Dr_Ruminahui Posted June 1, 2025 Share Posted June 1, 2025 (edited) The Call to Arms 2025 IMPERIUM STRONGHOLD Time to bust out those brushes and paints and stand ready to represent your Forum/s of choice and aid them on the path to claim Victory!!!! What is The Call to Arms, I hear you ask? The Call to Arms is a multi-forum event designed to encourage us all to start a new army, or bolster our current forces. The Forums of the B&C are divided up into five Strongholds; The Astartes Stronghold Adeptus Astartes Black Templars Blood Angels Dark Angels Space Wolves Ultramarines Grey Knights Deathwatch (note, Deathwatch models can be vowed either in the Astartes or Imperium Strongholds) The Imperium Stronghold Adepta Sororitas Adeptus Mechanicus Astra Militarum Imperial Knights Talons of the Emperor The Imperium of Mankind Deathwatch (note, Deathwatch models can be vowed either in the Astartes or Imperium Strongholds) The Chaos Stronghold Chaos Daemons Chaos Knights Heretic Astartes Death Guard Emperor's Children Thousand Sons World Eaters The Realm of Chaos The Xenos Stronghold Aeldari Drukhari Genestealer Cults Leagues of Votann Necrons Orks T'au Empire Tyranids The Heresy Stronghold Age of Darkness Epic Scaled Heresy Games These five Strongholds will act as the hub for each of the five main Factions, and will for the 3 Month duration of the Call to Arms, run independently of the four other Strongholds. Each Stronghold may have different targets and goals, and even their own mini/complementary events, all with unique badges and achievements, but at the end of the 3 months, the five Strongholds will face off, and overall winners will be declared. Dates Start Date: 15th JUNE 2025 End Date: 15th SEPTEMBER 2025 (Timezone will be GMT -8 [so, North American Pacific Coast time], please make local adjustments for time) So, how is it all going to work? 1. As each of the Strongholds are acting (initially) as their own Events, you may choose to focus within a single Stronghold, or participate in all five Strongholds, and any complementary/mini-events that you would like to. Your Vows will be treated independently in each Stronghold, meaning a Failed Vow in one Stronghold will NOT effect Vows in the other Strongholds. 2. Models pledged to a Stronghold must come from the army books associated with those Forums covered by each Stronghold. The exceptions to this are Titans and models not associated with a given faction (such as Necromunda models and terrain), these models / units may be pledged to any Stronghold. 3. You may join in any of the Events at any time within the 3 Month time-frame of The Call to Arms 4. For each Stronghold, you have a MAXIMUM of 3 Vows, you must finish your active vow before pledging to a second or third vow. 5. In addition to the three Vows, any model in the 10pt Category or higher will fit into the "Job's a Big'un" Vow, and will run separate from the 3 Vow limit and have the entirety of the 3 months to be completed. 6. Once recorded, Vows may not be altered, however special considerations may be made upon request. 7. There is no minimum pledge, you may vow 1 model, or your entire collection, but beware, failing your last active vow will invalidate any completed vows you may have already submitted. How do I join in? Each model has a point value based upon its size, and the comparative amount of effort and time it takes to paint said model, listed below are are the points-per-model, more specific lists can be found in each Forums Rally Point thread, but I've added some generic examples below, 1pt Infantry 2pts Cavalry/Bikers 3pts Heavy Weapons Teams / Walkers (Dreadnaughts, Sentinels) 4pts Skimmers / Light Vehicles (Landspeeders, ATV, Armigers) 5pts Small Tanks (Leman Russ, Rhino Variants) 6pts Large Tanks (Rogal Dorn, Sicaran, Land Raider) 8pts Superheavies (Baneblades etc) 10pts Imperial Knight etc Characters 5pts Leader/Character models 10pts Primarchs Note: Characters with Retinue, I.E. Saint Celestine. The Leader model is worth 5pts, the other models are pointed as to their type - for example, Saint Celestine and her bodyguard would be 7 points - 5 for the Saint (leader), 1 each for her 2 seraphim buddies. 