Brother Tyler Posted May 15, 2025 Share Posted May 15, 2025 Greetings all warlords of the Horus Heresy. Call to Arms is back this year, but @Dr_Ruminahui will be running it for @Grotsmasha. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, loyal Astartes (which is new this year), Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for loyal Astartes being their own stronghold. Check out the full rules here If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout! Trokair and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385886-event-call-to-arms-2025-epic-horus-heresy/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 1, 2025 Share Posted June 1, 2025 STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Horus Heresy go to the The Heresy Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for the Heresy The below list should cover every model for the Heresy (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); 1pt Infantry Base, Dreadnaught Base, Rapier Base, Jetbike/Speeder Base, Sentinal Base, Rhino, Predator, Medusa, Leman Russ, Drop Pod 2pts Sicaran, Land Raider, Spartan, Malcador, Armiger Knights, Questoris Knights, Ceratus KInights 3pts Fellblade Chassis tanks, Kratos Battletank, Baneblade Chassis tanks, Arcastus Knights, LI/AI Aircraft 4pts Thunderhawk Gunship 5pts Warhound Titan 6pts Reaver Titan 7pts Warbringer Titan 8pts Warlord Titan 10pts Warmaster Titan 5pts Leader and Unit Composition: Command Base *I am super unfamiliar with the Aeronautica Craft, so please let me know if there need to be more points gradings for the different Aircraft* Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 5 Infantry bases (1ptx5), 2 Warmaster titans (2ptsx10), 3 Landraiders (3x2pts), and a Thunderhawk (4pts), your vow would be worth 35pts Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the forces of the Emperor or Warmaster and the Heresy to Victory!!! After June 15th, please do the same in the Heresy Stronghold! Rules and Place your Vow => The Heresy Stronghold Link to comment https://bolterandchainsword.com/topic/385886-event-call-to-arms-2025-epic-horus-heresy/#findComment-6113385 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Share Posted June 15, 2025 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these threads in the faction forums - if you have any questions, please ask me in the Strongholds or @Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385886-event-call-to-arms-2025-epic-horus-heresy/#findComment-6116282 Share on other sites More sharing options...
