kabaakaba Posted May 20, 2025 Share Posted May 20, 2025 Omnissiah’s Blessing: In your Command phase, select one friendly Astra Militarum Vehicle model within 3" of this model. That Vehicle model regains up to D3 lost wounds and, until the start of your next Command phase, that Vehicle model has a 4+ Invulnerable Save. Each model can only be selected for this ability once per turn. The question is does the target model must be damaged? or any AM Vechicle within 3" can de targeted with this ability? Because there is nothib about model must be damaged Link to comment https://bolterandchainsword.com/topic/385940-tech-priest-enginseer-omnissiah%E2%80%99s-blessing/ Share on other sites More sharing options...
Solution Karhedron Posted May 20, 2025 Solution Share Posted May 20, 2025 I think that the vehicle does not have to be damaged. You simply select one vehicle, not a damaged vehicle. The vehicle regains up to D3 lost wounds. Zero is up to D3. Also, the second part (the 4++) is not contingent on wounds being regained. I think that an undamaged vehicle is a valid target for the ability, it simply regains zero wounds because it has not lost any but the 4++ still applies. Dr_Ruminahui, DemonGSides and kabaakaba 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385940-tech-priest-enginseer-omnissiah%E2%80%99s-blessing/#findComment-6110931 Share on other sites More sharing options...
kabaakaba Posted May 20, 2025 Author Share Posted May 20, 2025 thx, that nice 4++ my main concern DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/385940-tech-priest-enginseer-omnissiah%E2%80%99s-blessing/#findComment-6110932 Share on other sites More sharing options...
DemonGSides Posted May 21, 2025 Share Posted May 21, 2025 (edited) It does not need to be damaged. First sentence says target a vehicle, that's the only check done. Doesn't say "Choose a vehicle at below starting strength" which is the terminology it would have if it was required to be hurt already. Edited May 21, 2025 by DemonGSides Dr_Ruminahui and kabaakaba 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385940-tech-priest-enginseer-omnissiah%E2%80%99s-blessing/#findComment-6111095 Share on other sites More sharing options...
Magos Takatus Posted June 7, 2025 Share Posted June 7, 2025 Sounds like you can just slather that puppy in holy unguents to get your invulnerable. :) Link to comment https://bolterandchainsword.com/topic/385940-tech-priest-enginseer-omnissiah%E2%80%99s-blessing/#findComment-6114704 Share on other sites More sharing options...