40K Scale Titans 20pts Warhound Titan 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Mortalis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Mortalis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechanicus Transterranic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshrine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Mortalis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. You may vow ANY MODEL that is covered by THIS STRONGHOLD, but you must allocate your points to only one SUBFACTION. These Subfactions are the ones listed under the various Strongholds above, and are the various B&C forums/subforums, with 2 exceptions: a) Deathwatch is a valid Subfaction for both the Astartes and Imperium Strongholds, despite not having a dedicated forum/subforum; and b) in the HERESY STRONGHOLD, the Subfactions are "Emperor" and "Warmaster", not the 2 B&C forums listed above. NOTE: Your chosen Subfaction doesn't have to correspond to your vowed models, although it typically does. Please make your vows in this thread in the following format; "I, {insert username}, heed the Call to Arms and pledge to paint {insert units/models} for {xxx pts} for the Glory of the {Subfaction name} and the {Stronghold name} Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." For example: "I, Dr Ruminahui, heed the Call to Arms and pledge to paint 6 seraphim, a vindicare assassin, Saint Celestine and her bodyguard and a Necromunda Fuel Tanks for 21 pts for the Glory of the Adepta Sororitas and the Imperium Stronghold on or before September 15th, or bear the badge of failure until year's end." The post that contains your Vow must include starting pictures that contain all the models from the Vow. Starting models may be in any of the following conditions; In the box On the Sprue Assembled Single Colour Primed Sub-assemblies primed in different colours will be acceptable, I.E. chassis in Leadbelcher, with armour plates in secondary colour. Additionally, you may pledge models you have not yet received I.E. Warhammer: Imperium Subscription, just make sure a image is edited in to your Vow post once you've received the models, and make a post indicating that you have done so. Your Vow is considered complete when you declare it so, and post completed pictures of all models contained within the Vow. Although "Complete" is to your own standard, we would like you to aim for GW's "Battle Ready", with the miniatures based. If basing is something you don't do, or won't be doing within the Event's timeline, please return the bases to flat black or brown as this will greatly enhance the Completed presentation. Required Completion Pictures: Please include 1 image with a complete shot of the entire Vow, I also encourage everyone to include additional images for each squad/unit in the vow,. Once you have made your vow, pop this badge of Participation into your Signature, Will there be any awards? Yes!! There will be Badges and Achievements within the Astartes Stronghold. Note, all badges/ranks/achievements are a different thing and entirely separate from the ranks and achievements tracked by the forum software. Event Failed: Servitor 10 points: Veteran 25 points Sergeant 45 points: Captain 75 points: General 100+ points: Theatre Commander Artificer - Top 1, 2, or 3 best painted models from each Forum, chosen by the forum Moderators, Administrators and Librarians. Princeps - Awarded to all completed 40K scale Titans Imperium Champion - Awarded to the Frater who individually paints the most points worth of models in the Imperium Stronghold Champions of the Horde - The Subfaction for each Stronghold with the highest overall points worth of models Champion of the Call - The Subfaction for each Stronghold that has the Highest Participation vs. Completion Percentage. As to the overall competition between the Strongholds, there will also be Badges awarded for the following; Masters of the Horde - The Stronghold that completes the highest overall points worth of models. Masters of the Call - The Stronghold that has the Highest Participation vs. Completion Percentage. Master Artificer - Voted best painted Model, chosen from the 5 Stronghold Artificers. In addition to the Badges and Achievements above, there will be additional Awards for the following 4 categories. At this stage there are no physical prizes like last year, but that *MAY* change by the end of the Event. Favourite Young Blood - This category is for Participants who have been building and/or painting models for less than 12 months. Anyone wishing to participate as A Young Blood will need to specifically declare that are are doing so when making their Vows. At the conclusion of the Event all Young Blood Entries will be placed into a Poll for the B&C at large to vote on and pick a Favourite. The voting criteria for this category is not about picking the best painted model, but the model that inexplicably pulls a smile on your face, one that makes you think, damn that's cool.. Master of the Forge - Best Conversion or Kit-bash. Anyone wishing to participate for the Master of the Forge Badge and Prize will need to specifically declare that they are doing so when they vow the model. Stronghold Artificer - Awarded to five Participants, one from each Stronghold for the Best Painted Model in from the Stronghold, chosen by the Frater via Poll. Grand Marshal - Individual with the Most Points of Models Painted across all Strongholds That's it, you've done it, you've made it to the end!!! If you have any questions or queries, contact