Xenith Posted May 15, 2025 Share Posted May 15, 2025 (edited) Greetings Hive Tyrants, Neurotyrants, Norn Emissaries, and particularly feisty Gaunts! Call to Arms is back this year, but @Dr_Ruminahui will be running it for @Grotsmasha. For those new to B&C or simply unaware, Call to Arms is a Forum wide event that this year runs from June 15th until September 15th! The forum is split up into 5 Strongholds: Imperium, Loyal Astartes (which is new this year), Chaos, Xenos and Heresy with all 5 factions competing against one another to paint the most in the 3 months time limit. There will be a Central hub thread for each of the Strongholds in the Work in Progress section of the Forge forum which will be linked once it's live. We can use thread to cross post in and track/give motivation to those participating. For those of you familiar with previous Call to Arms events, the rules are exactly the same this year except for loyal Astartes being their own stronghold. Check out the full rules here If you've got any questions, give @Dr_Ruminahui or one of the Mods a shout! Edited May 14, 2025 by Xenith ZeroWolf and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 1, 2025 Share Posted June 1, 2025 (edited) STRONGHOLDS OPEN JUNE 15, 2025 For the Full Rules and where to place your vows for the Tyranid go to the The Xenos Stronghold Start Date: 15th June End Date: 15th September Here is a more detailed list of points per model specifically for the Tyranid The below list should cover every model for the Tyranid (if I'm missed any, please let me, @Dr_Ruminahui, know and I'll figure out their point values and add them); 1pt Horm/Term/Neuro/Barbagaunt, Gargoyle, Genestealer, Pyro/Biovore, Spores, Van Ryan 2pts Ripper Swarms, Warriors, Lictor, Venom/Zoan/Neurothropes, Ravenors 3pts Hive/Tyrant Guard 5pts Tervigon, Exo/Toxicrene, Maleceptor, Haruspex, Tyrannofex, Tyrannocyte, Carnifex, Screamer Killer, Psychophage, Norns 7pts Harpy, Hive Crone 8pts Dimacheron 5pts Broodlord, Tyranid Prime, Neurotyrant, Deathleaper 10pts Swarmlord, Winged/Hive Tyrant Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Morialtis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Morialtis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechsnicus Transterrsnic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Morialtis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. All points are per model. For example if you pledge 20 Termagaunts(1ptx20), 3 Ravenors(2ptsx3), a Tervigon (5pts), and a Winged Hive Tyrant (10pts), your vow would be worth 41pts Please feel free use this thread as a place to share your thoughts, ideas, and WIPs prior to the Event to motivate and inspire the Tyranid Empire and Xenos to Victory!!! After June 15th, please do the same in the Xenos Stronghold! Rules and Place your Vow => The Xenos Stronghold Edited June 12, 2025 by Dr_Ruminahui ZeroWolf and Mike Zulu 2 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6113383 Share on other sites More sharing options...
Antarius Posted June 10, 2025 Share Posted June 10, 2025 @Dr_Ruminahui How about Mawlocs/Trygons and the Norn Assimilator/Emissary (I don't actually have the latter, but I gues someone else might). Also, do I understand the rules correctly that a Hive Tyrant is eligible for the Job's a Big'un? If it's 10+ points, I guess it is, I'm just a bit confused because a Hive Tyrant isn't actually all that big. But I'm probably just overthinking things... Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6115393 Share on other sites More sharing options...
Dr_Ruminahui Posted June 10, 2025 Share Posted June 10, 2025 All 4 of those are 5, being non-characters and about Tyrannofex size, who is also 5. I know there is a lot of range of scale in the 5 point bracket for Tyranids, but none of them seem quite big enough to be put at 6 points. Again, I'm happy to reconsider, but photos next to other 6 point things would be appreciated if you want me to do that. Hive Tyrant being 10 is a bit a legacy issue, I guess, being the model that was the closest to Primarch equivalent in Tyranids at the time. Is there a larger nid character now? I'm happy putting whatever is bigger in that slot instead, and maybe keeping the winged tyrant there if I can compare the models beside each other. And yes, any 10+ point model can be a "Job's a Big'un" vow. Antarius and ZeroWolf 2 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6115440 Share on other sites More sharing options...
