Brother Tyler Posted May 15 Share Posted May 15 Greetings all warlords of the Age of Darkness. Call to Arms is back this year, but @Dr_Ruminahui will be running it for @Grotsmasha. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, loyal Astartes (which is new this year), Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for loyal Astartes being their own stronghold. Check out the full rules here If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout! Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 1 Share Posted June 1 (edited) STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Horus Heresy go to the The Heresy Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for the Heresy The below list should cover every model for the Heresy (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); 1pt Scouts, PA mkII through mkVII, Terminators, Thallax 2pts Bikes, Outriders, Jetbikes, Tarantula 3pts Rapier Teams, Land Speeders, Dreadnoughts, Castellax 4pts Thanatars, Armiger Knights 5pts Nemesis Dreadknight, Rhino Chassis Tanks, Impulsor, Gladiators, Drop Pod, Anvillus Dreadclaw 6pts Xiphon, Sicaran Chassis Tanks, Landraiders, Spartans, Terrax Drill, Kharybdis Assault Claw 8pts Glaive, Fellblade, Falchion, Fire Raptor, Storm Eagle 10pts Mastadon, Questoris, Valliant, Castellan, and Cerastus Knights 5pts Vigilator, Moritat, Techmarine, Apothecary, Consul, Centurions, Praetors 10pts All Primarchs 40K Scale Titans 20pts Arcastus Knights, Warhound Titan, Thunderhawk 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan, Stormbird Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Mortalis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 20 Legionaires (1ptx20), 3 Outriders (2ptsx3), a Javelin (3pts), and a Praetor (5pts), your vow would be worth 34pts Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the forces of the Emperor or Warmaster and the Heresy to Victory!!! After June 15th, please do the same in the Heresy Stronghold! Rules and Place your Vow => The Heresy Stronghold Edited June 16 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6113384 Share on other sites More sharing options...
SirTainly Posted June 10 Share Posted June 10 (edited) Pledging all this for Heresy as I have an UM Armoured Spearhead to complete before October (so most will need to be done by the end of this anyway). This might change with Heresy 3.0 points but it's currently. 7 x Predator 2 x Sabre 1 x Scorpius 1 x Rhino 10 x Marines 1 x Apothecary 1 x Techmarine 1 x Contemptor I think that's a pledge of 78 points. Edited as I had to change my list due to failing to understand my Rite of War properly! Edited June 10 by SirTainly Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6115190 Share on other sites More sharing options...
Dr_Ruminahui Posted June 10 Share Posted June 10 Provided those aren't IA scale models, my math comes out to 78 points as well. Happy painting! Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6115356 Share on other sites More sharing options...
Shard of Magnus Posted June 12 Share Posted June 12 I’m considering pledging the following for heresy (loyalists), although not sure if I will split it across several smaller pledges or have one large one. 1 consul 20 marines 2 rhinos 1 spartan 2 sicarans 6 jetbikes 2 armigers 2 castellax 6 thallax If thallax are 1 point and castellax 3, that should be 85 points. Not sure I can finishing painting all the above during the event timeframe either so might need to trim the list. Or add to it. My heresy pile to paint is quite a bit larger than this. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6115731 Share on other sites More sharing options...
SvenIronhand Posted June 12 Share Posted June 12 I’ll probably pledge a squad of Indomitus Terminators (given combi-bolters and with shaved-off aquilas). Still pumping out my Tacticals, though. Lautrec the Embraced and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6115733 Share on other sites More sharing options...
Dr_Ruminahui Posted June 12 Share Posted June 12 (edited) Cas 2 hours ago, Shard of Magnus said: I’m considering pledging the following for heresy (loyalists), although not sure if I will split it across several smaller pledges or have one large one. 1 consul 20 marines 2 rhinos 1 spartan 2 sicarans 6 jetbikes 2 armigers 2 castellax 6 thallax If thallax are 1 point and castellax 3, that should be 85 points. Not sure I can finishing painting all the above during the event timeframe either so might need to trim the list. Or add to it. My heresy pile to paint is quite a bit larger than this. That is correct - thallax are 1 and castellax are 3. I;ve added them to the points list. My math comes to 85 points as well. Edited June 12 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6115741 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15 Share Posted June 15 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these threads in the faction forums - if you have any questions, please ask me in the Strongholds or @Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6116281 Share on other sites More sharing options...
Dwango Posted June 24 Share Posted June 24 Quick works in progress shot of my vow. The Istvaan 3 board has paint on. Going to work o the buildings tonight I think. I've done the train tracks and craters and started the ruins. Seem to be getting the easier stuff out of the way first. Shard of Magnus and Lautrec the Embraced 2 Back to top Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6118256 Share on other sites More sharing options...
Lautrec the Embraced Posted July 3 Share Posted July 3 (edited) Progress so far - almost done with the blues, finally time for some other colours. The new Terminators are much chonkier than I expected, they really look intimidating next to Mk6 (and compared to old Mk3/4, it's like that one Tyberos the Red Wake art) Edited July 4 by Lautrec the Embraced librisrouge and Dwango 2 Back to top Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6119558 Share on other sites More sharing options...
SirTainly Posted August 1 Share Posted August 1 On 6/10/2025 at 9:00 AM, SirTainly said: Pledging all this for Heresy as I have an UM Armoured Spearhead to complete before October (so most will need to be done by the end of this anyway). This might change with Heresy 3.0 points but it's currently. 7 x Predator 2 x Sabre 1 x Scorpius 1 x Rhino 10 x Marines 1 x Apothecary 1 x Techmarine 1 x Contemptor I think that's a pledge of 78 points. Edited as I had to change my list due to failing to understand my Rite of War properly! Sadly going to have to drop on this, as at the moment I've no plans to move to HH3.0 which is where my local group is heading. I may do some more 40k instead, but it's looking like a lot of r/l stuff to deal with too in the next few months - not sure I will be painting any minis. Link to comment https://bolterandchainsword.com/topic/385887-event-call-to-arms-2025-age-of-darkness/#findComment-6125645 Share on other sites More sharing options...