me, @Dr_Ruminahui and I'll be more than happy to help you out. F.A.Q.s Q- If I have models with different coloured heads or shoulder pads, can they be primed different colours IE. Black templars or Eldar Guardians? A- Yes, this is acceptable. Q- I want to paint Traitor Guard, is there a way to pledge them to Chaos? A- Yes, for the purposes of Traitor Guard, the Astra Militarum units may be pledged to Chaos. The Realm of Chaos is the most appropriate forum. Q- Are 3D prints allowed? A- Yes, as long as they are board appropriate, 3D prints can be pledged to the Call to Arms. Use the points associated with the unit they represent. THIS THREAD WILL REMAIN LOCKED UNTIL JUNE 15, 2025, AT WHICH TIME VOWS MAY COMMENCE Edited May 29, 2025 by Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 1, 2025 Author Share Posted June 1, 2025 (edited) PARTICIPANTS TOTAL STRONGHOLD RESULTS - Pledged: 214.5 pnts / Completed: 198.5 pnts / Secured: 198.5 pnts / 92.54% Completed - 7 Participants, 6 (85.71%) completed all Imperium vows Adepta Sororitas - Pledged: 0 pnts / Completed: 0 pnts / Secured: 0 pnts / n/a % Completed Participants: 0 Adeptus Mechanicus - Pledged: 0 pnts / Completed: 0 pnts / Secured: 0 pnts / n/a % Completed Participants: 0 Astra Millitarum - Pledged: 126 pnts / Completed: 110 pnts / Secured: 110 pnts / 87.30% Completed Participants: (3 Total, 2 Secured - 66.67%) The Pounder - Vow 1: 34 pnts - Complete; Vow 2: 5 pnts - Complete 10 9x Krieg infantry 1x Sentinel (swapped in for missing krieger)3x Krieg heavy weapons 1x krieg fire coordinator5x Deathriders 1x Krieg artillery team 1x Lord Solar GSCUprising - Vow 1: 16 pnts - Incomplete 10x Kasrkin 1x Valkyrie Razurok - Vow 1: 71 pnts - Complete 1, 2 20x Death Riders10x Krieg Engineers with 2x drones20x Krieg Infantry Imperial Knights - Pledged: 6 pnts / Completed: 6 pnts / Secured: 6 pnts / 100.00% Completed Participants: (1 Total, 1 Secured - 100.00%) Karhedron - Vow 1: 6 pnts - Complete 6x Scions Talons of the Emperor - Pledged: 0 pnts / Completed: 0 pnts / Secured: 0 pnts / n/a % Completed Participants: 0 The Imperium of Mankind - Pledged: 37.5 pnts / Completed: 37.5 pnts / Secured: 37.5 pnts / 100.00% Completed Participants: (2 Total, 2 Secured - 100.00%) Lord_Ikka - Vow 1: 22 pnts - Complete 1x Ash Wastes Outrider 20x Security troops Dr. Clock - Vow 1: 15.5 pnts - Complete 1x Priest 9x Sanctifiers 1x Cherub1x Arco-Flagellant Deathwatch - Pledged: 45 pnts / Completed: 45 pnts / Secured: 45 pnts / 100.00% Completed Participants: (1 Total, 1 Secured - 100.00%) Antarius - Vow 1: 45 pnts - Complete 1, 2 1x Watch captain1x Apothecary10x Deathwatch veterans teams10x Fortis5x Intercessors2x Razorbacks Edited September 17, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6113400 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6116253 Share on other sites More sharing options...
Antarius Posted June 15, 2025 Share Posted June 15, 2025 "I, Antarius, heed the Call to Arms and pledge to paint a Watch Captain, Apothecary, two Deathwatch Veteran teams, a Fortis Kill Team, an Intercessor Squad and two Razorbacks, totalling 45 pts. for the Glory of the Deathwatch and the Imperium Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." (The Apothecary's shoulder pads are separate at present, but one is primed white, the other is a Deathwatch shoulder pad that is presently unprimed. I've had to sub in a heavy bolter for a grenade launcher in the Intercessor squad, but that's just an aesthetic thing). 4 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6116293 Share on other sites More sharing options...
Antarius Posted June 15, 2025 Share Posted June 15, 2025 "So anyway Antarius, what are you going to do to make this project completely impractical and OTT?" Well, I thought I might paint half the armour in the original chapter colours of the individual marines and then paint the other half in the usual Deathwatch Black: I think it'll look good and I've always sort of wanted to do a halved colour scheme, so I figured this would be a nice opportunity. Plus, it lets me indulge in my love for pretty much all the chapters out there. 5 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6116426 Share on other sites More sharing options...
The Pounder Posted June 16, 2025 Share Posted June 16, 2025 (edited) “I, The Pounder, heed the Call to Arms and pledge to paint 10 Death Korps of Krieg Infantry, a Heavy Weapon Squad, 5 Deathriders and a Krieg Artillery Team, totalling 34pts. for the Glory of the Death Korps of Krieg and the Imperium Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." Looking forward to get going on these! Haven’t had the chance to build them yet but it’s all good! Pics to follow! Edited June 16, 2025 by The Pounder 7 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6116584 Share on other sites More sharing options...