Antarius Posted June 12, 2025 Share Posted June 12, 2025 Thanks! I think we'll be vowing a winged tyrant for the "Job's a Big'un" then - I'm fiddling with cleaning and assembling it as we speak Sadly, I don't have any possibility to do a size comparison for the Norn Emissary/Assimilator, as I don't have one (yet...). But if no-one is actually vowing one, it might be one of those things that doesn't matter all that much until it actually comes up. All I really know about it is that it's new, looks huge and is supposedly a bit smaller than it looks in the photos Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6115779 Share on other sites More sharing options...
The Pounder Posted June 12, 2025 Share Posted June 12, 2025 Funnily enough, I have just finished a Winged Tyrant and have a Norn Emissary! I’ll get a comparison pic later if you still want to see? Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6115800 Share on other sites More sharing options...
Dr_Ruminahui Posted June 12, 2025 Share Posted June 12, 2025 3 hours ago, The Pounder said: Funnily enough, I have just finished a Winged Tyrant and have a Norn Emissary! I’ll get a comparison pic later if you still want to see? That would be helpful. Do you happen to have a rhino and/or a landraider (or if not, a tyranofex and/or a carnifex) you can throw in the photo with them? Thanks. Though, am I correct in thinking the Norns aren't characters? Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6115842 Share on other sites More sharing options...
The Pounder Posted June 12, 2025 Share Posted June 12, 2025 Sadly I don’t currently own any Marine vehicles at the moment. I did however manage a side by side pic of the Flyrant and Norn Emissary! Also, I can confirm the Norn Emissary is NOT a character it is a Monster, though it does have Synapse. Hope that helps. Dr_Ruminahui, ZeroWolf and Antarius 3 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6115871 Share on other sites More sharing options...
Dr_Ruminahui Posted June 12, 2025 Share Posted June 12, 2025 (edited) Thanks for that, @The Pounder - it was very helpful. The only reason the flyrant is 10 is because it is a character AND is a centerpiece/big. The Norn, being monster, is 5 points unless it is sufficiently large enough to make it into the 6 point category - which it doesn't (in other words, it doesn't get the "bump up" for being a character model). Despite it being quite a bit larger than the other tyranid models, I feel its still closer to rhino than landraider in scale. Edited June 12, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6115874 Share on other sites More sharing options...
ZeroWolf Posted June 14, 2025 Share Posted June 14, 2025 I honestly was expecting the emissary/assimilator to be bigger than that So a winged Tyrant is 10pts then? Good thing I looked in here before making the vow tomorrow! I'd previously worked it out as 39pts total (20x Hormagaunts, 5x Barbagaunts, 9x Leapers, 1x Tyrant), so it looks like its now 44pts? Have I got that right? Antarius and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6116128 Share on other sites More sharing options...
Dr_Ruminahui Posted June 14, 2025 Share Posted June 14, 2025 Looks right to me. ZeroWolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6116152 Share on other sites More sharing options...
ZeroWolf Posted June 14, 2025 Share Posted June 14, 2025 Brilliant, thank you Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6116154 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Share Posted June 15, 2025 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. I will no longer be monitoring these threads in the faction forums - if you have any questions, please ask me in the Strongholds or @Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6116280 Share on other sites More sharing options...
Antarius Posted June 15, 2025 Share Posted June 15, 2025 20 hours ago, ZeroWolf said: I honestly was expecting the emissary/assimilator to be bigger than that Same here - in fact, even though I'd already been told that it was smaller than it looked in the Codex, I was still surprised! ZeroWolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6116294 Share on other sites More sharing options...
Antarius Posted June 15, 2025 Share Posted June 15, 2025 @Dr_Ruminahui I just noticed that Old One Eye isn't mentioned. He's a character/epic hero as well as a Carnifex. I'm going to vow him, but I'm guessing he's still 5 pts. like a regular Carnifex? Realistically speaking it's just another head variant, so I don't think he's really all that different from a "normal" Carnifex, when it comes to how big a job it is to paint him. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6116304 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Share Posted June 15, 2025 Sure, that works. I was thinking of regular pricing for the Tervigon as well, which I think is technically a character this edition, but really isn't any more ornate or complex than the tyranofex. Link to comment https://bolterandchainsword.com/topic/385899-event-call-to-arms-2025%C2%A0tyranids%C2%A0%C2%A0/#findComment-6116364 Share on other sites More sharing options...
