmasha. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, loyal Astartes (which is new this year), Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for loyal Astartes being their own stronghold. Check out the full rules here If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout! Bonehead and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 1, 2025 Share Posted June 1, 2025 (edited) STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Astra Millitarum, go to the The Imperium Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for Astra Millitarum The below list should cover every model for the Astra Millitarum (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); 1pt Ratlings, Guardsmen, Scions 2pts Ogrynn, Rough Riders 3pts HWTs, Sentinals 4pts Ordnance Batteries, Armiger Knights 5pts Taurox, Chimera Chassis Tanks, Leman Russ Chassis tanks 6pts Valkyrie, Vulture, Rogal Dorn, Malcador Chassis tanks, Macharius Chassis tanks 8pts Baneblades, Shadowswords, Hellhammers etc) 10pts Questoris, Valliant, Castellan, and Cerastus Knights 5pts Psykers, Castellans, Commissars, Tech-Priests Note: points are on a per model basis, so a command squad is 5 points for the character, the others as per the chart above (so typically 1) 40K Scale Titans 20pts Arcastus Knights, Warhound Titan 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 20 Guardsmen(1ptx20), 3 Rough Riders (2ptsx3), Sentinal (3pts), and a Commissar (5pts), your vow would be worth 34pts Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Astra Millitarum and the Imperium to Victory!!! After June 15th, please do the same in the Imperium Stronghold! Rules and Place your Vow => The Imperium Stronghold Edited July 9, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6113357 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Share Posted June 15, 2025 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these threads in the faction forums - if you have any questions, please ask me in the Strongholds or @Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6116265 Share on other sites More sharing options...
Razurok Posted July 9, 2025 Share Posted July 9, 2025 (edited) Starting a new Krieg themed army, here is my pledge: I, Razurok, heed the Call to Arms and pledge to paint 20x Death Riders, 10x Krieg Engineers, 20x Krieg Infantry for 71 points for the Glory of the Death Korps of Krieg and the Imperium Stronghold on or before 15th September 2025, or bear the badge of failure until year's end. For the Emperor!! Edited July 10, 2025 by Razurok Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6120367 Share on other sites More sharing options...
Dr_Ruminahui Posted July 9, 2025 Share Posted July 9, 2025 (edited) Sounds good, @Razurok - but you'll need to post photos of the various models in their unpainted state before you start painting them. So, if you are building as you go along, just go back and edit your post when you finish building a unit and before you put any paint on it. I'm assuming you are painting the little non-model based doodads that come with the kits? So, the grenadier bomb drones and the command squad servo skull scrolls? IF so, I'll give you a 1/2 point for each of those. 50 infrantry x 1 pnt ea. = 50 30 riders x 2 pnts ea = 60 20 engineers x 1 pnt ea = 20 4 engineer bomb drones x 1/2 pnt ea = 2 2x command squads x 5 models x 1 pnt eac = 10 2x Lord Commissars x 5 pnts ea = 10 2x servos skull scrolls x 1/2 pnt ea= 1 3x squads heavy weapons x 3 models x 3 pnts ea = 27 3x heavy weapon spotters x 1 pnt ea = 3 Total 183 points Let me know if you agree with my math, and if not where I may have gotten it wrong. Edited July 9, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6120416 Share on other sites More sharing options...
Razurok Posted July 9, 2025 Share Posted July 9, 2025 Ok sounds good, I’ll edit it accordingly later then. Not sure if this will disqualify for some of the units but I already have 10x death riders + 1x Lord Dreir primed. Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6120476 Share on other sites More sharing options...
Dr_Ruminahui Posted July 9, 2025 Share Posted July 9, 2025 Priming is fine, any paint beyond that is not. So if they are just primed, you're good. Lord Dreir? Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6120480 Share on other sites More sharing options...
Focslain Posted July 9, 2025 Share Posted July 9, 2025 @Dr_Ruminahui Lord Dreir is the Death Rider Special character. Basically a mounted character. Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6120489 Share on other sites More sharing options...
Dr_Ruminahui Posted July 9, 2025 Share Posted July 9, 2025 (edited) He didn't list him in his vow, though, which made me curious. @Razurok, is Lord Drier part of your call to arms vow? If so, is he counted in the 20 death riders or in addition to? Anyway, if he is vowed, he's worth 10 points. Incidentally, you need to paint everything in your vow by September 15 to have any of it count - so if you have doubts getting through all that in time (I definitely couldn't) you might want to break it down into a smaller vow and start with that, and add other vows (you get 3 + 1 of a model 10 pnts or more in value) as you feel you can complete as you finish your previous vow(s). Edited July 9, 2025 by Dr_Ruminahui kabaakaba 1 Back to top Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6120492 Share on other sites More sharing options...
Razurok Posted July 10, 2025 Share Posted July 10, 2025 I updated my pledge and went for a smaller vow, totaling 71 points. I edited my original post with pictures of the units. Excited for this challenge! Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385884-event-call-to-arms-2025-astra-militarum/#findComment-6120563 Share on other sites More sharing options...