Dr_Ruminahui Posted June 16, 2025 Author Share Posted June 16, 2025 @The Pounder, I have you at 33 points rather than 34: 10x Krieg infantry (10 x 1= 10)3x Heavy weapons (3 x 3 = 9)5x Deathriders (5 x 2 = 10)1x Krieg artillery team (4) Equals 33, by my math, anyway. Let me know if you think I missed anything. Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6116644 Share on other sites More sharing options...
The Pounder Posted June 16, 2025 Share Posted June 16, 2025 Apologies, I forgot to say they were Krieg HWT! Krieg Heavy Weapons Squads come with a Fire Coordinator (single Korpsman on foot) so that’s where the extra pt came from! 1 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6116653 Share on other sites More sharing options...
kabaakaba Posted June 16, 2025 Share Posted June 16, 2025 (edited) It's complicated, because krieg hwt is 3 mini with one model - the gunner on weapon and coordinator is 4th model. Not like standard hwt with 2 guys on each base Edited June 16, 2025 by kabaakaba 1 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6116656 Share on other sites More sharing options...
Dr_Ruminahui Posted June 16, 2025 Author Share Posted June 16, 2025 (edited) @The Pounder, I think you did say they were Krieg, but I was unfamiliar with the models . Next year, I may bump them down to 2 pnts/model as they are about the same size as other 2pnt models (and lack the extra guy of the other AM heavy weapon teams) but I'll keep them as is for this year. So I've put your vow back at 34 pnts. Edited June 16, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6116697 Share on other sites More sharing options...
Antarius Posted June 19, 2025 Share Posted June 19, 2025 Vow complete! There's also an additional marine in there that I'd started on but decided to just finish along with the rest of the lot. Bases are still wet, but hopefully we'll see some crackle effect once they dry. 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6117454 Share on other sites More sharing options...
Antarius Posted June 19, 2025 Share Posted June 19, 2025 This post was recognized by Dr_Ruminahui! "Congratulations on completing your vows for the Imperium Stronghold during Call to Arms 2025" Antarius was awarded the badge 'Call to Arms 2025 Imperium' And a shot of them all together, just to make it a bit easier - never mind the tyranids sneaking up on them! 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6117455 Share on other sites More sharing options...
Dr. Clock Posted June 20, 2025 Share Posted June 20, 2025 18 hours ago, Antarius said: sneaking up on them! Surely they're just advancing toward the rear. You're making us all look pretty bad over here Ant! I think my favourite part of this is that the Templars and Iron Hands are all just like... 'See? Black goes with everything!' Non-joke fave is the Griffon boi. Cheers, The Good Doctor. 1 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6117561 Share on other sites More sharing options...
Antarius Posted June 21, 2025 Share Posted June 21, 2025 Thanks, I’m glad you like them! I am going to concentrate on my Tyranid vow for now, but I’ll be back with another Deathwatch vow soon(ish). I just have to model a couple of kill teams (which is a bit difficult, as I honestly can’t figure out all the different options for them ) and then I should be good to go with another twenty or so colourful marines and a couple of characters. 2 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6117656 Share on other sites More sharing options...
Paladin777 Posted June 21, 2025 Share Posted June 21, 2025 (edited) Edit: I reread the rules. No basecoated models. Official vow coming later. Edited June 22, 2025 by Paladin777 Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6117691 Share on other sites More sharing options...
Dr. Clock Posted June 21, 2025 Share Posted June 21, 2025 8 hours ago, Antarius said: a couple of kill teams Copy that! For loadouts I'd heartily recommend a Fortis team: 2 missile launchers, 4 plasma guns and 4 bolter. Then for veteran squads I get alot of use out of 'assault' squads with 4 hammers, 2 Infernus HB, 2 fragcannons and 2 storm shields. The other kill teams are all non-tacticus so I haven't used them yet... But checking out the models you have, I'd suggest that you really can't ever go wrong with more hammers and heavy weapons, though it also often makes sense to bring a few 'non kill team' units if you don't have guys with the fancy weapons - nothing wrong with 1-2x5 Intercessors or whatever cheap rando 5-mans you favor for pure scoring. Cheers, The Good Doctor. 1 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6117708 Share on other sites More sharing options...
Dr_Ruminahui Posted June 23, 2025 Author Share Posted June 23, 2025 Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value). Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6117953 Share on other sites More sharing options...
The Pounder Posted June 24, 2025 Share Posted June 24, 2025 Looking good @Antarius! At a rapid pace too! I’ve finished the first part of my vow! A Heavy Weapons Squad. Here’s the pic: Death Korps of Krieg Heavy Weapons Squad That’s 7 pts so far. More pics available in my project log in the Astra Militarum threads. 2 5 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6118290 Share on other sites More sharing options...
