I just read through the leaks and it seems to me we lost access to chaff units. Cultist are gone which is very sad and I think Tzaangors got changed to the worse or at least their role changed.
They lost battleline, -1 OC, lost their AP on Tzaangor blades, lost access to 5+FNP through their shaman. They got scout 6 and their ability changed to remove from battlefield in enemy turn into strategic reserve.
They got a massive price hike even if they got worse. They cost now for 10/20 models 70/160 points from the 65/120 points they were until now. A big unit of 20 costs 40 points more in an already very pricy army and way to much for a chaff unit that dies very fast.
I think their role now is holding/fulfilling objectives and redeploying but don't know how effective at that they are now.
Just skimed the mutant detachment and I was very underwhelmed. Getting d3 wounds for a meagre bonus doesn't seem good. Same with the new ability of the shaman.
What are your thoughts?
Edited by Anon
https://bolterandchainsword.com/topic/385912-tzaangors-in-10th-edition-codex/
10 Tzaangors still feels chaff-y.
Scout helps them get to objectives in the middle, +1 Ld from the Herdbanner helps them score it, and they can still have OC2 + Battleline with in the "Tzaangor-detachment".
Blades losing their AP-1 sucks, but that just means I'll run mine with Chainswords now, so it's a sidegrade at worst.
I do think GW screwed up a bit by making them 70/160 though, should've been 70/150 at most.
As for the Tzaangor-detachment, I sort of like it.
You can ressurect models (thay may or may not have been sacrificed) and even attach a Sorcerer/Infernal Master to them, for some change in how they play. With 6" Scout and re-roll charge, the advance&charge-strat will also see some play.
I also like the idea of running a utility-shaman (since they're dirt cheap) and if he somehow gets killed on an objective, you can just turn him into a spawn.
Is it a 10/10 detachment? Heck no, but it does seem fun.
Edited by Minsc
In my opinion Tzangors are significantly better than they were before from a rules perspective.
Biggest negative for sure is losing battle line.      The removal of the -1AP for their blades for me is like minsk, a sidegrade so that I'll switch them to chainswords and autopistols.   Adding scout plus the returning to strategic reserves is a huge upgrade to their previous unit rule which was kind of garbage.
That said, I for sure agree they are not worth the 70 points.     At 70 points, they are the same cost as a space marine scout squad and have a worse armour save, don't infiltrate and have worse weapons, and the 10 bodies are harder to hide than a 5 man scout squad.
Register a new account
Sign in