GSCUprising Posted June 29, 2025 Share Posted June 29, 2025 (edited) “I, GSCUprising, heed the Call to Arms and pledge to paint 10 Kasrkin troops and one Valkyrie to bear them into the skies on or before 15th September 2025, or bear the badge of failure until year's end." My main pledges lie elsewhere, but I am determined to get these ones done and love the impetus this challenge gives. Edited July 15, 2025 by Dr_Ruminahui Added picture to vow 4 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6118928 Share on other sites More sharing options...
Dr_Ruminahui Posted July 2, 2025 Author Share Posted July 2, 2025 (edited) Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value, entry into Master of the Forge). @GSCUprising, I have that as 16 points. You'll need to post a photo pre-painting (primed is fine). Edited July 15, 2025 by Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6119439 Share on other sites More sharing options...
Dr_Ruminahui Posted July 3, 2025 Author Share Posted July 3, 2025 (edited) - STATE OF THE EVENT - I've decided rather than doing reports on the event at the end of every month into the event, to instead do them at the end of every calendar month - so, 2 weeks in, 1/2 way through, 2 weeks left, as I feel that better replicates the flow of the event. I will still be posting reminders at the 1 and 2 months marks, but with no type of reporting or recap at those times. So, 2 weeks into the event we have 60 individual participants with 71 vows, for a total of 3,091.5 vowed points. We have 5 entries into the Master of the Forge category, and zero for Young Bloods. If anyone else has a Master of the Forge entry, or wants to participate as a Young Blood, please let me know. Or, if you told me and I missed recording it, please let me know again. The Stronghold leading in vowed points is the Heresy stronghold, with an insane 1167 points vowed. Not surprisingly, the largest vow of 410 points by @SgtSharp is also in that Stronghold, as is the most points vowed for a subfaction - in this case, the "For the Emperor" subfaction with 616. The second highest subfaction is also from this stronghold - "For the Warmaster" has 572 points vowed. Finally, it is tied for the most completed vows - 2, worth 19 points. Although its way too early for this to be determinative (or even particularly meaningful), the Imperium Stronghold has the highest completion rate (based points of complete vows versus those of uncompleted vows) of 43%. It is also the Stronghold with the lowest points vowed at 104, and the only Stronghold with a subfaction with a 100% completion rate - Deathwatch. Between those two are Xenos with vows of 769 points, Astartes of 549.5 and Chaos with 502. Xenos has the highest points in completed vows - 69, and is tied for the most completed vows (with Heresy) with 2. Most completed vows are by @Antarius, who has completed 2 worth 113 points. Highest individually pointed model vowed is worth 20 points, in the form of a Revenant Titan - our only full sized titan so far. Finally, in a very humourous turn, according to Bolter & Chainsword the Horus Heresy was an inside job, with the highest vow for the Warmaster (at 365 points) being from the @GodEmperorOfMankind himself. Anyway, great to see all the participants and their enthusiasm. Happy painting and I look forward to many more completed vows and beautiful models. Edited July 7, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6119448 Share on other sites More sharing options...
Lord_Ikka Posted July 3, 2025 Share Posted July 3, 2025 "I, Lord_Ikka , heed the Call to Arms and pledge to paint the following for {22 pts} for the Glory of the Imperium of Mankind and the Imperium Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." 1 Ash Wastes Outrider - 2pts 20 Necromunda Corporate/House security Troops - 20 pts 4 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6119459 Share on other sites More sharing options...
GSCUprising Posted July 6, 2025 Share Posted July 6, 2025 On 7/3/2025 at 12:29 AM, Dr_Ruminahui said: Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value, entry into Master of the Forge). @GSCUprising, I have that as 16 points. You'll need to post a photo pre-painting (primed is fine). Yes, guv. Will sort pics tomorrow when I return home. Thank you. 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6119900 Share on other sites More sharing options...
Dr_Ruminahui Posted July 7, 2025 Author Share Posted July 7, 2025 (edited) Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value, entry into Master of the Forge). Edited July 7, 2025 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6120092 Share on other sites More sharing options...
GSCUprising Posted July 10, 2025 Share Posted July 10, 2025 On 7/3/2025 at 12:29 AM, Dr_Ruminahui said: Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value, entry into Master of the Forge). @GSCUprising, I have that as 16 points. You'll need to post a photo pre-painting (primed is fine). Sorry. I got home a couple of days later than anticipated. Please see below for my Valkyrie and Kasrkin. Sorry for the Valk, it's in bits ready for undercoating. 3 Back to top Link to comment https://bolterandchainsword.com/topic/385989-call-to-arms-2025-imperium-stronghold/#findComment-6120658 Share on other sites More sharing options...
